Home » Eclipse Projects » Eclipse Platform » help ... system requirements...
help ... system requirements... [message #71778] Thu, 12 June 2003 05:29 Go to next message
Originally posted by: cdrdvo.mozcom.com
guyz,
help me ouit... i just downloaded eclipse but i can't manage how to run
it.. found a portion in their webpage on how to run eclipse but it is on
windows.. how aboiut on linux.. im runing rh8...
pls.. help..
Kent
Re: help ... system requirements... [message #71836 is a reply to message #71778] Thu, 12 June 2003 07:14 Go to previous messageGo to next message
so, what exactly is your problem? Did you download the correct version
(Linux Motif/GTK)? What errors do you see?
Kent wrote:
> guyz,
> pls.. help..
> Kent
Re: help ... system requirements... [message #74969 is a reply to message #71836] Sun, 15 June 2003 22:49 Go to previous message
im running redhat8 and i downloaded the Motif one,
if i would run the startup.jar file. i have this errors...
[kent@rhLinux eclipse]$ java -jar starup.jar
Exception in thread "main" java.util.zip.ZipException: No such file or
directory
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:112)
at java.util.jar.JarFile.<init>(JarFile.java:117)
at java.util.jar.JarFile.<init>(JarFile.java:55)
do i have to make a special configurations? if so can you pls tell me how?
im really new in linux..
"Christian Sell" <cse@dynabean.de> wrote in message
news:bc9naq$p97$1@rogue.oti.com...
> Kent wrote:
> > guyz,
> > pls.. help..
> > Kent
Previous Topic:"refresh()" method in the TreeViewer()
Next Topic:can you guyz help me out...
Current Time: Mon Jul 14 06:47:43 EDT 2025
Powered by FUDForum. Page generated in 0.06504 seconds
