Home » Eclipse Projects » Remote Application Platform (RAP) » Tomcat - need to clean work directory when restarting
Tomcat - need to clean work directory when restarting [message #73542] Mon, 11 February 2008 17:48 Go to next message
I am running my RAP application under Tomcat 6.0.16 on Windows XP and
Vista. In my own application, and in the sample calc application
( http://www.volanakis.de/nuggets/rap_deployment_with_war/calc .ui.rap-war.zip)
used in the RAP Deployment tutorial
( http://rapblog.innoopract.com/2007/12/rap-deployment-part-2- deploying-your.html),
I find that when I restart Tomcat, I need to clear out the
application's work directory (C:\Program Files\Apache Software
Foundation\Tomcat 6.0\work\Catalina\localhost\calc). Otherwise:
Start Tomcat
http://localhost:8080/calc/rap - works normally
Stop Tomcat
Start Tomcat
http://localhost:8080/calc/rap - error:
HTTP Status 404 - ProxyServlet: /calc/rap
type Status report
message ProxyServlet: /calc/rap
description The requested resource (ProxyServlet: /calc/rap) is not
available.
Apache Tomcat/6.0.16
The servletbridge test, under the calc app, does not have this problem:
http://localhost:8080/calc/sp_test
nor does the servletbridge sample app
(http://www.eclipse.org/equinox/server/downloads/bridge.war):
http://localhost:8080/bridge/sp_test
The Tomcat sample app (sample.war) also does not have this problem.
I have tried this with two different browsers on two different machines
to make sure it was not a browser caching issue.
If there is a simple way to force Tomcat or the servletbridge to clear
out the work directory between runs that may be sufficient to solve the
problem.
Ryan
Re: Tomcat - need to clean work directory when restarting [message #73882 is a reply to message #73542] Thu, 14 February 2008 03:26 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
maybe there are some errors during the shutdown of the RAP app, that
prevent the server from cleanup the working directory. Could you please
look whether there are some problems reported in your catalina logfiles?
We have been working recently on some problems with session shutdown and
our Yoxos team that uses RAP told us that shutdown and restart of the
application server now works without problems. So maybe it's worth to
try the latest CVS version.
Ciao
Frank
-----Ursprüngliche Nachricht-----
Von: Ryan Donnelly [mailto:ryanrd1@gmail.com]
Bereitgestellt: Montag, 11. Februar 2008 23:48
Bereitgestellt in: eclipse.technology.rap
Unterhaltung: Tomcat - need to clean work directory when restarting
Betreff: Tomcat - need to clean work directory when restarting
XP and Vista. In my own application, and in the sample calc application
..zip)
our.html),
Start Tomcat
Stop Tomcat
Start Tomcat
type Status report
available.
problem:
problem.
machines
clear
problem.
Ryan
Re: Tomcat - need to clean work directory when restarting [message #74095 is a reply to message #73882] Thu, 14 February 2008 12:57 Go to previous messageGo to next message
Frank,
I have just tried building both the sample calc app and my app with RAP
from CVS and still have this problem. I am able to stop the Tomcat
service without errors. I have turned logging up to DEBUG on Tomcat and
the only thing remotely out of the ordinary is this, in
catalina.2008-02-14.log:
Feb 14, 2008 3:29:35 PM org.apache.catalina.core.StandardContext
addApplicationListener
INFO: The listener "listeners.ContextListener" is already configured for
this context. The duplicate definition has been ignored.
INFO: The listener "listeners.SessionListener" is already configured for
There is also a logfile
work/Catalina/localhost/rapdemo/eclipse/workspace/.metadata/ .log
which has the following error in it:
!ENTRY org.eclipse.core.runtime 2 0 2008-02-14 15:50:01.941
!MESSAGE Authorization infrastructure
(org.eclipse.core.runtime.compatibility.auth) not installed.
!STACK 0
java.lang.NoClassDefFoundError:
org/eclipse/core/internal/runtime/auth/AuthorizationHandler
org.eclipse.core.internal.runtime.InternalPlatform.initializ eAuthorizationHandler(InternalPlatform.java:603)
org.eclipse.core.internal.runtime.InternalPlatform.start(Int ernalPlatform.java:745)
org.eclipse.core.internal.runtime.PlatformActivator.start(Pl atformActivator.java:31)
org.eclipse.osgi.framework.internal.core.BundleContextImpl$2 .run(BundleContextImpl.java:999)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tartActivator(BundleContextImpl.java:993)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:974)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:417)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:189)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:340)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.MultiSourcePackage. loadClass(MultiSourcePackage.java:31)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:405)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:161)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:501)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:471)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:430)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:413)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:408)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.installBundles(ConfigurationActivator.java:218)
org.eclipse.update.internal.configurator.ConfigurationActiva tor.start(ConfigurationActivator.java:82)
org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:350)
org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1118)
org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:634)
org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:508)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:282)
org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:468)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:195)
org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:297)
Do you know of a way to force Equinox/Servletbridge or Tomcat to clear
out the work directory between runs?
Ryan
Frank Appel wrote:
> Ciao
> Frank
> .zip)
> our.html),
> Start Tomcat
> Stop Tomcat
> Start Tomcat
> type Status report
> available.
> problem:
> problem.
> machines
> clear
> problem.
> Ryan
Re: Tomcat - need to clean work directory when restarting [message #74131 is a reply to message #74095] Fri, 15 February 2008 03:18 Go to previous messageGo to next message
Originally posted by: benjamin.wolff.web.de
hi!
to avoid the exception that is thrown you can checkout the
org.eclipse.core.runtime.compatibility.auth plugin from cvs. it is located
in the dev.eclipse.org:/cvsroot/eclipse repository.
i already mentioned this exception
( http://www.eclipse.org/newsportal/article.php?id=2202&gr oup=eclipse.technology.rap#2202)
HTH
-ben
Re: Tomcat - need to clean work directory when restarting [message #74572 is a reply to message #74131] Tue, 19 February 2008 02:41 Go to previous message
another thing. Ensure that the -console flag has been removed from the
web.xml. This may also cause trouble regarding restarting the appserver.
If the problem still persists feel free to file a bug report.
Ciao
Frank
Von: Ben W. [mailto:benjamin.wolff@web.de]
Bereitgestellt: Freitag, 15. Februar 2008 09:19
Betreff: Re: Tomcat - need to clean work directory when restarting
hi!
located in the dev.eclipse.org:/cvsroot/eclipse repository.
hnology.rap#2202)
HTH
-ben
Previous Topic:XMLMemento missing(?)
Next Topic:line numbers in library code
Current Time: Thu Nov 06 15:54:01 EST 2025
Powered by FUDForum. Page generated in 0.03653 seconds
