Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Teneo] Date and DateTime mapping?
[Teneo] Date and DateTime mapping? [message #72637] Thu, 22 February 2007 17:18 Go to next message
My date and datetime types are currently mapping to varchar(255) instead of date. The following XSD element
<element name="lastReboot" type="dateTime"></element>
maps to the following hbm:
<property name="lastReboot" lazy="false" insert="true" update="true" not-null="false" unique="false">
<column not-null="false" unique="false" name="`lastreboot`"/>
<type name=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype ">
<param name="edatatype">Date</param>
<param name="epackage">http://www.eclipse.org/emf/2003/XMLType</param>
</type>
</property>
What is the magic incantation to get this to map to a DateTime. I get similar results when I use the date type.
I'm not sure if this is an XSD->ecore mapping or a Teneo issue.
The ecore mapping looks like:
<eStructuralFeatures xsi:type="ecore:EAttribute" name="lastReboot" unique="false"
eType="ecore:EDataType http://www.eclipse.org/emf/2003/XMLType#//DateTime">
<eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">
<details key="kind" value="element"/>
<details key="name" value="lastReboot"/>
<details key="namespace" value="##targetNamespace"/>
</eAnnotations>
</eStructuralFeatures>
Although it looks like the DateTime type is preserved in the mapping, I noticed that the ecore-Java mapping is to an Object and not a Date-like type.
Is Date/DateTime not being mapped to DB date/datetime in Teneo or is there potentially something wrong in my configuration?
Brian
Re: [Teneo] Date and DateTime mapping? [message #72651 is a reply to message #72637] Thu, 22 February 2007 18:49 Go to previous messageGo to next message
After poking around in the source, I believe I found the problem in the method isEDate() in org.eclipse.emf.teneo.util.EcoreDataTypes.java
Apparently, the EDataType instance class for date types is of type Object, not one of the java date classes expected in this function. I made the following change to the method and was able to get the datetime mappings I was hoping for, although I didn't try timestamps or any of the other types. I don't know if there are other places where a similar change should be made.
replace this:
public boolean isEDate(EDataType eDataType) {
Class ic = eDataType.getInstanceClass();
return java.util.Date.class == ic || java.util.Calendar.class == ic || java.sql.Date.class == ic;
with this:
String nm = eDataType.getName();
return nm.equals("DateTime") || nm.equals("Date") || nm.equals("Time");
When making this change, the hbType() method will now return a java.util.Date classname instead of null.
This results in the correct mapping, but it isn't quite correct. The problem is that when you populate a dateTime typed element from an XML file, the format of the data doesn't match what XML Schema expects. I tried having AbstractMapper.hbType() return "org.eclipse.xsd.impl.type.XSDDateTimeType" presuming that it could do the proper mapping, but the hibernate mapping code doesn't know how to map one of those to a date and tosses an exception.
It would appear that what is needed is some kind of user defined type in the hibernate mapping layer (extending org.hibernate.UserType) but I'm a bit out over my skis right now. Any suggestions on how to get this to work properly?
Brian
> <type
> <param
> </type>
> </property>
> unique="false"
> <eAnnotations
> </eAnnotations>
> type.
> Brian
Re: [Teneo] Date and DateTime mapping? [message #72664 is a reply to message #72651] Fri, 23 February 2007 02:07 Go to previous messageGo to next message
Brian,
What class was ic in your case?
gr. Martin
> replace this:
> with this:
> work properly?
> Brian
>> <type
>> <param
>> </type>
>> </property>
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
>> Date-like type.
>> there potentially something wrong in my configuration? Brian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Date and DateTime mapping? [message #72679 is a reply to message #72664] Fri, 23 February 2007 03:59 Go to previous messageGo to next message
ic for the datetime elements were coming back as type "java.lang.Object". However, somewhere under the covers in EMF, the actual type is org.eclipse.emf.ecore.xml.type.internal.XMLCalendar (I was able to get a cast exception when I tried to map it as a java.util.Date type).
Just for grins, I implemented a hibernate usertype that maps the org.eclipse.emf.ecore.xml.type.internal.XMLCalendar class. I then modified hbtype() in AbstractMapper to return my user type class instead of "java.util.Date".
So far, it is working (the mapping is correct) but with one caveat - It is tracking the dates properly, but for some reason, I'm losing the time precision (everything is at 12:00).
Brian
Martin Taal wrote:
> Brian,
> gr. Martin
>> replace this:
>> with this:
>> nm.equals("Time");
>> Brian
>>> <type
>>> <param
>>> </type>
>>> </property>
>>> unique="false"
>>> <eAnnotations
>>> </eAnnotations>
>>> Date-like type.
Re: [Teneo] Date and DateTime mapping? [message #72692 is a reply to message #72664] Fri, 23 February 2007 04:51 Go to previous messageGo to next message
BTW, I found the problem in my user type where it was losing the hours/minutes.
I'd be more than happy to share it with you if you believe that adding a special type for datetime is the way to solve the problem.
Brian
Martin Taal wrote:
> Brian,
> gr. Martin
>> replace this:
>> with this:
>> nm.equals("Time");
>> Brian
>>> <type
>>> <param
>>> </type>
>>> </property>
>>> unique="false"
>>> <eAnnotations
>>> </eAnnotations>
>>> Date-like type.
Re: [Teneo] Date and DateTime mapping? [message #72704 is a reply to message #72692] Fri, 23 February 2007 06:47 Go to previous messageGo to next message
--------------090102080205020907010008
Brian,
I'm still looking at using
https://bugs.eclipse.org/bugs/show_bug.cgi?id=172063 to switch to using
the XMLGregorianCalendar and Duration now that we can depend on JDK 5.0
classes. It looks like we can't stop using our own internal QName class
because our QName class needs to be mutable and the JDK's implementation
is not. I'm concerned that this switch will lead to binary
incompatibility problems when methods like this in XMLTypeFactory
Object createDateTime(String literal);
change to
XMLGregorianCalendar createDateTime(String literal);
and of course there will be similar changes for features of these
EDataTypes in existing generated client APIs.
I'm not sure what's best... Comments are welcome...
> hours/minutes.
> Brian
> Martin Taal wrote:
>> Brian,
>> gr. Martin
>>> replace this:
>>> with this:
>>> nm.equals("Time");
>>> Brian
>>>> <type
>>>> <param
>>>> </type>
>>>> </property>
>>>> <eAnnotations
>>>> </eAnnotations>
>>>> is there potentially something wrong in my configuration? Brian
<html>
<head>
</head>
Brian,<br>
<br>
I'm still looking at using <a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=172063">https://bugs.eclipse.org/bugs/show_bug.cgi?id=172063</a>
to switch to using the XMLGregorianCalendar and Duration now that we
can depend on JDK 5.0 classes.&nbsp; It looks like we can't stop using our
own internal QName class because our QName class needs to be mutable
and the JDK's implementation is not.&nbsp; I'm concerned that this switch
will lead to binary incompatibility problems when methods like this in
XMLTypeFactory<br>
<blockquote>&nbsp; Object createDateTime(String literal);<br>
</blockquote>
change to<br>
<blockquote>&nbsp; XMLGregorianCalendar createDateTime(String literal);<br>
</blockquote>
EDataTypes in existing generated client APIs.<br>
<br>
I'm not sure what's best...&nbsp; Comments are welcome...<br>
<br>
<br>
Brian Vetter wrote:
<blockquote cite="midermdf2$1v1$1@utils.eclipse.org" type="cite">BTW, I
hours/minutes.
<br>
<br>
<br>
<br>
Brian
<br>
<br>
Martin Taal wrote:
<br>
<blockquote type="cite">Brian,
<br>
<br>
<br>
gr. Martin
<br>
<br>
Brian Vetter wrote:
<br>
<blockquote type="cite">After poking around in the source, I
<br>
<br>
<br>
<br>
replace this:
<br>
<br>
&nbsp;&nbsp;&nbsp; Class ic = eDataType.getInstanceClass();
<br>
&nbsp;&nbsp;&nbsp; return java.util.Date.class == ic || java.util.Calendar.class == ic
<br>
<br>
<br>
with this:
<br>
<br>
&nbsp;&nbsp;&nbsp; String nm = eDataType.getName();
<br>
&nbsp;&nbsp;&nbsp; return nm.equals("DateTime") || nm.equals("Date") ||
nm.equals("Time");
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Brian
<br>
<br>
Brian Vetter wrote:
<br>
<blockquote type="cite">My date and datetime types are currently
<br>
<br>
&nbsp;&nbsp;&nbsp; &lt;element name="lastReboot" type="dateTime"&gt;&lt;/element&gt;
<br>
<br>
<br>
<br>
<br>
&lt;property name="lastReboot" lazy="false" insert="true" update="true"
not-null="false" unique="false"&gt;
<br>
&nbsp;&nbsp;&nbsp; &lt;column not-null="false" unique="false" name="`lastreboot`"/&gt;
<br>
&nbsp;&nbsp;&nbsp; &lt;type
name=" org.eclipse.emf.teneo.hibernate.mapping.DefaultToStringUserT ype "&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &nbsp; &lt;param name="edatatype"&gt;Date&lt;/param&gt;
<br>
name="epackage"&gt;<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2003/XMLType">http://www.eclipse.org/emf/2003/XMLType</a>&lt;/param&gt;
<br>
&nbsp;&nbsp;&nbsp; &lt;/type&gt;
<br>
&lt;/property&gt;
<br>
<br>
<br>
<br>
I'm not sure if this is an XSD-&gt;ecore mapping or a Teneo issue.
<br>
<br>
<br>
&nbsp;&nbsp; &lt;eStructuralFeatures xsi:type="ecore:EAttribute"
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; eType="ecore:EDataType
<a class="moz-txt-link-freetext" href="http://www.eclipse.org/emf/2003/XMLType#//DateTime">http://www.eclipse.org/emf/2003/XMLType#//DateTime</a>"&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp; &lt;eAnnotations
source=<a class="moz-txt-link-rfc2396E" href="http:///org/eclipse/emf/ecore/util/ExtendedMetaData">"http:///org/eclipse/emf/ecore/util/ExtendedMetaData"</a>&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;details key="kind" value="element"/&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;details key="name" value="lastReboot"/&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; &lt;details key="namespace" value="##targetNamespace"/&gt;
<br>
&nbsp;&nbsp;&nbsp;&nbsp; &lt;/eAnnotations&gt;
<br>
&nbsp;&nbsp; &lt;/eStructuralFeatures&gt;
<br>
<br>
type.
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------090102080205020907010008--
Re: [Teneo] Date and DateTime mapping? [message #72715 is a reply to message #72704] Fri, 23 February 2007 12:24 Go to previous messageGo to next message
I think if XMLGregorianCalendar had extended Calendar (or GregorianCalendar), it would be more alluring to use directly. The ability for an app to treat it as either would have been useful. Since XMLGregorianCalendar is unrelated, I'm not sure you get any benefit to using it directly.
The safer approach would be to refactor emf's XMLCalendar class to use XMLGregorianCalendar for all of its parsing/serialization features instead of implementing its own.
Brian
Ed Merks wrote:
> Brian,
> change to
>> hours/minutes.
>> Brian
Re: [Teneo] Date and DateTime mapping? [message #72822 is a reply to message #72692] Sun, 25 February 2007 10:32 Go to previous messageGo to next message
Hi Brian,
Thanks, can you enter a bugzilla for this and attach your patch to it? If possible can you also
attach a small xsd model which illustrates the problem.
gr. Martin
> hours/minutes.
> Brian
> Martin Taal wrote:
>> Brian,
>> gr. Martin
>>> replace this:
>>> with this:
>>> nm.equals("Time");
>>> Brian
>>>> <type
>>>> <param
>>>> </type>
>>>> </property>
>>>> <eAnnotations
>>>> </eAnnotations>
The Netherlands
Re: [Teneo] Date and DateTime mapping? [message #73332 is a reply to message #72822] Wed, 28 February 2007 16:23 Go to previous message
I've created bugzilla 175909 and attached 4 files (3 patch files) and one xsd example to it.
Brian
Martin Taal wrote:
> Hi Brian,
> If possible can you also attach a small xsd model which illustrates the
> problem.
> gr. Martin
>> hours/minutes.
>> Brian
Re: [Teneo] Date and DateTime mapping? [message #602900 is a reply to message #72637] Thu, 22 February 2007 18:49 Go to previous message
replace this:
with this:
Brian
> <type
> <param
> </type>
> </property>
> unique="false"
> <eAnnotations
> </eAnnotations>
> type.
> Brian
Re: [Teneo] Date and DateTime mapping? [message #602903 is a reply to message #72651] Fri, 23 February 2007 02:07 Go to previous message
Brian,
gr. Martin
> replace this:
> with this:
> work properly?
> Brian
>> <type
>> <param
>> </type>
>> </property>
>> unique="false"
>> <eAnnotations
>> </eAnnotations>
>> Date-like type.
The Netherlands
Re: [Teneo] Date and DateTime mapping? [message #602908 is a reply to message #72664] Fri, 23 February 2007 03:59 Go to previous message
Brian
Martin Taal wrote:
> Brian,
> gr. Martin
>> replace this:
>> with this:
>> nm.equals("Time");
>> Brian
>>> <type
>>> <param
>>> </type>
>>> </property>
>>> unique="false"
>>> <eAnnotations
>>> </eAnnotations>
>>> Date-like type.
Re: [Teneo] Date and DateTime mapping? [message #602912 is a reply to message #72664] Fri, 23 February 2007 04:51 Go to previous message
Brian
Martin Taal wrote:
> Brian,
> gr. Martin
>> replace this:
>> with this:
>> nm.equals("Time");
>> Brian
>>> <type
>>> <param
>>> </type>
>>> </property>
>>> unique="false"
>>> <eAnnotations
>>> </eAnnotations>
>>> Date-like type.
Re: [Teneo] Date and DateTime mapping? [message #602917 is a reply to message #72692] Fri, 23 February 2007 06:47 Go to previous message
Brian,
change to
> hours/minutes.
> Brian
> Martin Taal wrote:
>> Brian,
>> gr. Martin
>>> replace this:
>>> with this:
>>> nm.equals("Time");
>>> Brian
>>>> <type
>>>> <param
>>>> </type>
>>>> </property>
>>>> <eAnnotations
>>>> </eAnnotations>
<html>
<head>
</head>
Brian,<br>
<br>
XMLTypeFactory<br>
</blockquote>
change to<br>
</blockquote>
<br>
<br>
<br>
hours/minutes.
<br>
<br>
<br>
<br>
Brian
<br>
<br>
Martin Taal wrote:
<br>
<br>
<br>
<br>
gr. Martin
<br>
<br>
Brian Vetter wrote:
<br>
<br>
<br>
<br>
<br>
replace this:
<br>
<br>
<br>
<br>
<br>
<br>
with this:
<br>
<br>
<br>
nm.equals("Time");
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Brian
<br>
<br>
Brian Vetter wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
&lt;/property&gt;
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
type.
<br>
<br>
<br>
</blockquote>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
Re: [Teneo] Date and DateTime mapping? [message #602921 is a reply to message #72704] Fri, 23 February 2007 12:24 Go to previous message
Brian
Ed Merks wrote:
> Brian,
> change to
>> hours/minutes.
>> Brian
Re: [Teneo] Date and DateTime mapping? [message #602941 is a reply to message #72692] Sun, 25 February 2007 10:32 Go to previous message
Hi Brian,
gr. Martin
> hours/minutes.
> Brian
> Martin Taal wrote:
>> Brian,
>> gr. Martin
>>> replace this:
>>> with this:
>>> nm.equals("Time");
>>> Brian
>>>> <type
>>>> <param
>>>> </type>
>>>> </property>
>>>> <eAnnotations
>>>> </eAnnotations>
The Netherlands
Re: [Teneo] Date and DateTime mapping? [message #603034 is a reply to message #72822] Wed, 28 February 2007 16:23 Go to previous message
Brian
Martin Taal wrote:
> Hi Brian,
> problem.
> gr. Martin
>> hours/minutes.
>> Brian
Previous Topic:[Teneo] Save of resource takes VERY long time
Next Topic:[Teneo] Save of resource takes VERY long time
Current Time: Tue Jul 22 02:43:11 EDT 2025
Powered by FUDForum. Page generated in 0.06595 seconds
