Home » Archived » M2M (model-to-model transformation) » Problem with transformation DSM2UML
Problem with transformation DSM2UML [message #72109] Wed, 16 January 2008 09:55 Go to next message
Originally posted by: amivi.fagbegnon.gmail.com
I have a problem to assign types to a UML Property. In fact I have a
model XMI conforms to meta model and I try to convert it into UML Model
(class diagram).
Thx
Re: Problem with transformation DSM2UML [message #72132 is a reply to message #72109] Wed, 16 January 2008 10:52 Go to previous messageGo to next message
Originally posted by: quentin.glineur.obeo.fr
--------------050603050005010504000308
fagbegnon a
[ATL] Problem with transformation DSM2UML: UML type assignment [message #73138 is a reply to message #72132] Wed, 23 January 2008 05:25 Go to previous message
ok,
I have a model xmi conforms to an ecore meta model. The meta model
define an enumeration types TYPE(varchar,char,time, nulmeric, float...).
I want to generate (with ATL Transformation) a UML class diagram
matching the xmi model. I have dificulties to match these
types(enumliteral) with UML primmitive types.
Indeed I want to have:
- a helper which gives UML!PrimitiveType according to the type of the
element in xmi model (char, int,varchar...);
- the correct method or instruction ATL that assign the type computed to
a UML property.
I hope that it's more clear...
Amivi
Quentin Glineur a écrit :
> fagbegnon a écrit :
>> Hello,
>> Model (class diagram).
>> Thx
> Can you be a little more specific on your problem (about you
> configuration, the way you are trying to make your conversion, etc) ?
> Quentin
Previous Topic:[ATL] Duplicates in my list
Next Topic:[QVTO] Implicit source vs contextless invocation
Current Time: Thu Jul 17 22:31:44 EDT 2025
Powered by FUDForum. Page generated in 0.03466 seconds
