Home » Eclipse Projects » Eclipse Platform » ANT build and running in separate JVM.
ANT build and running in separate JVM. [message #71470] Wed, 11 June 2003 15:40 Go to next message
Originally posted by: jcollard.utilicorp.com
This is probably been asked several times before, and probably has a simple
solution...
I get the following error building a project after setting it to build in a
separate JVM:
Unable to load default ProjectHelper due to
java.lang.NoClassDefFoundError: org/xml/sax/SAXException
How do I correct this?
John
Re: ANT build and running in separate JVM. [message #71592 is a reply to message #71470] Wed, 11 June 2003 19:34 Go to previous messageGo to next message
Originally posted by: mxlehma.NO-SPAM.qwest.com
For the ant configuration that you are changing the JDK on, go to the
Classpath tab and add the org.apache.xerces_4.0.13/xercesImpl.jar and
xmlParserAPIs.jar files from the eclipse plugins directory. That fixed
the problem for me.
> solution...
> separate JVM:
> John
Re: ANT build and running in separate JVM. [message #71629 is a reply to message #71592] Wed, 11 June 2003 22:09 Go to previous messageGo to next message
Originally posted by: darin_swanson.oti.com
We should put up a dialog to let the user know that they will need to
include the xerces JARs in this case. In the same VM, no Xerces as you get
it for "free" from the Xerces plugin. In a separate VM you must have Xerces.
Logged https://bugs.eclipse.org/bugs/show_bug.cgi?id=38815
Darins
"Michael" <mxlehma@NO-SPAM.qwest.com> wrote in message
news:bc8ea2$qch$1@rogue.oti.com...
> the problem for me.
simple
> > solution...
in a
> > separate JVM:
> > Thanks,
> > John
Re: ANT build and running in separate JVM. [message #72223 is a reply to message #71592] Thu, 12 June 2003 12:02 Go to previous message
That worked great! Thanks!
-John
> the problem for me.
simple
> > solution...
in a
> > separate JVM:
> > Thanks,
> > John
Previous Topic:how to use umlaut in java code
Next Topic:problem running an ant script in elipse.
Current Time: Sat Jul 26 10:04:53 EDT 2025
Powered by FUDForum. Page generated in 0.25299 seconds
