Home » Archived » Visual Editor (VE) » VE doesn't start at loading
VE doesn't start at loading [message #72770] Thu, 25 November 2004 20:24 Go to next message
Originally posted by: andreas_bauer.arcor.de
I installed SDK, EMF, GEF, VE runtime from http://www.eclipse.org/vep.
Eclipse works for me, but if I want to create a Visual Class,
setup from VE stops with the Error Messages:
Error running operations
"An internal error occured during:
Create remote VM Visual Editor for Java.
In the error logfile is th entry:
Error Nov 26, 2004 01:36:38.437 An internal error occurred during: "Create
Remote VM for Visual Editor for Java".
org.eclipse.core.runtime.CoreException[2]: java.lang.RuntimeException:
IWAV0067E No Standard Bean Type Proxy Factory has been set.
org.eclipse.jem.internal.proxy.core.ProxyFactoryRegistry.get BeanTypeProxyFactory(ProxyFactoryRegistry.java:174)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorVMController$CreateRegistry.run(JavaVisualEditorVMContro ller.java:168)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
It must be something with Setup of VE.
I'm new with VE, searching the whole time in the net without success, need
help.
Many thanks
Andreas
Re: VE doesn't start at loading [message #73182 is a reply to message #72770] Mon, 29 November 2004 16:28 Go to previous message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
There must be more errors, but most likely it is a firewall problem.
Do you have a firewall, and is it set to allow localhost access?
If you are in some system other than windows, check your etc/.hosts
files. It should have ONLY one entry that has localhost on it, and that
entry should be for 127.0.0.1
Rich Kulp
Re: VE doesn't start at loading [message #603496 is a reply to message #72770] Mon, 29 November 2004 16:28 Go to previous message
Rich Kulp
Previous Topic:where can i get the guide?
Next Topic:Add Events not working in VE on one project
Current Time: Sat Jul 26 12:36:12 EDT 2025
Powered by FUDForum. Page generated in 0.08064 seconds
