Home » Archived » BIRT » Chart generation problems
Chart generation problems [message #72962] Fri, 09 September 2005 04:58 Go to next message
Originally posted by: brian.compston.xxxxx.xxx
I'm trying to generate .rptdesign files from within a programme. All works
well (tables, paragraphs images etc.) until I attempt to create a graph
element.
The
ExtendedItemHandle ehi = elementFactory.newExtendedItem(null, "Chart");
call is always returning null.
I have tried running the example programmes such as SalesReport.java and
get exactly the same result. Looking at the internals I think it is
something do to with failure to load a 'rom.def' file.
Has anyone got any ideas or a solution ?
Thanks in advance.
Brian Compston
Re: Chart generation problems [message #73046 is a reply to message #72962] Fri, 09 September 2005 11:09 Go to previous message
Originally posted by: brian.compston.xxx.xxx
After further invistigation I have added various plugins to the project
which now results in a
java.lang.ClassCastException:org.eclipse.birt.chart.reportIt em.ChartReportItemFactoryImpl
error when the DesignEngine.newSession() call is made.
The "Validate Plugin-set" test doesn't report any problems for the set
currently selected.
Any ideas ?
Previous Topic:scripted Datasource example?
Next Topic:RunReport.java Error
Current Time: Mon Jul 21 21:08:24 EDT 2025
Powered by FUDForum. Page generated in 0.26083 seconds
