Home » Modeling » OCL » validate enumartion litrerals ocl
validate enumartion litrerals ocl [message #71825] Tue, 14 July 2009 10:51 Go to next message
I created a model and within it an enumeration E with two properties e1
and e2.
In this model I created a class C with a property c1 of type E.
I would like to check if the value of the c1 is e1 or e2 using an ocl
constraint defined in the plugin.xml file (like in the OCL Validation
Constraints Tutorial).
Expression applied to C class
self.c1 = 'e1'
returns an error.
Any idea how I can compare a property against the value of an Enumeration?
What would be the ocl syntax in my example?
thank you for help.
Szymon
Re: validate enumartion litrerals ocl [message #71844 is a reply to message #71825] Tue, 14 July 2009 13:14 Go to previous messageGo to next message
Hi Szymon
The correct OCL syntax for an enumeration literal is E::e1 not 'e1', so try
self.c1 = E::e1
Ed Willink
Szymon wrote:
> and e2.
> self.c1 = 'e1'
> returns an error.
> Enumeration? What would be the ocl syntax in my example?
> thank you for help.
> Szymon
Re: validate enumartion litrerals ocl [message #71919 is a reply to message #71844] Wed, 15 July 2009 03:37 Go to previous messageGo to next message
The only way I got this type of constraint to work in my application was
to use this syntax:
self.c1 = #E::e1
I am using OCL 1.2.3 under Eclipse Ganymede.
JT
Ed Willink wrote:
> Hi Szymon
> self.c1 = E::e1
> Regards
> Ed Willink
> Szymon wrote:
>> and e2.
>> self.c1 = 'e1'
>> returns an error.
>> thank you for help.
>> Szymon
Re: validate enumartion litrerals ocl [message #71938 is a reply to message #71919] Wed, 15 July 2009 05:21 Go to previous messageGo to next message
thank yo for help. It works fine.
Szymon
Re: validate enumartion litrerals ocl [message #71956 is a reply to message #71919] Wed, 15 July 2009 05:22 Go to previous messageGo to next message
> to use this syntax:
> self.c1 = #E::e1
I find this very difficult to understand. Using MDT-OCL 1.3.0 on Galileo
(and I don't think anything has changed here) and the RoyalAndLoyal.ocl
example from org.eclipse.qvt.declarative.examples.ocl.royalandloyal.
The constraint:
inv invariant_Customer7 :
(self.gender = Gender::male) implies self.title = 'Mr.'
works fine, but fails if Gender::male is misspelled or #-prefixed.
(The error message for the #-prefix needs improvement -
raised as https://bugs.eclipse.org/bugs/show_bug.cgi?id=283509).
Search the sources the # character is only used as a fragment separator
in comment hyper links and as a miscellaneous string character, so I
cannot understand how you get something tyo work by using it.
Please submit a full 'working' example using # as a Bugzilla.
Ed Willink
Re: validate enumartion litrerals ocl [message #72014 is a reply to message #71956] Wed, 15 July 2009 13:00 Go to previous messageGo to next message
The older version of OCL, appears to have supported the '#' in front of an
enum literal name:
http://www.csci.csusb.edu/dick/samples/ocl.html#Grammar
I have a minimal working example using the '#' under OCL 1.2.3. I will
submit a bugzilla.
JT
>> to use this syntax:
>> self.c1 = #E::e1
> The constraint:
> Regards
> Ed Willink
Re: validate enumartion litrerals ocl [message #72032 is a reply to message #72014] Wed, 15 July 2009 13:38 Go to previous messageGo to next message
Hi John
Thanks for providing your source. It is an example of an informal guide
that when accurate is very helpful. Unfortunately it contains many
errors, so I would recommend not consulting it further. Buy the Warmer
and Kleppe book; it's very readable.
It appears that the current MDT-OCL is working correctly. The only issue
is whether the previous release temporarily supported an obsolete
syntax. Since the current release correctly rejects #, there is little
point raising a bugzilla that I instantly reject as INVALID.
Ed Willink
> an enum literal name:
> submit a bugzilla.
> JT
>>> was to use this syntax:
>>> self.c1 = #E::e1
>> The constraint:
>> Regards
>> Ed Willink
Re: validate enumartion litrerals ocl [message #72050 is a reply to message #72032] Wed, 15 July 2009 13:51 Go to previous message
Thank you for the feedback and your recommended book. I will check it out.
JT
Ed Willink wrote:
> Hi John
> Regards
> Ed Willink
>> submit a bugzilla.
>> Thanks,
>> JT
>>>> self.c1 = #E::e1
>>> The constraint:
>>> Regards
>>> Ed Willink
Previous Topic:exclusion among attributes of different types
Next Topic:Generating code with OCL constraints etc.. in it
Current Time: Mon Jul 21 21:18:20 EDT 2025
Powered by FUDForum. Page generated in 0.04450 seconds
