How to retrieve the xml encoding from the schema [message #72976] |
Wed, 05 September 2007 11:07  |
Originally posted by: nospam.nospam.com
Hi all,
I need to get the XML encoding from the loaded Schema, we set XSD_TRACK_LOCATION to true prior to parsing i.e.
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
// parse the doc..
XSDResourceImpl xsdResource = (XSDResourceImpl) resourceSet
.getResource(schemaURI,true);
XSDSchema x = xsdResource.getSchema();
However, the following always returns null
String encoding = x.getDocument().getXMLEncoding();
Does anyone know how to get the xml encoding from the schema ?
Many thanks in advance
Tony
Re: How to retrieve the xml encoding from the schema [message #73020 is a reply to message #73004] |
Wed, 05 September 2007 14:35  |
Originally posted by: nospam.ibm.com
Thanks for the quick response Ed.
Does the trick nicely
Ed Merks wrote:
> Tony,
> The encoding will be put into the
> XSDResourceImpl.getDefaultSaveOptions() map via the XSD_ENCODING option
> as the key.
> TG wrote:
>> Hi all,
>> Boolean.TRUE);
>> // parse the doc..
>> Tony
Re: How to retrieve the xml encoding from the schema [message #602596 is a reply to message #72976] |
Wed, 05 September 2007 11:16  |
Tony,
as the key.
TG wrote:
> Hi all,
> Boolean.TRUE);
> // parse the doc..
> Tony
Re: How to retrieve the xml encoding from the schema [message #602604 is a reply to message #73004] |
Ed Merks wrote:
> Tony,
> as the key.
> TG wrote:
>> Hi all,
>> Boolean.TRUE);
>> // parse the doc..
>> Tony
FUDForum. Page generated in 0.14363 seconds
