Home » Archived » BIRT » Timestamp vs date
Timestamp vs date [message #72673] Thu, 08 September 2005 10:32
Originally posted by: fakeuser.poh.dynalias.org
I have the following code to get the value of a computed column
if(row["DISPOSITION_DATE"] != null)
row["DISPOSITION_DATE"];
}else{
new Date("0/0/00");
where row["DISPOSITION_DATE"] is a java.sql.Timestamp
I get the following error when I run the report
10:08:58,500 ERROR [STDERR] RHINO USAGE WARNING: Missed Context.javaToJS() conversion:
Rhino runtime detected object 2005-08-01 15:33:18.421 of class java.sql.Timestamp where it expe
cted String, Number, Boolean or Scriptable instance. Please check your code for missig Context.
javaToJS() call.
The report itself also has the error:
There are errors on the report page:
- There are error(s) in Table:null
Error0 : Error.TableItemProcessingError(1 time)detail: There are problems(s) processing table .null
I need to compute this because I am sorting on the disposition_date, which may contain null values.
new Date(row["DISPOSITION_DATE"]) gets rid of the error in the report (not the rhino one), but the
date shows up as if I had used new Date("0/0/00").
How can I wrap this so that I get the correct date showing up in the report
(I don't mind the Rhino errors if that helps)
Patrick
Previous Topic:EclipseCon Presentation Topics
Next Topic:Master page header and footer on PDF, only displayed on first page
Current Time: Sat Jul 26 17:58:57 EDT 2025
Powered by FUDForum. Page generated in 0.03596 seconds
