Calling c++ dll within my eclipse plugin [message #71528] |
Thu, 22 May 2008 09:24  |
Originally posted by: oren_b1.verifone.com
I am trying to call a c++ function from dll within my eclipse plugin, and I
am using jni to that (i don't know any other way to call c++ functions from
java).
The code for invoking the c++ functions works on a regular java application
but what I am trying to use that code within my plugin I get the following
error message on the console:
# An unexpected error has been detected by Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6d892b63, pid=9900,
tid=10632
# Java VM: Java HotSpot(TM) Client VM (1.6.0_02-b06 mixed mode)
# Problematic frame:
# V [jvm.dll+0xd2b63]
# An error report file with more information is saved as hs_err_pid9900.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
I have succeeded to bypass this problem in some cases by writing a class
which implements "IWorkbenchWindowActionDelegate" and invoking my c++
function within the run(IAction) function in new thread.
however, it's not always possible to use "IWorkbenchWindowActionDelegate"
because it's ment for gui events, I have also tried to create new thread not
within "IWorkbenchWindowActionDelegate" and it doesn't work.
Is there another class similar to "IWorkbenchWindowActionDelegate" but for
invoking within the code? or maybe some one know different solution ?
Oren Barzilai
Re: Calling c++ dll within my eclipse plugin [message #71587 is a reply to message #71528] |
Thu, 22 May 2008 10:45  |
sorry, my mistake.
"oren barzilai" <oren_b1@verifone.com> wrote in message
news:g13s7u$7fl$1@build.eclipse.org...
> Hello,
> I am using jni to that (i don't know any other way to call c++ functions
> from java).
> application but what I am trying to use that code within my plugin I get
> the following error message on the console:
> tid=10632
> hs_err_pid9900.log
> not within "IWorkbenchWindowActionDelegate" and it doesn't work.
> Thanks
> Oren Barzilai
FUDForum. Page generated in 0.06776 seconds
