Home » Language IDEs » AspectJ » AJDT source checkout and errors in modules
AJDT source checkout and errors in modules [message #71678] Wed, 11 June 2008 05:07 Go to next message
Originally posted by: rinku.apache.org
Greetings,
I checked out AJDT sources from:
CVSROOT
:pserver:anonymous@dev.eclipse.org:/cvsroot/tools
Repository
org.eclipse.ajdt/AJDT_src
A few modules (listed below) there have compilation errors. Anyone else
seeing this? Am I missing something to set up a working AJDT workspace?
Following the modules with errors on a fresh checkout:
org.aspectj.weaver
org.eclipse.ajdt.build
org.eclipse.ajdt.build31
org.eclipse.ajdt.cuprovider
org.eclipse.ajdt.tests.performance
org.eclipse.ajdt.ui.buildconfig
org.eclipse.ajdt.ui.newbuildconfig
Thanks in advance.
Rahul
Re: AJDT source checkout and errors in modules [message #71697 is a reply to message #71678] Wed, 11 June 2008 12:03 Go to previous messageGo to next message
Most of those are old projects which you don't need. See:
http://www.eclipse.org/ajdt/developers.php#q:develop
I think you can delete all of those excepts org.aspectj.weaver
And make sure you're using the right CVS branch for your version of Eclipse.
Matt.
Rahul T wrote:
> Greetings,
> CVSROOT
> Repository
> org.aspectj.weaver
> Thanks in advance.
> Rahul
Re: AJDT source checkout and errors in modules [message #71716 is a reply to message #71697] Wed, 11 June 2008 22:44 Go to previous messageGo to next message
Thanks Matt.
I suppose this doesn't cover AspectJ sources, right?
Is there a roadmap for the next release for AJDT? It appears the project
is not very active.
Rahul
Matt Chapman wrote:
> Eclipse.
> Matt.
> Rahul T wrote:
>> Greetings,
>> CVSROOT
>> Repository
>> else seeing this? Am I missing something to set up a working AJDT
>> workspace?
>> org.aspectj.weaver
>> Thanks in advance.
>> Rahul
Re: AJDT source checkout and errors in modules [message #71735 is a reply to message #71716] Thu, 12 June 2008 01:51 Go to previous messageGo to next message
Originally posted by: nimoth.gmx.de
> is not very active.
There should be something like a roadmap. Use the mailing lists listed on
the AspectJ and AJDT project website. Those lists are much more active than
this group here.
Cheers
Martin
For emails, please use cs.tu-berlin.de instead of gmx.de behind the at.
Re: AJDT source checkout and errors in modules [message #71754 is a reply to message #71735] Thu, 12 June 2008 11:55 Go to previous message
Martin is right, we don't use the newsgroup any more and I forget it is
here a lot of the time - we might close it down and just move all
discussion to the mailing list.
The plan for AJDT is on the Plans page for AJDT...
http://www.eclipse.org/ajdt/plans.php
1.5.3 shortly and 1.6.0 once Eclipse 3.4 is completed.
Andy.
Re: AJDT source checkout and errors in modules [message #596949 is a reply to message #71678] Wed, 11 June 2008 12:03 Go to previous message
Matt.
Rahul T wrote:
> Greetings,
> CVSROOT
> Repository
> org.aspectj.weaver
> Thanks in advance.
> Rahul
Re: AJDT source checkout and errors in modules [message #596962 is a reply to message #71697] Wed, 11 June 2008 22:44 Go to previous message
Thanks Matt.
is not very active.
Rahul
Matt Chapman wrote:
> Eclipse.
> Matt.
> Rahul T wrote:
>> Greetings,
>> CVSROOT
>> Repository
>> workspace?
>> org.aspectj.weaver
>> Thanks in advance.
>> Rahul
Re: AJDT source checkout and errors in modules [message #596976 is a reply to message #71716] Thu, 12 June 2008 01:51 Go to previous message
> is not very active.
this group here.
Cheers
Martin
Re: AJDT source checkout and errors in modules [message #596986 is a reply to message #71735] Thu, 12 June 2008 11:55 Go to previous message
Andy.
Previous Topic:AJDT source checkout and errors in modules
Next Topic:Aspect Rewrite
Current Time: Sun Jul 27 06:07:17 EDT 2025
Powered by FUDForum. Page generated in 0.08030 seconds
