(no subject) [message #707234] |
Mon, 01 August 2011 06:55 |
I'm getting the following error during content assist. what could be the issue?
!STACK 0
java.lang.Error: Unresolved compilation problem:
The code of method specialStateTransition(int, IntStream) is exceeding the 65535 bytes limit
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser$DFA154.specialStateTransition(InternalAtgDslParser.java:65452)
at org.antlr.runtime.DFA.predict(DFA.java:48)
at org.eclipse.xtext.ui.editor.contentassist.antlr.internal.DFA.predict(DFA.java:22)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Table__UnorderedGroup__0(InternalAtgDslParser.java:51709)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Table__UnorderedGroup(InternalAtgDslParser.java:51479)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.ruleTable(InternalAtgDslParser.java:1163)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__TableAssignment_7(InternalAtgDslParser.java:56909)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__Group__7__Impl(InternalAtgDslParser.java:16292)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__Group__7(InternalAtgDslParser.java:16182)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__Group__6(InternalAtgDslParser.java:16080)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__Group__5(InternalAtgDslParser.java:15986)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__Group__4(InternalAtgDslParser.java:15904)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__Group__3(InternalAtgDslParser.java:15831)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__Group__2(InternalAtgDslParser.java:15738)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__Group__1(InternalAtgDslParser.java:15656)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__ItemDescriptor__Group__0(InternalAtgDslParser.java:15583)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.ruleItemDescriptor(InternalAtgDslParser.java:1088)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Repository__ItemDescriptorAssignment_3(InternalAtgDslParser.java:56206)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Repository__Group__3__Impl(InternalAtgDslParser.java:15465)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Repository__Group__3(InternalAtgDslParser.java:15410)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Repository__Group__2(InternalAtgDslParser.java:15341)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Repository__Group__1(InternalAtgDslParser.java:15259)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Repository__Group__0(InternalAtgDslParser.java:15186)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.ruleRepository(InternalAtgDslParser.java:1013)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Type__Alternatives(InternalAtgDslParser.java:5881)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.ruleType(InternalAtgDslParser.java:263)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Package__TypesAssignment_3(InternalAtgDslParser.java:55276)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Package__Group__3__Impl(InternalAtgDslParser.java:9695)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Package__Group__3(InternalAtgDslParser.java:9640)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Package__Group__2(InternalAtgDslParser.java:9571)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Package__Group__1(InternalAtgDslParser.java:9489)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Package__Group__0(InternalAtgDslParser.java:9416)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rulePackage(InternalAtgDslParser.java:188)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Model__PackagesAssignment_1(InternalAtgDslParser.java:55196)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Model__Group__1__Impl(InternalAtgDslParser.java:9367)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Model__Group__1(InternalAtgDslParser.java:9316)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.rule__Model__Group__0(InternalAtgDslParser.java:9238)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.ruleModel(InternalAtgDslParser.java:113)
at com.atg.atgdsl.ui.contentassist.antlr.internal.InternalAtgDslParser.entryRuleModel(InternalAtgDslParser.java:75)
at com.atg.atgdsl.ui.contentassist.antlr.AtgDslParser.getFollowElements(AtgDslParser.java:482)
at org.eclipse.xtext.ui.editor.contentassist.antlr.AbstractContentAssistParser.getFollowElements(AbstractContentAssistParser.java:220)
at org.eclipse.xtext.ui.editor.contentassist.antlr.ParserBasedContentAssistContextFactory.create(ParserBasedContentAssistContextFactory.java:124)
at org.eclipse.xtext.ui.editor.contentassist.CompletionProposalComputer.exec(CompletionProposalComputer.java:48)
at org.eclipse.xtext.ui.editor.contentassist.CompletionProposalComputer.exec(CompletionProposalComputer.java:1)
at org.eclipse.xtext.util.concurrent.IStateAccess$AbstractImpl.readOnly(IStateAccess.java:40)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:70)
Arun
FUDForum. Page generated in 0.03181 seconds
