Home » Language IDEs » AspectJ » How to run automated PDE Build with AspectJ Support?
How to run automated PDE Build with AspectJ Support? [message #72442] Mon, 27 October 2008 10:44 Go to next message
I have one problem, please help me:
I have an eclipse RCP application wich I build automatically with PDE
Builder.
I have some Plugins with AspectJ.
PDE Builder starts with:
<target name="build" description="Build Eclipse Product">
<java
jar=" ${eclipse.home}/plugins/org.eclipse.equinox.launcher_1.0.100 .v20080509-1800.jar "
fork="true"
failonerror="true"
<arg line="-application org.eclipse.ant.core.antRunner "/>
<arg line="-buildfile ${pde.buildfile} "/>
<arg line="-Dbuilder=${pde.builder}/scripts "/>
</java>
</target>
and produces my Application. BUT Plugins with AspectJ are builded WITHOUT
AspectJ support!
I use Eclipse 3.4 and AspectJ Developer Tools 1.6.1, what can I do to add
AspectJ-Compiler to my PDE-Builder?
Many thanks,
Nikolai
Re: How to run automated PDE Build with AspectJ Support? [message #72461 is a reply to message #72442] Wed, 29 October 2008 14:33 Go to previous messageGo to next message
Unfortunately, this is not possible with ajdt as it is currently released.
Internally, however, we use a modified pde builder to do headless building
of AJDT on our build server. This modified builder is meant for internal
use only, but I can release it to you if this is something that you'd like
to try out.
If there is enough interest in this, I will consider releasing a version
of our headless pde builder to the public.
Re: How to run automated PDE Build with AspectJ Support? [message #72661 is a reply to message #72461] Tue, 11 November 2008 08:13 Go to previous messageGo to next message
,i'm interested, i have the same problem.
Greetings Sven
Re: How to run automated PDE Build with AspectJ Support? [message #72688 is a reply to message #72461] Tue, 11 November 2008 17:18 Go to previous messageGo to next message
The bug for keeping track of this enhancement can be found here. Feel
free to add your own comments.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=252641
However, be aware that the soonest this feature would come out would be
for AJDT 1.7 (Eclipse 3.5). It is unlikely to be back ported to Eclipse
3.2.
Re: How to run automated PDE Build with AspectJ Support? [message #72735 is a reply to message #72461] Mon, 17 November 2008 22:14 Go to previous messageGo to next message
I have the same problem. Could you please release your build script to me
too? My e-mail address is d95776@yahoo.com
thanks!
hao
Re: How to run automated PDE Build with AspectJ Support? [message #72745 is a reply to message #72735] Tue, 18 November 2008 00:35 Go to previous messageGo to next message
Please see bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=252641 for
instructions on how to run a headless AspectJ aware build.
Re: How to run automated PDE Build with AspectJ Support? [message #72747 is a reply to message #72442] Tue, 18 November 2008 02:37 Go to previous message
Nikolai Raitsev schrieb:
> Builder.
> <java
> fork="true"
> failonerror="true"
> </java> </target>
> WITHOUT AspectJ support!
> add AspectJ-Compiler to my PDE-Builder?
> Many thanks,
> Nikolai
I found an other solution - the CompilerAdapter
http://www.eclipse.org/aspectj/doc/released/devguide/antTask s-adapter.html
<java classname="org.eclipse.equinox.launcher.Main" fork="true" >
<jvmarg
value=" -Dbuild.compiler=org.aspectj.tools.ant.taskdefs.Ajc11Compile rAdapter "/>
</java>
It's neccesary, that your plugin does contain the AspectJ runtime
library (aspectjrt.jar)
Greetings
Sven
Re: How to run automated PDE Build with AspectJ Support? [message #599196 is a reply to message #72442] Wed, 29 October 2008 14:33 Go to previous message
to try out.
Re: How to run automated PDE Build with AspectJ Support? [message #599290 is a reply to message #72461] Tue, 11 November 2008 08:13 Go to previous message
Greetings Sven
Re: How to run automated PDE Build with AspectJ Support? [message #599307 is a reply to message #72461] Tue, 11 November 2008 17:18 Go to previous message
3.2.
Re: How to run automated PDE Build with AspectJ Support? [message #599340 is a reply to message #72461] Mon, 17 November 2008 22:14 Go to previous message
thanks!
hao
Re: How to run automated PDE Build with AspectJ Support? [message #599355 is a reply to message #72735] Tue, 18 November 2008 00:35 Go to previous message
Re: How to run automated PDE Build with AspectJ Support? [message #599361 is a reply to message #72442] Tue, 18 November 2008 02:37 Go to previous message
> Builder.
> <java
> fork="true"
> failonerror="true"
> </java> </target>
> Many thanks,
> Nikolai
<jvmarg
</java>
Greetings
Sven
Previous Topic:ProceedingJoinPoint can's handle boolean type
Next Topic:create update site with aj support
Current Time: Thu Jul 17 20:16:53 EDT 2025
Powered by FUDForum. Page generated in 0.33765 seconds
