Home » Eclipse Projects » GEF » Wire in Logic Editor Example
Wire in Logic Editor Example [message #71436] Wed, 19 March 2003 11:43 Go to next message
Originally posted by: oro7d3.netscape.net
In Logic Editor Example, if I use the default connection router, I can bend
the wires in the diagram.
But once I change to Manhattan Connection Router, I can no longer bend the
wires. Could someone please tell me where in the code which determines
whether a wire is bendable based on the connection router?
Thank you.
Re: Wire in Logic Editor Example [message #71455 is a reply to message #71436] Wed, 19 March 2003 11:48 Go to previous messageGo to next message
WireEditPart.refreshBendpointEditPolicy()
Re: Wire in Logic Editor Example [message #71472 is a reply to message #71436] Wed, 19 March 2003 11:50 Go to previous messageGo to next message
It depends on the edit policy. When the router changes in the logic
example, we call WireEditPart.refreshBendpointEditPolicy() which removes
the edit policy for the CONNECTION_BENDPOINTS_ROLE if the router is a
manhattan router. This particular code is specific to the logic example.
Eric
> Thank you.
Re: Wire in Logic Editor Example [message #71489 is a reply to message #71472] Wed, 19 March 2003 17:02 Go to previous messageGo to next message
Originally posted by: sy_cheung2.yahoo.com
Thanks to both of your for the help.
I have a related question: Does the Manhattan Connection Router consider the
Bound of the source/target figures when it routes the connection? i.e. It
will not route the connection THRU the source/target figure, it will route
AROUND them?
I study the code, it has this when it calculates the start/end direction:
rect = conn.getTargetAnchor().getOwner().getBounds().getCopy();
conn.getTargetAnchor().getOwner().translateToAbsolute(rect);
So it is consider the bound when it calculate the Direction?
But in my plugin, I still get cases when a connection going THRU the
source/target figure.
I am wonder it is because of the Connection Router? or the connection Anchor
that I have for the source/target figure (I am just some kind of Fix point
connection anchor).
Thanks in advance.
"Eric Bordeau" <ebordeau@us.ibm.com> wrote in message
news:b5a74g$s2i$1@rogue.oti.com...
> Eric
bend
the
> > Thank you.
Re: Wire in Logic Editor Example [message #71508 is a reply to message #71489] Wed, 19 March 2003 17:04 Go to previous messageGo to next message
I think it may be your connection anchor. I use ChopBoxConnectionAnchor with
Manhattan Connection Router , I don't see connection going thru either
"Sam Cheung" <sy_cheung2@yahoo.com> wrote in message
news:b5apdn$b8i$1@rogue.oti.com...
the
> AROUND them?
Anchor
> connection anchor).
> Thanks in advance.
example.
> > Eric
> bend
> the
> > > Thank you.
Re: Wire in Logic Editor Example [message #71527 is a reply to message #71489] Wed, 19 March 2003 17:47 Go to previous messageGo to next message
Manhattan router is very dumb. It will route connections on top of other
nodes in the diagram. We would like to investigate an intelligent
Orthogonal (same as mahattan, but we need to pick a new name) router, but
have not had time to address such issues.
the
> AROUND them?
Anchor
> connection anchor).
> Thanks in advance.
example.
> > Eric
> bend
> the
> > > Thank you.
Re: Wire in Logic Editor Example [message #71546 is a reply to message #71527] Wed, 19 March 2003 18:20 Go to previous message
Originally posted by: jwoods.journee.com
Randy,
What are the chances of getting a better router added to the plan for 2.2?
Connection routers are very reusable and very important in GEF (and like you
said - the Manhattan router is dumb). I've found Manhattan OK for testing
and prototyping - but real world end users need something better to make use
of applications written on top of GEF. Ditto for anchors. I'd contribute
one to the group, but I'm still in the core functionality stage of my
project and haven't got the time yet for usability issues (sound familiar?).
Something like a smarter Manhatten (no routing on top of nodes, etc.) with
moveable line segments (up/down or left/right) would be great.
- Jason
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b5as1d$d0c$1@rogue.oti.com...
Previous Topic:Create GEF Editor like the Compare Editor
Next Topic:How do I custom my canvas?
Current Time: Sun Aug 31 18:20:17 EDT 2025
Powered by FUDForum. Page generated in 0.04578 seconds
