[Elver/Teneo] Hibernate Search (Apache Lucene) integration [message #73598] |
Mon, 05 March 2007 09:14  |
I am using Hibernate Search with my persistent classes. Now I have to
add the necessary annotations to the generated model code afterwards. I
was wondering if it is possible to add those annotations to the datamodel
(ecore) and let the code generator add the annotations to the generated
classes automatically? Is this possible?
Arjen.
btw. I'm using the Elver codegen feature to generate the model code.
Re: [Elver/Teneo] Hibernate Search (Apache Lucene) integration [message #73731 is a reply to message #73616] |
Tue, 06 March 2007 07:33  |
Hi Martin,
Thanks, that would be great. I've entered a feature request (Bug id
176480).
Arjen.
On Mon, 05 Mar 2007 17:58:30 +0100, Martin Taal wrote:
> Hi Arjen,
> Interesting feature. At this time Teneo does not generate the code (and
> ejb3 annotations). For the longer term of Teneo this is in the roadmap.
> For Elver codegen this can certainly be an option which is handled
> earlier than 'the longer term'. Maybe it is possible to support this
> without using annotations in the code (would be nice as dynamic emf
> would then also be covered). I need to check.
> Can you enter a bugzilla feature request on Teneo for this?
> gr. Martin
> Arjen Hoekman wrote:
>> datamodel (ecore) and let the code generator add the annotations to the
>> generated classes automatically? Is this possible?
>> Thanks,
>> Arjen.
Re: [Elver/Teneo] Hibernate Search (Apache Lucene) integration [message #603108 is a reply to message #73598] |
Mon, 05 March 2007 11:58  |
Hi Arjen,
Interesting feature. At this time Teneo does not generate the code (and ejb3 annotations). For the
longer term of Teneo this is in the roadmap. For Elver codegen this can certainly be an option which
is handled earlier than 'the longer term'.
Maybe it is possible to support this without using annotations in the code (would be nice as dynamic
emf would then also be covered). I need to check.
gr. Martin
> Arjen.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Elver/Teneo] Hibernate Search (Apache Lucene) integration [message #603142 is a reply to message #73616] |
Hi Martin,
176480).
Arjen.
> Hi Arjen,
> gr. Martin
>> Thanks,
>> Arjen.
FUDForum. Page generated in 0.08491 seconds
