Home » Language IDEs » Java Development Tools (JDT) » [Java Search] search for methods by return type (and parameter types)?
[Java Search] search for methods by return type (and parameter types)? [message #6613] Sun, 27 April 2003 17:55 Go to next message
Is there a way to search for methods by return type, as well as
parameter types? If so, how? and are there preferences that must be
set to enable this?
If not, I'll make a feature request (if not made already ...)
Re: [Java Search] search for methods by return type (and parameter types)? [message #7353 is a reply to message #6613] Mon, 28 April 2003 08:51 Go to previous messageGo to next message
Yes. You can search using the following pattern (assuming that X is the
return type, and Y and Z are the paramter types):
"*(Y, Z) X"
Jerome
"Tom Roche" <tlroche@us.ibm.com> wrote in message
news:b8hjjm$m31$1@rogue.oti.com...
> set to enable this?
Re: [Java Search] search for methods by return type (and parameter types)? [message #7395 is a reply to message #7353] Mon, 28 April 2003 10:58 Go to previous messageGo to next message
>> parameter types?
> the return type, and Y and Z are the paramter types): "*(Y, Z) X"
Doh! Merci: I had tried
X *(Y, Z)
which makes more sense (to me, at least :-), since that's the order in
which one declares a method. I wonder why <whoever> decided to require
return-type-last?
Re: [Java Search] search for methods by return type (and parameter types)? [message #7407 is a reply to message #7395] Mon, 28 April 2003 11:17 Go to previous messageGo to next message
Maybe because searching with a given return type is less used...
I bet that if it was the opposite, people would complain as well :-)
news:3EAD4190.5070209@us.ibm.com...
> >> parameter types?
> X *(Y, Z)
> return-type-last?
Re: [Java Search] search for methods by return type (and parameter types)? [message #7426 is a reply to message #6613] Mon, 28 April 2003 11:41 Go to previous messageGo to next message
Could you give an example of what you're looking for ?
> set to enable this?
Re: [Java Search] search for methods by return type (and parameter types)? [message #7492 is a reply to message #7426] Mon, 28 April 2003 12:11 Go to previous message
Ignore my post.
"Philippe Mulet" <philippe_mulet@fr.ibm.com> wrote in message
news:b8ji2p$4bj$1@rogue.oti.com...
> > set to enable this?
Previous Topic:Execute "Organize Imports" from within code?
Next Topic:Getting unexpected exceptions in multiple plugins
Current Time: Mon Nov 03 18:11:14 EST 2025
Powered by FUDForum. Page generated in 0.03655 seconds
