Home » Archived » XML Schema Definition (XSD) » Binding XML to Java
Binding XML to Java [message #71458] Mon, 29 January 2007 07:44 Go to next message
Originally posted by: elena.tibrea.gmail.com
I'm creating an XML as described here:
http://www.theserverside.com/tt/articles/article.tss?l=Bindi ngXMLJava.
Is it possible to add an element which represents a schema
(org.eclipse.xsd.XSDSchema) to the XML resource?
If yes, can you give some clues?
Thanks.
elena
Re: Binding XML to Java [message #71477 is a reply to message #71458] Mon, 29 January 2007 08:09 Go to previous messageGo to next message
Elena,
You could build an Ecore model for the XMLSchema.xsd and use that, or
you could use the extended metadata's demandFeature to create the
element name and namespace you want just as for any other XML name and
namespace you might want to produce. The XSD model itself requires the
specialized behavior of an XSDResourceImpl to serialize, so you can't
use it directly for the purposes of embedding it in some XML data
represented as an EMF AnyType.
> Thanks.
> elena
Re: Binding XML to Java [message #71496 is a reply to message #71477] Mon, 29 January 2007 11:58 Go to previous messageGo to next message
Hi again,
Using the EMF model generated from mySchema.xsd file, I could have smth
like:
StructuralFeature feature =
MyPackage.eINSTANCE.getDocumentRoot().getEStructuralFeature( "myFeature");
MyType featureType=MyFactory.eINSTANCE.createMyFeatureType();
rootMixed.add(feature,featureType);
which would result in <myFeature> being included in my XML Resource,
but what I want to have in the end is a XML file looking like
<document>
<data>
<xs:schema>
<!--everything which belongs to a schema declaration, basically
mySchema.xsd file-->
</xs:schema>
</data>
</document>
Help :-)
Thanks.
elena
Re: Binding XML to Java [message #71515 is a reply to message #71496] Mon, 29 January 2007 13:23 Go to previous message
--------------000705080308080905060006
Elena,
The paper shows how to use demandFeature and how to use AnyType.
AnyType rootTreeNode = XMLTypeFactory.eINSTANCE.createAnyType();
documentRoot.eSet(rootNodeFeature, rootTreeNode);
That same technique could be used to build anything. Or, as I
suggested, you could generate a <My>Package for the schema for schemas
and use that:
http://www.w3.org/2001/XMLSchema.xsd
elena t wrote:
> Hi again,
> smth like:
> <document>
> <data>
> <xs:schema>
> </xs:schema>
> </data>
> </document>
> Help :-)
> Thanks.
> elena
<html>
<head>
http-equiv="Content-Type">
</head>
Elena,<br>
<br>
Re: Binding XML to Java [message #599555 is a reply to message #71458] Mon, 29 January 2007 08:09 Go to previous message
Elena,
> Thanks.
> elena
Re: Binding XML to Java [message #602063 is a reply to message #71477] Mon, 29 January 2007 11:58 Go to previous message
Hi again,
like:
<document>
<data>
<xs:schema>
</xs:schema>
</data>
</document>
Help :-)
Thanks.
elena
Re: Binding XML to Java [message #602074 is a reply to message #71496] Mon, 29 January 2007 13:23 Go to previous message
Elena,
and use that:
elena t wrote:
> Hi again,
> smth like:
> <document>
> <data>
> <xs:schema>
> </xs:schema>
> </data>
> </document>
> Help :-)
> Thanks.
> elena
<html>
<head>
</head>
Elena,<br>
<br>
Previous Topic:Binding XML to Java
Next Topic:[Announce] EclipseCon 2007 Registration
Current Time: Fri Jul 18 00:33:38 EDT 2025
Powered by FUDForum. Page generated in 0.31585 seconds
