PDE Build: building Source feature. [message #72871] |
Thu, 02 June 2005 18:59  |
Originally posted by: VMarathe.ifmc.sdps.org
Hi Everybody,
I am building a feature using PDE build process and also trying to
generate source feature and plugins also. As per the documentation I
have read so far, we have to make two entries.
1. In build.properties in feature project, add "generate.feature" script
2. Add "<includes>" element in feature.xml
Using this, I get the distributable zip file as I want but it includes
all zip files of the plug-ins source code.
My question is, are the source code zips supposed to be included in the
binary distributable? I want all the source code zips to go to a
different zip file. I have a limited idea about building source features.
Any kind of help is highly appreciated.
Thanks.
Re: PDE Build: building Source feature. [message #74292 is a reply to message #73449] |
Mon, 06 June 2005 09:52   |
Philippe Ombredanne wrote:
> Vasant,
> I assume you are making reference to this fine article:
> http://www.eclipse.org/articles/Article-PDE-Automation/autom ation.html
> What you get is a feature, and a plugin extending
> org.eclipse.pde.core.source.
> The plugin contains only the sources as a zip.
> The whole zip will contain everything, binary plugins and source plugins as
> well as the related features.
> If you want two different zips one with source only, the other without
> sources, check how this is done:
> http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.releng. eclipsebuilder/
> Each directory corresponds to a set of builds.
> You might need a bit of customization of the customTargets.xml to accomplish
> what you want as Eclipse is typically distributed as binaries only or
> binaries+sources.
Thanks, a lot, Philippe for your reply.
Yes, I was making reference to the same link.
I will go through the link you have provided and see if it explains what
I need to do. It would also be great if you could let me know which
folder I can take a look at from the link you have sent, because the
link contains many different folders.
Thanks again.
Vasant.
Re: PDE Build: building Source feature. [message #74596 is a reply to message #74431] |
Mon, 06 June 2005 12:36  |
> "Vasant" <VMarathe@ifmc.sdps.org> wrote in message
> news:42A45530.4060106@ifmc.sdps.org...
> Dear Vasant,
> I doubt you will find any explanantion, but the code and the article should
> help you make your way around.
> And if you want to write some explanantion for everybody to enjoy, that
> would very nice!
Thanks, Philippe, for coming back.
I will dig through the code and shall write some explanation about
seperating the source and binary once I figure it out.
Thanks again,
Vasant
FUDForum. Page generated in 1.21323 seconds
