Home » Archived » XML Schema Definition (XSD) » XSDSchema Loading
XSDSchema Loading [message #72401] Mon, 18 June 2007 17:44 Go to next message
Originally posted by: kemoon.tin.it
Does anybody know how to load an xml schema from a file with import and
include directives linking to other files?
I have tried this solutiom, but it still doesn't work.
String schemaURL =
"../xmLegesEditor/xsdData/NIR_XSD_completo/nirstrict.xsd";
public static XSDSchema loadSchemaUsingResourceSet(String schemaURL)
throws Exception{
XSDResourceFactoryImpl resourceFactory = new XSDResourceFactoryImpl();
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "xsd",resourceFactory);
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getURIConverter().getURIMap().put(URI.createURI( "./xlink.xsd"),URI.createURI(" file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/NIR _XSD_completo/xlink.xsd "));//,URI.createURI("./xlink.xsd"));
resourceSet.getURIConverter().getURIMap().put(URI.createURI( "./h.xsd"),URI.createURI(" file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/NIR _XSD_completo/h.xsd "));//,URI.createURI("./h.xsd")); resourceSet.getURIConverter().getURIMap().put(URI.createURI( "./dsp.xsd"),URI.createURI(" file:/home/tommaso/schemaWorkspace/xmLegesEditor/xsdData/NIR _XSD_completo/dsp.xsd "));//,URI.createURI("./dsp.xsd")); File
file = new File(schemaURL);
if (file.isFile())
schemaURL =
URI.createFileURI(file.getCanonicalFile().toString()).toStri ng();
resourceSet.getLoadOptions().put(XSDResourceImpl.XSD_TRACK_L OCATION,
Boolean.TRUE);
XSDResourceImpl xsdSchemaResource = null;
try
xsdSchemaResource =
(XSDResourceImpl)resourceSet.getResource(URI.createURI(schem aURL),true);
catch(Exception e)
System.err.println("Exception caught in method 'load schema using
ResourceSet' message = " + e.getMessage() + " xsdSchemaResource: " +
xsdSchemaResource);
for (Iterator resources =
resourceSet.getResources().iterator();resources.hasNext(); /* no-op */)
Resource resource = (Resource)resources.next();
if (resource instanceof XSDResourceImpl)
XSDResourceImpl xsdResource = (XSDResourceImpl)resource;
XSDSchema xsdSchema = xsdResource.getSchema();
for (Iterator contents = xsdSchema.getContents().iterator();
contents.hasNext(); )
XSDSchemaContent xsdSchemaContent =
(XSDSchemaContent)contents.next();
if (xsdSchemaContent instanceof XSDSchemaDirective)
XSDSchemaDirective xsdSchemaDirective =
(XSDSchemaDirective)xsdSchemaContent;
if (xsdSchemaDirective.getResolvedSchema() == null)
System.err.println("Unresolved schema "+
xsdSchemaDirective.getSchemaLocation() +" in " + xsdResource.getURI());
if(xsdSchemaDirective instanceof XSDImport)
XSDImport xsdSchemaImport = (XSDImport)xsdSchemaDirective;
XSDSchema resolvedSchema =
((XSDImportImpl)xsdSchemaImport).importSchema();
if(resolvedSchema != null)
System.err.println("-------> now
resolved");
xsdSchemaDirective.setResolvedSchema(resolvedSchema);
((XSDSchemaImpl)resolvedSchema).imported((XSDImport)xsdSchem aDirective);
else
System.err.println("Resolved schema "+
return xsdResource.getSchema();
System.err.println("loadSchemaUsingResourceSet(" + schemaURL + ") did
not contain any schemas!");
return null;
Re: XSDSchema Loading [message #72419 is a reply to message #72401] Mon, 18 June 2007 19:09 Go to previous message
Francesca,
If you run this under debug control (or add a print statement), what's
the value of schemaURL at the point when you call getResource? (As long
as you load using an absolute URI, all relative URIs should resolve
correctly to the same absolute URI they'd resolve to if you were loading
..html file in a browser.)
> and include directives linking to other files?
> String schemaURL =
> throws Exception{
> File file = new File(schemaURL);
> if (file.isFile())
> schemaURL =
> Boolean.TRUE);
> try
> xsdSchemaResource =
> catch(Exception e)
> xsdSchemaResource);
> { XSDSchemaDirective
> xsdSchemaDirective = (XSDSchemaDirective)xsdSchemaContent;
> resolved");
> } else {
> did not contain any schemas!");
> return null;
Re: XSDSchema Loading [message #602386 is a reply to message #72401] Mon, 18 June 2007 19:09 Go to previous message
Francesca,
> String schemaURL =
> throws Exception{
> if (file.isFile())
> schemaURL =
> Boolean.TRUE);
> try
> xsdSchemaResource =
> catch(Exception e)
> xsdSchemaResource);
> resolved");
> } else {
> return null;
Previous Topic:XSDSchema Loading
Next Topic:import resolution and namespaces
Current Time: Mon Jul 21 22:07:13 EDT 2025
Powered by FUDForum. Page generated in 0.28958 seconds
