Newb with a possible bug.. [message #71484] |
Fri, 04 February 2005 04:46  |
Originally posted by: steff.tdc.dk
Hi!
I'm not too sure if I've installed Eclipse properly.
I'm using FreeBSD, and have installed with no problems from
ports-collection.
I get this error in the log:
!ENTRY org.eclipse.ui 4 0 Feb 03, 2005 11:53:51.116
!MESSAGE java.lang.ClassCastException
!STACK 0
org.epic.core.popupmenus.TogglePerlNatureActionDelegate.setA ctivePart(TogglePerlNatureActionDelegate.java:40)
org.eclipse.ui.internal.ObjectPluginAction.setActivePart(Obj ectPluginAction.java:63)
org.eclipse.ui.internal.ObjectActionContributor.contributeOb jectActions(ObjectActionContributor.java:108)
org.eclipse.ui.internal.ObjectActionContributorManager.contr ibuteObjectActions(ObjectActionContributorManager.java:131)
org.eclipse.ui.internal.PopupMenuExtender.addObjectActions(P opupMenuExtender.java:98)
org.eclipse.ui.internal.PopupMenuExtender.menuAboutToShow(Po pupMenuExtender.java:119)
org.eclipse.jface.action.MenuManager.fireAboutToShow(MenuMan ager.java:286)
org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuM anager.java:370)
at org.eclipse.jface.action.MenuManager.access$000(MenuManager. java:38)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager .java:383)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:116)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:954)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:978)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:959)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:174)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:2621)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2294)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.core.resources 2 1 Feb 03, 2005 11:54:12.552
!MESSAGE Skipping builder com.ibm.sse.model.structuredbuilder for project
RouterAPI. Either the builder is missing from the install, or it belongs
to a project nature that is missing or disabled.
!ENTRY org.eclipse.core.resources 2 1 Feb 03, 2005 11:54:12.554
!MESSAGE Skipping builder org.eclipse.wst.sse.core.structuredbuilder for
project RouterAPI. Either the builder is missing from the install, or it
belongs to a project nature that is missing or disabled.
I've tried googling for com.ibm.sse.model.structuredbuilder and
org.eclipse.wst.sse.core.structuredbuilder for a while, but without any
luck.
I've grep'ed for structuredbuilder in my eclipse folder but the word
wasn't found anywhere in the folder.
Is this a bug? Do any of you have one or both these two files? If so,
please contact me to setup a way for me to obtain these files - it would
be greatly appriciated!!
/Steffen
Re: Newb with a possible bug.. [message #71712 is a reply to message #71484] |
Fri, 04 February 2005 11:27  |
Steffen Schumacher wrote:
> Hi!
> ports-collection.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> luck.
The last two entries for *structuredbuilder are for the builder that
used to detect Tasks in XML, HTML, JSP, CSS, and DTD files. It was
provided by the Core SSE plugin and disabled in M2. It's a harmless
warning and you can safely ignore it. The builder will be removed
in M3.
- Nitin
FUDForum. Page generated in 0.11756 seconds
