Home » Language IDEs » PHP Development Tools (PDT) » How to get rid of warnings in console?
How to get rid of warnings in console? [message #72448] Wed, 04 June 2008 03:22 Go to next message
I am developing components for Joomla! 1.5. Joomla! uses singleton
patterns extensively. That means that the objects have a static field in
which it stores a instance of itself. A getInstace() function makes this
own instance awailable globally.
PDT throws a warning for every occurance of this construct: "Debug
strict... - Non-static method JLoader::register() should not be called
statically"
For my development work it is really not of interest if that is a problem
or not (I think it is a quite modern design), but it is virtually
impossible to find my relevant debugging info in tons of (for me)
unnecessary info.
Can anybody tell me how to switch that off?
Thank you very much
Klaus
Re: How to get rid of warnings in console? [message #72483 is a reply to message #72448] Wed, 04 June 2008 06:18 Go to previous messageGo to next message
I've just opened an issue request about that:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=235559
For now, I can suggest you to use error_reporting(E_ERROR) somewhere in
the beginning of your code, so you will be notified only on real errors.
Thanks!
kkaal wrote:
> statically"
> problem or not (I think it is a quite modern design), but it is
> virtually impossible to find my relevant debugging info in tons of (for
> me) unnecessary info.
> Thank you very much
> Klaus
Re: How to get rid of warnings in console? [message #72921 is a reply to message #72448] Wed, 11 June 2008 13:31 Go to previous message
..oO(kkaal)
>statically"
It is bad design, in strict PHP mode I would even call it a bug. Static
methods should be marked as that.
But in case of Joomla! 1.5 a reason might be that it's still backwards-
compatible with PHP 4 (AFAIK, I don't use it).
>but it is virtually
>unnecessary info.
You could disable E_STRICT errors by changing error_reporting.
Micha
Re: How to get rid of warnings in console? [message #72939 is a reply to message #72483] Wed, 11 June 2008 13:31 Go to previous message
..oO(Michael Spector)
Bad idea. This would also suppress E_NOTICE errors, which are most
important while developing.
Micha
Previous Topic:utf-8
Next Topic:PDT and XDebug 2.0.3
Current Time: Sun Aug 31 18:21:11 EDT 2025
Powered by FUDForum. Page generated in 0.55483 seconds
