Re: PreferencesMessages.DLTKEditorPreferencePage_returnKeyword [message #6663 is a reply to message #6587] |
Fri, 22 June 2007 01:20  |
Jae Gangemi wrote:
> On 2007-06-19 03:46:33 -0400, Andrei Sobolev <andrei.sobolev@xored.com>
> said:
>> Jae Gangemi wrote:
>>> what happenned w/ this?
>>> as of my update against cvs today, this constant is no longer
>>> available - is it not coming back? the jdt allows for a specific
>>> color setting for the 'return' keyword, so why wouldn't the dltk?
>>> thx!
>> I've removed all unused NLS messages.
>> Could you add it to your plugin internal preference messages?
>> Or else I could create it in PrefereceMessages.
>> Andrei.
> i didn't know that was unused - i had thought at one point there was a
> reference to it in one of the other language implementations.
> i think it should be added back in - the jdt supports showing the
> 'return' statement in a seperate color, so i think the dltk should as well.
> i've created a patch and attached it to this bug:
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=193336
> oddly enough, the ruby and python implemenations already had most of
> this work done, i just needed to add the keyword into the coloring
> preference config page. the tcl implemenation required a little more
> effort. :)
I've applied patch. Thanks.
FUDForum. Page generated in 0.24570 seconds
