Home » Archived » Test and Performance Tools Platform (TPTP) » Slow profiling of Java application
Slow profiling of Java application [message #72046] Mon, 29 May 2006 04:53 Go to next message
Originally posted by: eygelaar.sun.ac.za
I am busy developing a Java application for my MScEng thesis. Solving a
simple problem without the profiler takes about +/- 1 or 2 seconds. But,
profiling the application takes a really long time. After 5 minutes I stop
the profiler. I am puzzled why profiling the application takes such a long
time.
I am using the standard "Execution History - Statistical" profiling set,
Eclipse 3.1.2, TPTP 4.1.0.1, ThinkPad T42, 1gig RAM.
Any help will be welcome.
Anton
Re: Slow profiling of Java application [message #72255 is a reply to message #72046] Tue, 30 May 2006 10:28 Go to previous message
Originally posted by: nmehrega.ca.ibm.com
This is a multipart message in MIME format.
--=_alternative 004F813E8525717E_=
Content-Type: text/plain; charset="US-ASCII"
Here are some suggestions on how you can speed up the profiler:
1) If you're using IAC (i.e. Local Direct Connection), try using the Agent
Controller instead
2) Selecting fewer profiling options will make things faster. Try
avoiding the graphical details option and the collection of instance level
information if possible.
3) The most important thing is to make sure you have your filters set up
properly. In your launch configuration -> click on 'Profiling' -> Select
your profiling set -> 'Edit' -> 'Next' -> 'Next' -> Set your filter set.
Try to exclude everything you're not interested in. This is the filterset
I usually use:
Class Method Mode
org.mypackage* * INCLUDE <--
Include everything in my package
EXCLUDE <-- Exclude everything else
4) If it's still too slow, try profiling to a file: -> in the 'Profiling'
tab of your launch configuration -> click on the 'Destination' tab ->
'Send profiling data to a file'. You can later import the profiling file
by going to File -> Import
Navid Mehregani
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Here are some suggestions on how you
can speed up the profiler:</font>
<br>
<br><font size=2 face="sans-serif">1) If you're using IAC (i.e. Local Direct
Connection), try using the Agent Controller instead</font><font size=3>
</font><font size=2 face="sans-serif"><br>
2) Selecting fewer profiling options will make things faster. &nbsp;Try
information if possible.<br>
properly. &nbsp;In your launch configuration -&gt; click on 'Profiling'
-&gt; Select your profiling set -&gt; 'Edit' -&gt; 'Next' -&gt; 'Next'
-&gt; Set your filter set. &nbsp;Try to exclude everything you're not interested
in.</font><font size=3> </font><font size=2 face="sans-serif">This is the
filterset I usually use:</font><font size=3> </font><font size=2 face="sans-serif"><br>
Class &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Method &nbsp; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp;Mode</font><font size=3> </font><font size=2 face="sans-serif"><br>
org.mypackage* &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;
&nbsp; * &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;
&nbsp; INCLUDE &nbsp; &nbsp; &nbsp;&lt;-- &nbsp;Include everything in my
package</font><font size=3> </font><font size=2 face="sans-serif"><br>
* &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; * &nbsp; &nbsp; &nbsp; &nbsp; &nbsp; &nbsp;
&nbsp; &nbsp; &nbsp; &nbsp; EXCLUDE &nbsp; &nbsp; &lt;-- Exclude everything
else</font><font size=3> </font><font size=2 face="sans-serif"><br>
<br>
4) If it's still too slow, try profiling to a file: -&gt; in the 'Profiling'
tab of your launch configuration -&gt; click on the 'Destination' tab -&gt;
'Send profiling data to a file'. &nbsp;You can later import the profiling
&nbsp;file by going to File -&gt; Import</font><font size=3> </font>
<br>
<br><font size=2 face="sans-serif">Navid Mehregani</font>
--=_alternative 004F813E8525717E_=--
Previous Topic:Error into Sample Birt Report
Next Topic:The Open Group Application Response Measurement
Current Time: Sat Jul 12 23:50:07 EDT 2025
Powered by FUDForum. Page generated in 0.04259 seconds
