Home » Language IDEs » C / C++ IDE (CDT) » CDT 1.1 HPUX
CDT 1.1 HPUX [message #73633] Tue, 17 June 2003 08:24 Go to next message
Originally posted by: ofourdan.regis-dgac.net
Hi all,
I've seen several posts regarding the CDT on HPUX but did not see much
answers (yet)...
1) Does the CDT work on HPUX ?
2) Does it work with aCC ?
3) Where can I find (ie download) the CDT 1.1 sources (as I can't connect
to CVS from where I am, due to network restrictions) - 1.0 source where
available at the time but I can't find the 1.1 sources...
Thanks in advance,
Olivier.
Re: CDT 1.1 HPUX [message #75958 is a reply to message #73633] Wed, 16 July 2003 10:57 Go to previous message
Originally posted by: dschaefe.ca.ibm.com
"Olivier Fourdan" <ofourdan@regis-dgac.net> wrote in message
news:bcn19a$66v$1@rogue.oti.com...
> Hi all,
> answers (yet)...
We currently have not ported the CDT to HPUX. This is deserving of an
enhancement request if there isn't already one.
If we did support HPUX, then you would have access to the Standard Make
Project which simply run's make. So whatever you can put in a makefile, the
CDT will run it at build time.
Error parsing would be another story but we currently don't have support for
plugable error parsers in 1.1.
Yes, there is a problem with the CDT 1.1 source feature, i.e. it doesn't
provide source. If you simply want to look at it, you can use the ViewCVS
feature at:
http://dev.eclipse.org/viewcvs/index.cgi/?cvsroot=Tools_Proj ect
> Thanks in advance,
Sorry I couldn't be more help,
Doug
Previous Topic:automatic makefile generation
Next Topic:Makefile :: Auto Backup
Current Time: Tue Jul 22 12:54:43 EDT 2025
Powered by FUDForum. Page generated in 0.02490 seconds
