Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [TENEO] stackoverflow when saving a copied resource
[TENEO] stackoverflow when saving a copied resource [message #71985] |
Fri, 16 February 2007 12:35  |
I am trying to take an XMI resource, copy it, add it to a teneo resource,
then save the new teneo resource.
I am able to create the teneo resource, load the XMI resource, do the copy
of the resource with the EMF utility methods, and then add the new copy of
the resource to the teneo resource. However, when I go to save the teneo
resorce the process runs for a very long time and then finally throws an
error and exits. The error log contains the following...
java.lang.StackOverflowError
at java.nio.CharBuffer.<init>(Unknown Source)
at java.nio.HeapCharBuffer.<init>(Unknown Source)
at java.nio.CharBuffer.wrap(Unknown Source)
at sun.nio.cs.StreamEncoder$CharsetSE.implWrite(Unknown Source)
at sun.nio.cs.StreamEncoder.write(Unknown Source)
at java.io.OutputStreamWriter.write(Unknown Source)
at java.io.Writer.write(Unknown Source)
org.apache.log4j.helpers.CountingQuietWriter.write(CountingQ uietWriter.java:36)
at org.apache.log4j.WriterAppender.subAppend(WriterAppender.jav a:292)
org.apache.log4j.RollingFileAppender.subAppend(RollingFileAp pender.java:225)
at org.apache.log4j.WriterAppender.append(WriterAppender.java:1 50)
at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton. java:221)
org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOn Appenders(AppenderAttachableImpl.java:57)
at org.apache.log4j.Category.callAppenders(Category.java:187)
at org.apache.log4j.Category.forcedLog(Category.java:372)
at org.apache.log4j.Category.log(Category.java:864)
at org.apache.commons.logging.impl.Log4JLogger.debug(Log4JLogge r.java:110)
org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rCacheHandler.getID(IdentifierCacheHandler.java:63)
org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer.getIden tifier(EMFTuplizer.java:65)
org.hibernate.persister.entity.AbstractEntityPersister.getId entifier(AbstractEntityPersister.java:3539)
org.hibernate.persister.entity.AbstractEntityPersister.isTra nsient(AbstractEntityPersister.java:3255)
at org.hibernate.engine.ForeignKeys.isTransient(ForeignKeys.jav a:181)
org.hibernate.event.def.AbstractSaveEventListener.getEntityS tate(AbstractSaveEventListener.java:487)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:84)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.onS aveOrUpdate(DefaultSaveOrUpdateEventListener.java:70)
at org.hibernate.impl.SessionImpl.fireSaveOrUpdate(SessionImpl. java:507)
at org.hibernate.impl.SessionImpl.saveOrUpdate(SessionImpl.java :499)
org.hibernate.engine.CascadingAction$1.cascade(CascadingActi on.java:218)
at org.hibernate.engine.Cascade.cascadeToOne(Cascade.java:268)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :216)
at org.hibernate.engine.Cascade.cascadeProperty(Cascade.java:16 9)
org.hibernate.engine.Cascade.cascadeCollectionElements(Casca de.java:296)
at org.hibernate.engine.Cascade.cascadeCollection(Cascade.java: 242)
at org.hibernate.engine.Cascade.cascadeAssociation(Cascade.java :219)
at org.hibernate.engine.Cascade.cascade(Cascade.java:130)
org.hibernate.event.def.AbstractSaveEventListener.cascadeAft erSave(AbstractSaveEventListener.java:437)
org.hibernate.event.def.AbstractSaveEventListener.performSav eOrReplicate(AbstractSaveEventListener.java:326)
org.hibernate.event.def.AbstractSaveEventListener.performSav e(AbstractSaveEventListener.java:180)
org.hibernate.event.def.AbstractSaveEventListener.saveWithGe neratedId(AbstractSaveEventListener.java:108)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.sav eWithGeneratedOrRequestedId(DefaultSaveOrUpdateEventListener .java:186)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.ent ityIsTransient(DefaultSaveOrUpdateEventListener.java:175)
org.hibernate.event.def.DefaultSaveOrUpdateEventListener.per formSaveOrUpdate(DefaultSaveOrUpdateEventListener.java:98)
Re: [TENEO] stackoverflow when saving a copied resource [message #72004 is a reply to message #71985] |
Fri, 16 February 2007 12:48   |
Mark,
How large is the xmi? When you save the copy to xmi that works fine?
Can you reproduce it for a small set of data?
gr. Martin
> resource, then save the new teneo resource.
> copy of the resource with the EMF utility methods, and then add the new
> copy of the resource to the teneo resource. However, when I go to save
> the teneo resorce the process runs for a very long time and then finally
> throws an error and exits. The error log contains the following...
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [TENEO] stackoverflow when saving a copied resource [message #72023 is a reply to message #72004] |
Fri, 16 February 2007 13:00   |
The XMI file is 4.5M. I will try to save a smaller amount of data...
I have also attached the end of the console log for you.
15-Feb-2007 14:16:11,710 [DEBUG]
org.eclipse.emf.teneo.hibernate.mapping.property.EListProper tyHandler: Set
value java.util.ArrayList for target srd.impl.OrganizationImpl field
contacts
services
namedEquipment
org.hibernate.event.def.AbstractSaveEventListener: executing
identity-insert immediately
org.hibernate.persister.entity.AbstractEntityPersister: Inserting entity:
Organization (native id)
org.hibernate.persister.entity.AbstractEntityPersister: Version: 0
15-Feb-2007 14:16:11,710 [DEBUG] org.hibernate.jdbc.AbstractBatcher: about
to open PreparedStatement (open PreparedStatements: 0, globally: 0)
15-Feb-2007 14:16:11,710 [DEBUG] org.hibernate.SQL: insert into
`organization` (e_version, `name`, `dtype`) values (?, ?, 'Organization')
preparing statement
15-Feb-2007 14:16:11,750 [DEBUG]
org.hibernate.persister.entity.AbstractEntityPersister: Dehydrating
entity: [Organization#<null>]
15-Feb-2007 14:16:11,750 [DEBUG] org.hibernate.type.IntegerType: binding
'0' to parameter: 1
15-Feb-2007 14:16:11,750 [DEBUG] org.hibernate.type.StringType: binding
'GLVSN (GALAVISION)' to parameter: 2
15-Feb-2007 14:16:11,870 [DEBUG]
org.hibernate.id.IdentifierGeneratorFactory: Natively generated identity:
22
15-Feb-2007 14:16:11,870 [DEBUG] org.hibernate.jdbc.AbstractBatcher: about
to close PreparedStatement (open PreparedStatements: 1, globally: 1)
15-Feb-2007 14:16:12,842 [DEBUG] org.hibernate.jdbc.AbstractBatcher:
closing statement
org.eclipse.emf.teneo.hibernate.mapping.identifier.Identifie rCacheHandler:
Setting id: 22 for object srd.impl.OrganizationImpl in idcache
15-Feb-2007 14:16:12,842 [DEBUG] org.hibernate.engine.Cascade: processing
cascade ACTION_SAVE_UPDATE for: Organization
15-Feb-2007 14:16:12,842 [DEBUG] org.hibernate.engine.Cascade: cascade
ACTION_SAVE_UPDATE for collection: Organization.contacts
15-Feb-2007 14:16:12,842 [DEBUG] org.hibernate.engine.CascadingAction:
cascading to saveOrUpdate: Contact
ID for object srd.impl.ContactImpl not found in id cache
org.hibernate.event.def.AbstractSaveEventListener: transient instance of:
Contact
org.hibernate.event.def.DefaultSaveOrUpdateEventListener: saving transient
instance
org.hibernate.event.def.AbstractSaveEventListener: saving [Contact#<null>]
org.hibernate.event.def.AbstractSaveEventListener: executing insertions
cascade ACTION_SAVE_UPDATE for: Contact
org.eclipse.emf.teneo.mapping.elist.PersistableEList: Created persistable
list EList of type:
org.eclipse.emf.teneo.hibernate.mapping.elist.HibernatePersi stableEList of
member physicalAddresses owned by srd.impl.ContactImpl with delegate list
java.util.ArrayList
list EList of type:
member phoneNumbers owned by srd.impl.ContactImpl with delegate list
java.util.ArrayList
list EList of type:
member emailAddresses owned by srd.impl.ContactImpl with delegate list
java.util.ArrayList
list EList of type:
member authInfo owned by srd.impl.ContactImpl with delegate list
java.util.ArrayList
list EList of type:
member urlAddresses owned by srd.impl.ContactImpl with delegate list
java.util.ArrayList
list EList of type:
member ipAddresses owned by srd.impl.ContactImpl with delegate list
java.util.ArrayList
list EList of type:
member services owned by srd.impl.ContactImpl with delegate list
java.util.ArrayList
list EList of type:
member namedEquipment owned by srd.impl.ContactImpl with delegate list
java.util.ArrayList
cascading to saveOrUpdate: Organization
org.hibernate.event.def.AbstractSaveEventListener: persistent instance of:
Organization
org.hibernate.event.def.DefaultSaveOrUpdateEventListener: ignoring
persistent instance
org.hibernate.event.def.DefaultSaveOrUpdateEventListener: object already
associated with session: [Organization#22]
15-Feb-2007 14:16:12,842 [DEBUG] org.hibernate.engine.Cascade: done
processing cascade ACTION_SAVE_UPDATE for: Contact
15-Feb-2007 14:16:12,842 [DEBUG] org.hibernate.engine.Versioning: Seeding:
0
Setting version: 0 for object srd.impl.ContactImpl in idcache
value java.util.ArrayList for target srd.impl.ContactImpl field
physicalAddresses
phoneNumbers
emailAddresses
value java.util.ArrayList for target srd.impl.ContactImpl field authInfo
urlAddresses
value java.util.ArrayList for target srd.impl.ContactImpl field ipAddresses
value java.util.ArrayList for target srd.impl.ContactImpl field services
namedEquipment
Contact (native id)
15-Feb-2007 14:16:12,842 [DEBUG] org.hibernate.jdbc.AbstractBatcher: about
15-Feb-2007 14:16:12,842 [DEBUG] org.hibernate.SQL: insert into `contact`
(e_version, `description`, `firstname`, `lastname`, `middlename`,
`nickname`, `callorder`, `dtype`) values (?, ?, ?, ?, ?, ?, ?, 'Contact')
preparing statement
15-Feb-2007 14:16:12,882 [DEBUG]
entity: [Contact#<null>]
15-Feb-2007 14:16:12,882 [DEBUG] org.hibernate.type.IntegerType: binding
'0' to parameter: 1
15-Feb-2007 14:16:12,882 [DEBUG] org.hibernate.type.StringType: binding
'24 HOUR' to parameter: 2
15-Feb-2007 14:16:12,882 [DEBUG] org.hibernate.type.StringType: binding '
' to parameter: 3
' to parameter: 4
' to parameter: 5
15-Feb-2007 14:16:13,983 [DEBUG] org.hibernate.type.StringType: binding
null to parameter: 6
null to parameter: 7
15-Feb-2007 14:16:14,033 [DEBUG]
59
15-Feb-2007 14:16:14,033 [DEBUG] org.hibernate.jdbc.AbstractBatcher: about
closing statement
Setting id: 59 for object srd.impl.ContactImpl in idcache
15-Feb-2007 14:16:15,155 [DEBUG] org.hibernate.engine.Cascade: processing
15-Feb-2007 14:16:15,155 [DEBUG] org.hibernate.engine.Cascade: cascade
ACTION_SAVE_UPDATE for collection: Contact.physicalAddresses
15-Feb-2007 14:16:15,155 [DEBUG] org.hibernate.engine.Cascade: done
cascade ACTION_SAVE_UPDATE for collection: Contact.physicalAddresses
ACTION_SAVE_UPDATE for collection: Contact.phoneNumbers
15-Feb-2007 14:16:15,155 [DEBUG] org.hibernate.engine.CascadingAction:
cascading to saveOrUpdate: PhoneNumber
org.hibernate.transaction.JDBCTransaction: rollback
15-Feb-2007 14:16:15,626 [DEBUG]
org.hibernate.transaction.JDBCTransaction: rolled back JDBC Connection
15-Feb-2007 14:16:15,626 [DEBUG] org.hibernate.jdbc.JDBCContext: after
transaction completion
15-Feb-2007 14:16:15,626 [DEBUG] org.hibernate.jdbc.ConnectionManager:
aggressively releasing JDBC connection
releasing JDBC connection [ (open PreparedStatements: 0, globally: 0)
(open ResultSets: 0, globally: 0)]
org.hibernate.connection.DriverManagerConnectionProvider: returning
connection to pool, pool size: 1
15-Feb-2007 14:16:16,287 [DEBUG] org.hibernate.impl.SessionImpl: after
15-Feb-2007 14:16:16,287 [DEBUG] org.hibernate.impl.SessionImpl: closing
session
15-Feb-2007 14:16:16,287 [DEBUG] org.hibernate.jdbc.ConnectionManager:
connection already null in cleanup : no action
Re: [TENEO] stackoverflow when saving a copied resource [message #72061 is a reply to message #72023] |
Fri, 16 February 2007 14:03   |
Could it be a java stack size issue? It is maybe easier to set the java stack size to a higher value
and test that.
gr. Martin
> Set value java.util.ArrayList for target srd.impl.OrganizationImpl field
> contacts
> services
> namedEquipment
> entity: Organization (native id)
> about to open PreparedStatement (open PreparedStatements: 0, globally: 0)
> preparing statement
> '0' to parameter: 1
> identity: 22
> about to close PreparedStatement (open PreparedStatements: 1, globally: 1)
> closing statement
> processing cascade ACTION_SAVE_UPDATE for: Organization
> of: Contact
> transient instance
> persistable list EList of type:
> of member physicalAddresses owned by srd.impl.ContactImpl with delegate
> list java.util.ArrayList
> of member phoneNumbers owned by srd.impl.ContactImpl with delegate list
> java.util.ArrayList
> of member emailAddresses owned by srd.impl.ContactImpl with delegate
> of member authInfo owned by srd.impl.ContactImpl with delegate list
> java.util.ArrayList
> of member urlAddresses owned by srd.impl.ContactImpl with delegate list
> java.util.ArrayList
> of member ipAddresses owned by srd.impl.ContactImpl with delegate list
> java.util.ArrayList
> of member services owned by srd.impl.ContactImpl with delegate list
> java.util.ArrayList
> of member namedEquipment owned by srd.impl.ContactImpl with delegate
> of: Organization
> persistent instance
> Seeding: 0
> Set value java.util.ArrayList for target srd.impl.ContactImpl field
> physicalAddresses
> phoneNumbers
> emailAddresses
> authInfo
> urlAddresses
> ipAddresses
> services
> namedEquipment
> entity: Contact (native id)
> `contact` (e_version, `description`, `firstname`, `lastname`,
> `middlename`, `nickname`, `callorder`, `dtype`) values (?, ?, ?, ?, ?,
> ?, ?, 'Contact')
> preparing statement
> '0' to parameter: 1
> ' ' to parameter: 3
> ' ' to parameter: 4
> ' ' to parameter: 5
> identity: 59
> closing statement
> Setting id: 59 for object srd.impl.ContactImpl in idcache 15-Feb-2007
> 14:16:15,155 [DEBUG] org.hibernate.engine.Cascade: processing cascade
> session
The Netherlands
Re: [TENEO] stackoverflow when saving a copied resource [message #602687 is a reply to message #71985] |
Mark,
gr. Martin
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: [TENEO] stackoverflow when saving a copied resource [message #602693 is a reply to message #72004] |
contacts
services
namedEquipment
preparing statement
'0' to parameter: 1
22
closing statement
Contact
instance
list EList of type:
java.util.ArrayList
list EList of type:
java.util.ArrayList
list EList of type:
java.util.ArrayList
list EList of type:
java.util.ArrayList
list EList of type:
java.util.ArrayList
list EList of type:
java.util.ArrayList
list EList of type:
java.util.ArrayList
list EList of type:
java.util.ArrayList
Organization
persistent instance
0
physicalAddresses
phoneNumbers
emailAddresses
urlAddresses
namedEquipment
Contact (native id)
preparing statement
'0' to parameter: 1
' to parameter: 3
' to parameter: 4
' to parameter: 5
59
closing statement
session
Re: [TENEO] stackoverflow when saving a copied resource [message #602703 is a reply to message #72023] |
and test that.
gr. Martin
> contacts
> services
> namedEquipment
> preparing statement
> '0' to parameter: 1
> identity: 22
> closing statement
> of: Contact
> transient instance
> java.util.ArrayList
> java.util.ArrayList
> java.util.ArrayList
> java.util.ArrayList
> java.util.ArrayList
> of: Organization
> persistent instance
> Seeding: 0
> physicalAddresses
> phoneNumbers
> emailAddresses
> authInfo
> urlAddresses
> ipAddresses
> services
> namedEquipment
> ?, ?, 'Contact')
> preparing statement
> '0' to parameter: 1
> ' ' to parameter: 3
> ' ' to parameter: 4
> ' ' to parameter: 5
> identity: 59
> closing statement
> session
The Netherlands
Re: [TENEO] stackoverflow when saving a copied resource [message #602716 is a reply to message #72004] |
Fri, 16 February 2007 16:11  |
I can create an empty teneo resource, then create objects and save...that
seems to work fine.
I don't know how to replicate the actions during the copy of the XMI
resource without saving the entire resource.
When the save is done is that a single transaction...is it possible to
tell hibernate/teneo to save in smaller, multiple transactions.??
Mark.
Re: [TENEO] stackoverflow when saving a copied resource [message #602752 is a reply to message #72119] |
Fri, 16 February 2007 23:59  |
It depends on your data, when you save one object and commit then it will automatically also save
all the related objects. So if there are many relations then the save of one object will result in
the save of the complete resource.
Instead of copying the xmi resource into a teneo resource you can also save the objects from the
XMIresource directly in the database. For example by iterating through the root objects in the xmi
resource and then save and commit one by one. If the objects trees (counted from the root objects)
in your resource are fairly independent then this should help.
gr. Martin
> save...that seems to work fine.
> Mark.
The Netherlands
Re: [TENEO] stackoverflow when saving a copied resource [message #602871 is a reply to message #72228] |
Tue, 20 February 2007 15:19  |
Martin,
Unfortunately I have a single root object, and all other objects have
relations to some other objects. In fact an object with no relationships
would not exist in the resource...
I have increased the stack size to 50M with no success.
At this point I am not sure how to proceed...or what to try.
Mark.
Re: [TENEO] stackoverflow when saving a copied resource [message #602875 is a reply to message #72517] |
Wed, 21 February 2007 02:02  |
Mark,
You can send me (by email) the xml file (zipped) and the ecore model. I can give it a try. I am on
holiday this week so it will be next week before I can really look at it.
gr. Martin
mark wrote:
> Martin,
> Mark.
The Netherlands
Re: [TENEO] was stackoverflow when saving a copied resource [message #602885 is a reply to message #72535] |
Thu, 22 February 2007 14:46  |
Martin,
I moved to a Linux box and seemed to have gotten further, I think. The
process runs for over 12 minutes, but then throws the following exception.
org.hibernate.exception.ConstraintViolationException: Could not execute
JDBC batch update
org.hibernate.exception.SQLStateConverter.convert(SQLStateCo nverter.java:71)
org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExce ptionHelper.java:43)
org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatc her.java:249)
org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:92)
org.hibernate.jdbc.AbstractBatcher.prepareStatement(Abstract Batcher.java:87)
org.hibernate.jdbc.AbstractBatcher.prepareBatchStatement(Abs tractBatcher.java:218)
org.hibernate.persister.collection.AbstractCollectionPersist er.recreate(AbstractCollectionPersister.java:1119)
org.hibernate.action.CollectionRecreateAction.execute(Collec tionRecreateAction.java:26)
at org.hibernate.engine.ActionQueue.execute(ActionQueue.java:24 8)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:232)
at org.hibernate.engine.ActionQueue.executeActions(ActionQueue. java:143)
org.hibernate.event.def.AbstractFlushingEventListener.perfor mExecutions(AbstractFlushingEventListener.java:298)
org.hibernate.event.def.DefaultFlushEventListener.onFlush(De faultFlushEventListener.java:27)
at org.hibernate.impl.SessionImpl.flush(SessionImpl.java:1000)
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:244)
org.eclipse.emf.teneo.resource.StoreResource.save(StoreResou rce.java:365)
at srd.util.xml2teneo.Import2Teneo.main(Import2Teneo.java:263)
Caused by: java.sql.BatchUpdateException: Cannot add or update a child
row: a foreign key constraint fails
com.mysql.jdbc.ServerPreparedStatement.executeBatch(ServerPr eparedStatement.java:652)
org.hibernate.jdbc.BatchingBatcher.doExecuteBatch(BatchingBa tcher.java:48)
org.hibernate.jdbc.AbstractBatcher.executeBatch(AbstractBatc her.java:242)
... 14 more
Exception in thread "main"
org.eclipse.emf.teneo.hibernate.HbMapperException: Exception when saving
resource srdV3
org.eclipse.emf.teneo.hibernate.resource.HibernateResource.s aveResource(HibernateResource.java:248)
Caused by: org.hibernate.exception.ConstraintViolationException: Could not
execute JDBC batch update
... 2 more
... 14 more
Current Time: Tue Jul 22 12:11:44 EDT 2025
Powered by FUDForum. Page generated in 0.27352 seconds
