MetaCoder RC2 plug-in available for download [message #6508] |
Thu, 11 July 2002 02:23  |
The MetaCoder Development Environment
o A Choice of Template Languages XSLT, Java / W3C interface, Java / JDom
o Syntax Highlighting Editors for XSL, XML
o Context Sensitive Code Assist in both the XML and XSLT editors
o Line Directed Error Checking
o Code Generated directly into a test environment for final validation
o Direct Database Meta Data to XML import using a built in XSLT extension
The Test Environment
o Execute Transforms to Console, Errors shown in Task List
o Generate multipule output files
o Auto Compile generated Java checking for compile time errors, Errors shown
in Task List
Deploy MetaCode
o Package the MetaCode as a Wizard that can be invoked from within your IDE
Download Plug-in / Documentation / Samples
http://metacoder.info
Re: MetaCoder RC2 plug-in available for download [message #6526 is a reply to message #6508] |
Thu, 11 July 2002 02:29   |
It's a really great project, thanks.
Eclipse lacks XML support, and it's very noisy - no coloring, no validation
etc, so maybe you can release XML/XSLT Eclipse support ( already released in
MetaCoder plugin) as a standalone plugin?
"Tayo" <tayo@btclick.com> wrote in message
news:agj6iv$uh4$1@rogue.oti.com...
shown
> in Task List
> Deploy MetaCode
IDE
Re: MetaCoder RC2 plug-in available for download [message #567510 is a reply to message #6508] |
shown
> in Task List
> Deploy MetaCode
IDE
FUDForum. Page generated in 0.07585 seconds
