RCP Application LTW problem [message #72006] |
Mon, 21 July 2008 21:02 |
Originally posted by: burt.leung.gmail.com
Hi All,
I'm having problems getting the load-time weaving working on the RCP
Application project I'm working on.
To try to figure out what could be going wrong, I tried creating a simple
RCP application using the "Hello RCP" template/wizard via the Eclipse IDE.
So I've done the following so far:
1. Created a target platform based on RCP 3.4.
2. Added the following plugins to the target platform:
* org.aspectj.runtime_1.6.1.20080703120000
* org.aspectj.weaver_1.6.1.20080703120000
* org.eclipse.equinox.weaving.aspectj_1.0.0.200807082136
* org.eclipse.equinox.weaving.caching.j9_1.0.0.200807082136
* org.eclipse.equinox.weaving.caching_1.0.0.200807082136
* org.eclipse.equinox.weaving.hook_1.0.0.200807082136
3. Created the Hello RCP sample application. Created a .product file to
use to run the application.
2. Created a META-INF/aop.xml file that used the one aspect defined in the
sample RCP application.
3. Set the VM arg
" -javaagent:F:\hello3.4Workspace\target.3.4\plugins/org.aspec tj.weaver_1.6.1.20080703120000/aspectjweaver.jar "
If I run the application the output gives:
osgi> [DefaultClassLoader@331059] info AspectJ Weaver Version 1.6.1rc1 built
on Thursday Jul 3, 2008 at 20:33:51 GMT
[DefaultClassLoader@331059] info register classloader
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader@331059
[DefaultClassLoader@331059] info using configuration /META-INF/aop.xml
[DefaultClassLoader@331059] info register aspect aspects.HelloAspect
Jul 21, 2008 10:13:03 AM org.aspectj.weaver.tools.Jdk14Trace error
SEVERE: experiment2/Application
java.lang.NoClassDefFoundError: org/aspectj/lang/reflect/CodeSignature
org.aspectj.weaver.patterns.KindedPointcut.read(KindedPointc ut.java:245)
at org.aspectj.weaver.patterns.Pointcut.read(Pointcut.java:286)
org.aspectj.weaver.patterns.CflowPointcut.read(CflowPointcut .java:103)
at org.aspectj.weaver.patterns.Pointcut.read(Pointcut.java:295)
at org.aspectj.weaver.patterns.AndPointcut.read(AndPointcut.jav a:87)
at org.aspectj.weaver.patterns.Pointcut.read(Pointcut.java:290)
org.aspectj.weaver.AjAttribute$AdviceAttribute.read(AjAttrib ute.java:490)
at org.aspectj.weaver.AjAttribute.read(AjAttribute.java:101)
org.aspectj.weaver.bcel.BcelAttributes.readAjAttributes(Bcel Attributes.java:106)
org.aspectj.weaver.bcel.BcelMethod.unpackAjAttributes(BcelMe thod.java:191)
at org.aspectj.weaver.bcel.BcelMethod.<init>(BcelMethod.java:104)
org.aspectj.weaver.bcel.BcelObjectType.getDeclaredMethods(Bc elObjectType.java:248)
org.aspectj.weaver.ReferenceType.getDeclaredMethods(Referenc eType.java:524)
org.aspectj.weaver.ResolvedType.getDeclaredAdvice(ResolvedTy pe.java:748)
org.aspectj.weaver.ResolvedType.getDeclaredShadowMungers(Res olvedType.java:785)
org.aspectj.weaver.ResolvedType.collectShadowMungers(Resolve dType.java:626)
org.aspectj.weaver.ResolvedType.collectCrosscuttingMembers(R esolvedType.java:518)
org.aspectj.weaver.CrosscuttingMembersSet.addOrReplaceAspect (CrosscuttingMembersSet.java:78)
org.aspectj.weaver.CrosscuttingMembersSet.addOrReplaceAspect (CrosscuttingMembersSet.java:65)
org.aspectj.weaver.bcel.BcelWeaver.addLibraryAspect(BcelWeav er.java:203)
org.aspectj.weaver.loadtime.ClassLoaderWeavingAdaptor.regist erAspects(ClassLoaderWeavingAdaptor.java:398)
org.aspectj.weaver.loadtime.ClassLoaderWeavingAdaptor.regist erDefinitions(ClassLoaderWeavingAdaptor.java:239)
org.aspectj.weaver.loadtime.ClassLoaderWeavingAdaptor.initia lize(ClassLoaderWeavingAdaptor.java:151)
org.aspectj.weaver.loadtime.Aj$ExplicitlyInitializedClassLoa derWeavingAdaptor.initialize(Aj.java:262)
org.aspectj.weaver.loadtime.Aj$ExplicitlyInitializedClassLoa derWeavingAdaptor.getWeavingAdaptor(Aj.java:267)
org.aspectj.weaver.loadtime.Aj$WeaverContainer.getWeaver(Aj. java:245)
at org.aspectj.weaver.loadtime.Aj.preProcess(Aj.java:86)
org.aspectj.weaver.loadtime.ClassPreProcessorAgentAdapter.tr ansform(ClassPreProcessorAgentAdapter.java:52)
sun.instrument.TransformerManager.transform(TransformerManag er.java:122)
sun.instrument.InstrumentationImpl.transform(Instrumentation Impl.java:155)
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:165)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:554)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:524)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:455)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:443)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:423)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:188)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
Jul 21, 2008 10:13:03 AM org.aspectj.weaver.tools.Jdk14Trace info
INFO: Dumping to F:\eclipse3.4\.\ajcore.20080721.101303.562.txt
I confirmed that the class org.aspectj.lang.reflect.CodeSignature is in
the target platform though (via the aspectrt.jar file), so it is puzzling.
In addition, I then tried to debug the application by setting a breakpoint
to stop at any Exception that occurs. The debuggers first break is at:
Thread [main] (Suspended (exception ClassNotFoundException))
ClassLoader.findBootstrapClass(String) line: not available [native
method] [local variables unavailable]
Launcher$ExtClassLoader(ClassLoader).findBootstrapClass0(Str ing) line:
891
Launcher$ExtClassLoader(ClassLoader).loadClass(String, boolean) line:
301
Launcher$AppClassLoader(ClassLoader).loadClass(String, boolean) line:
299
Launcher$AppClassLoader.loadClass(String, boolean) line: 268
Launcher$AppClassLoader(ClassLoader).loadClass(String) line: 251
InstrumentationImpl.loadClassAndCallPremain(String, String) line: 133
The class it can't find is given to be
"org.aspectj.weaver.loadtime.Agent". I checked and this class is also in
the target platform (via the aspectjweaver.jar file) so I'm puzzled by
this.
I made sure that the product has the right dependencies set too. E.g. The
"org.aspectj.runtime" and "org.aspectj.weaver" plugins are depended on.
Any help would be appreciated, thanks.
Burt
FUDForum. Page generated in 0.44891 seconds
