Home » Language IDEs » PHP Development Tools (PDT) » phpDoc @property tag not working.
phpDoc @property tag not working. [message #73646] Tue, 17 June 2008 10:23 Go to next message
Originally posted by: runar.b.olsen.gmail.com
Lets say you have a class that acts as a registry and that contains the
magic methods __get($var) and __set($var, $value); Now for most of the
time you cannot be sure what type of variable __get will return but you
do know that __get('foo'); always will return a instance of the Foo
class. According to phpDoc (http://preview.tinyurl.com/2fxl57) you can
add the @property doc tag for the class defining that the property $foo
of the class Registery is a instance of Foo, but PDT does not seem to
take this into account when it comes to auto completing. Is this
something that will be included in a later release?
Example:
<?php
* @property Foo $foo
class Registry {
private $datastore = array();
public function __get($var) {
if(array_key_exists($var, $this->datastore) {
return $this->datastore[$var];
return false;
class Foo {
public function bar()
echo 'FooBar!';
$reg = new Registry();
// There is no foo in the auto complete list here
$foo = $reg->foo;
// Typing in $foo-> does not tell me about the bar method.
Re: phpDoc @property tag not working. [message #73664 is a reply to message #73646] Tue, 17 June 2008 12:20 Go to previous messageGo to next message
Hi Runar,
It's funny that you raise this issue today, because I have committed the
fixes this morning. for more details see this Bugzilla issue (Bug #235108
- [GoalEvaluator] Evaluate __call() __ get() functions and variables)
https://bugs.eclipse.org/bugs/show_bug.cgi?id=235108
Eclipse PDT now supports both @property and @method tags that indicate
magic fields and methods.
I will appreciate it if you can check next nightly build and see if this
answers your requirements.
Runar B. Olsen wrote:
> Example:
> <?php
> class Registry {
> return false;
> class Foo {
> echo 'FooBar!';
> $foo = $reg->foo;
Re: phpDoc @property tag not working. [message #991316 is a reply to message #73646] Tue, 18 December 2012 09:12 Go to previous message
Hello, I would like to return to this subject. I've found a problem in my example with scenerio 3. It seems that the engine dosen't recognize the array symbol [] when used in @method tag. The popup hint show Foo[] correctly as return value but the autocomplete dosen't work.
<?php
 * @method Foo getOne() getOne()
 * @method Foo[] getAllWithProblem() getAllWithProblem()
class Foo
	public function autocompleteWorks()
	 * @return Foo[]
	public function getAllOkay()
		return array( new Foo() );
	static public function testScenerios()
		// scenerio 1
		$oFoo1 = $this->getOne();
		// works
		$oFoo1->autocompleteWorks();
		// scenerio 2
		foreach($this->getAllOkay() as $oFoo2)
			// works
			$oFoo2->autocompleteWorks();
		// scenerio 3
		foreach($this->getAllWithProblem() as $oFoo3)
			// dosen't work
			$oFoo3->
			// scenerio 3 fix, but with nested classes dosen't work
			/* @var $oFoo3 Foo */
			$oFoo3->autocompleteWorks();
Previous Topic:Debug Display view functionality
Next Topic:eclipse pdt editor not showing error
Current Time: Thu Jul 17 20:46:19 EDT 2025
Powered by FUDForum. Page generated in 0.03057 seconds
