Home » Archived » XML Schema Definition (XSD) » problems at pattern facet creation/validation
problems at pattern facet creation/validation [message #72111] Wed, 25 April 2007 05:02 Go to next message
Originally posted by: paradies.transit-online.de
I've used the wtp xsd schema editor for a long time and was always happy
with it but today I've noticed strange behaviour while editing and
validating a pattern facet:
First of all I found relevant differences in validation of regular
expressions between Regular Expression Wizard and XSD Schema Editor.
So what's going wrong?
Suppose I want to define an range of letters using their hex values e.g.
[\x40-\x42]+. Using the Regular Expression Wizard from the properties
view this expression is fine and testable. After finishing I'm going to
validate the schema (context menu in the source editor -> validate).
Then the validator reports the following error:
"InvalidRegex: Pattern value '[\x40-\x42]+' is not a valid regular
expression. The reported error was: 'This expression is not supported in
the current option setting.'."
I know this is reported by Xerces but I've found no way neither to show
nor to control the regex options. Is this a bug or am I doing something
wrong?
The second issue I'd noticed appears when I've edited the expression
with the wizard again. The value of the pattern node has changed but
also a value attribute to the type node is added as shown below.
- schema source fragment before editing:
<xsd:simpleType name="XSDSimpleType">
<xsd:restriction base="xsd:string">
<xsd:pattern
value="[0x40-0x42]+"></xsd:pattern>
</xsd:restriction>
</xsd:simpleType>
- schema source fragment after editing:
<xsd:simpleType name="XSDSimpleType" value="[\x40-\x43]+">
<xsd:pattern
value="[0x40-0x43]+"></xsd:pattern>
</xsd:restriction>
</xsd:simpleType>
Seems to be a buggy ...
Thomas
Re: problems at pattern facet creation/validation [message #72134 is a reply to message #72111] Wed, 25 April 2007 06:27 Go to previous messageGo to next message
Thomas,
Comments below.
Thomas Paradies wrote:
> happy with it but today I've noticed strange behaviour while editing
> and validating a pattern facet:
Note that the WTP schema editor is provided by the WTP project not
directly by the XSD project which just provides a crude sample editor.
So I've added the webtools newsgroup to the "to" list so they will see
your question and answer it.
> e.g. [\x40-\x42]+. Using the Regular Expression Wizard from the
> properties view this expression is fine and testable. After finishing
> I'm going to validate the schema (context menu in the source editor ->
> validate). Then the validator reports the following error:
Unfortunately I don't know anything about the regular expression
wizard. Hopefully it's not just a wizard for editing Java regular
expressions which have a different syntax than XML Schema's regular
expressions.
> in the current option setting.'."
I can't see anything in the specification that allows for \x escaping.
> show nor to control the regex options. Is this a bug or am I doing
> something wrong?
Well, it doesn't look right to me. I think Xerces regular expression
code is general enough to support different options, but for XML Schema
purposes it has to use the XML Schema option and I don't think your
expression is right according to that.
> <xsd:pattern
> </xsd:restriction>
> </xsd:simpleType>
> <xsd:pattern
> </xsd:restriction>
> </xsd:simpleType>
It's certainly not correct. But I can't reproduce it with the sample
editor so I don't think it's a problem in the XSD model itself.
> Thomas
Re: problems at pattern facet creation/validation [message #72149 is a reply to message #72134] Wed, 25 April 2007 08:23 Go to previous message
Ed,
thank you for your prompt response. See below ...
> Thomas,
> Comments below.
Sorry, that was not obvious to me. Thanks for the hint.
> expressions.
I'm afraid yes, but we'll see ...
You're right it's Perl-like but I found it also for Xerces (see
http://xerces.apache.org/xerces-j/apiDocs/org/apache/xerces/ utils/regex/RegularExpression.html)
>> something wrong?
Well, then should the expression [#x40-#x43]+ do it, right? The
validation reports
"InvalidRegex: Pattern value '[#x40-#x43]+' is not a valid regular
expression. The reported error was: 'The range end code point is less
than the start code point.'"
Strange! But the expression without range [#x40#x43]+ is correct. Also
with the sample editor...
>> <xsd:pattern
>> </xsd:restriction>
>> </xsd:simpleType>
>> <xsd:pattern
>> </xsd:restriction>
>> </xsd:simpleType>
I agree.
>> Thomas
Re: problems at pattern facet creation/validation [message #602313 is a reply to message #72111] Wed, 25 April 2007 06:27 Go to previous message
Thomas,
Comments below.
expressions.
> something wrong?
> <xsd:pattern
> </xsd:restriction>
> </xsd:simpleType>
> <xsd:pattern
> </xsd:restriction>
> </xsd:simpleType>
> Thomas
Re: problems at pattern facet creation/validation [message #602318 is a reply to message #72134] Wed, 25 April 2007 08:23 Go to previous message
Ed,
> Thomas,
> Comments below.
> expressions.
>> something wrong?
validation reports
>> <xsd:pattern
>> </xsd:restriction>
>> </xsd:simpleType>
>> <xsd:pattern
>> </xsd:restriction>
>> </xsd:simpleType>
I agree.
>> Thomas
Previous Topic:problems at pattern facet creation/validation
Next Topic:Schema Merging
Current Time: Fri Jul 18 22:40:38 EDT 2025
Powered by FUDForum. Page generated in 0.04208 seconds
