Home » Eclipse Projects » Equinox » ServiceTracker
ServiceTracker [message #72630] Fri, 25 August 2006 03:38 Go to next message
Hi folks,
I have found a strange behaviour in using the ServiceTracker.
I have two plugins A & B (I have more in my RCP application, but this
doesn't matter). Plugin A registers a service in its Activator. Plugin B
creates a ServiceTracker (in a view). First I start plugin B. When I now
start plugin A, plugin B finds the service registered by plugin A. That
is all expected and working behaviour, but when I now stop plugin A,
then the service is released (tracing org.eclipse.osgi), but the service
tracker in plugin B was not informed.
I think the service tracker should be informed?!
TIA
Marco
PS: Eclipse 3.1.2
Re: ServiceTracker [message #72683 is a reply to message #72630] Mon, 28 August 2006 17:27 Go to previous messageGo to next message
Hi Marco,
Yes the ServiceTracker should be informed. Before I ask you to open a
bug report can you tell me more about the ServiceTracker you are
creating? Do you use a ServiceTrackerCustomizer? If so what do you do
in the ServiceTrackerCustomizer.addingService method? For a service to
be tracked by ServiceTracker the ServiceTrackerCustomizer must return a
non-null object to be tracked from the addingService method.
If you are using a ServiceTrackerCustomizer and returning non-null from
addingService then you should definately be informed if that service
goes away. If you are not getting the removedService called then please
open a bug report against Equinox->Framework and attach a testcase we
can use to reproduce.
Thanks.
Tom.
Marco Lehmann wrote:
> Hi folks,
> TIA
> Marco
> PS: Eclipse 3.1.2
Re: ServiceTracker [message #72717 is a reply to message #72683] Thu, 31 August 2006 04:54 Go to previous message
Hi Tom,
unfortunatly, I changed my code to use the extension registry and
therefore extension points. I had several problems with only resolved
and not started bundles.
In spite of that fact I tried to enforce to problem again. I can't. I
tried several scenarios:
1. Plugin A and Plugin B are completly independent of each other
2. Plugin B depends on Plugin A (the service interface is defined in
PluginA)
Both cases work as expected. The service tracker gets informed in both
cases. I must have done something wrong, but I can't remember what.
I'll keep watching.
Thanks for your reply, Tom.
Bye, Marco
Tom Watson schrieb:
> Hi Marco,
> Thanks.
> Tom.
>> Hi folks,
>> TIA
>> Marco
>> PS: Eclipse 3.1.2
Previous Topic:ContextFinder help
Next Topic:How can I start the Equinox OSGi frame with Java 2 Security?Does it work?
Current Time: Sun Aug 31 18:21:31 EDT 2025
Powered by FUDForum. Page generated in 0.04490 seconds
