Home » Eclipse Projects » Remote Application Platform (RAP) » Inconsistent Id Generated on HTML Component
Inconsistent Id Generated on HTML Component [message #71991] Mon, 28 January 2008 23:50 Go to next message
Hi all,
The 1st time when running RAP with UI Test parameter enabled I notice that
the id generated starts from 'w3', but the next run it starts from 'w2',
this make it hard to write consistent components identification by their
Id's. Is there any reason why the Id does not consistently starts from
'w1' ?
Best Regards,
Setya
Re: Inconsistent Id Generated on HTML Component [message #72156 is a reply to message #71991] Tue, 29 January 2008 18:27 Go to previous messageGo to next message
Originally posted by: rsternberg.innoopract.com
Hi Setya,
> 'w1' ?
Yes there is, "w1" is reserved for the Display, "w2" is used by a label for
the text size determination, which does not always run (since measured text
sizes are cached).
However, you should never rely on these ids, rather assign unique ids of
your own to the tested widgets like this:
widget.setData( WidgetUtil.CUSTOM_WIDGET_ID, "myTestId-1" );
See Javadoc on WidgetUtil.CUSTOM_WIDGET_ID and the discussion on
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204859
Best Regards, Ralf
Re: Inconsistent Id Generated on HTML Component [message #72188 is a reply to message #72156] Tue, 29 January 2008 23:07 Go to previous message
Ralf,
> sizes are cached).
Thanks for your clarification.
I'm aware of the capability to assign custom unique id, but as I
understand I can only do this on components that I myself render.
What if I need to click menus of coolbar buttons, asserting that certain
views/editors open, shouldn't I rely on this these ids ? Or is there any
way to assign custom id to these components ?
Best Regards,
Setya
Previous Topic:Progress for CellEditors?
Next Topic:Context menus for TableHeaders
Current Time: Sun Aug 31 18:21:17 EDT 2025
Powered by FUDForum. Page generated in 0.10022 seconds
