Home » Eclipse Projects » Equinox » Ignoring version incompatibilities
Ignoring version incompatibilities [message #72450] Wed, 23 August 2006 12:03 Go to next message
Originally posted by: joerg.von.frantzius.artnology.nospam.com
--------------000204010301080505030309
there has been some discussion going on about WTP 1.5 not being able to
run within Eclipse 3.3 because e.g. the Require-Bundle entry for
org.eclipse.wst.server.core lists
"org.eclipse.core.runtime;bundle-version="[3.2.0,3.3.0*)*", i.e. the
required version must be lower than 3.3.0.
Is it somehow possible to get OSGI to explicitly ignore such a version
incompatibility? There is bug 7381 "Update Manager should allow to
ignore configuration errors when installing new feature"
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=78381> asking for that,
but maybe there already exists some way to achieve the same and no-one
yet bothered to comment it on the bug?
For anyone else finding this a useful enhancement, please be so kind to
cast your vote on the bug. It's really a pity that WTP can't even be
tried on Eclipse 3.3.
J
Re: Ignoring version incompatibilities [message #72469 is a reply to message #72450] Wed, 23 August 2006 14:47 Go to previous messageGo to next message
Originally posted by: john.eclipsefaq.org
The check done by update manager is quite distinct from the OSGi
resolver that runs on startup. You would need both of these to have an
option to ignore warnings. I suggest entering a separate bug against
Equinox Framework for the OSGi case.
Joerg von Frantzius wrote:
> Jörg
Re: Ignoring version incompatibilities [message #72561 is a reply to message #72469] Thu, 24 August 2006 04:36 Go to previous message
OK, did that: https://bugs.eclipse.org/bugs/show_bug.cgi?id=155002
Thanks for the hint,
Jörg
> an option to ignore warnings. I suggest entering a separate bug
> against Equinox Framework for the OSGi case.
>> to run within Eclipse 3.3 because e.g. the Require-Bundle entry for
>> version incompatibility? There is bug 7381 "Update Manager should
>> allow to ignore configuration errors when installing new feature"
>> that, but maybe there already exists some way to achieve the same and
>> no-one yet bothered to comment it on the bug?
>> to cast your vote on the bug. It's really a pity that WTP can't even
>> be tried on Eclipse 3.3.
>> Thanks,
>> Jörg
Previous Topic:How to get files in bundle's classpath
Next Topic:Determine debug mode
Current Time: Mon Jul 21 21:17:23 EDT 2025
Powered by FUDForum. Page generated in 0.04436 seconds
