Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » debug engine overview
debug engine overview [message #6384] Sun, 10 June 2007 18:52 Go to next message
could someone provide a quick overview in how the debugging
engine/framework works.
i see that there is no longer spawned via launch configuration
delegates, so i'm trying to understand how that entire process works. i
know that the debugger attaches to the ide, instead of the other way
around.
leaving aside remote debugging, if i wanted to debug a program locally,
wouldn't i still want the ability to have a debug launch shortcut that
started up the interpreter process from inside the ide?
thx!
Re: debug engine overview [message #6403 is a reply to message #6384] Wed, 13 June 2007 08:23 Go to previous messageGo to next message
Hello, Jae
You can investigate these classes for better understanding how the DLTK
debug infrastructure works:
- DebuggingEngineRunner
- DebuggingEngineManager
- IInterpreterRunnerFactory (RubyBasicDebuggerRunnerFactory as an
implementation)
- ScriptLaunchUtil
Of course for local debugging you should start interpreter process from
IDE. Each debugging engine can make this operation in its own way. You
can see existing Tcl and Ruby implementations.
If you have another questions relating to DLTK debugging, please ask!
> around.
> thx!
Re: debug engine overview [message #6422 is a reply to message #6403] Wed, 13 June 2007 09:51 Go to previous messageGo to next message
thanks!
i spent some time poking around in the code last night and got a
better understanding of what is going on under the covers.
has any thought been given to remote debugging? that's what i'm most
interested in getting working at the moment. it seems like a simpler
case then local debugging b/c you don't have to worry about the
debugging engine on the client side of things.
On 2007-06-13 08:23:48 -0400, Dmitriy Kovalev <kds@xored.com> said:
> Hello, Jae
> implementation)
> - ScriptLaunchUtil
>> around.
>> thx!
-jae
Re: debug engine overview [message #6441 is a reply to message #6422] Thu, 14 June 2007 11:30 Go to previous messageGo to next message
Hi Jae Gangemi,
Actually DLTK for now has only remote debugger implementation via DBGp
protocol. But we don't have launching shortcuts for it.
Andrei.
> thanks!
> i spent some time poking around in the code last night and got a better
Re: debug engine overview [message #6478 is a reply to message #6441] Sat, 16 June 2007 00:41 Go to previous messageGo to next message
i actually have an implementation for this, but it is in need of some
cleanup so it can work for all of the languages.
on a seperate note - it seems that in order for me to get any useful
information out of the Process object that is created to run the perl
interpreter (if an error occurred, etc), i need to hook into it's
stdout and stderr.
i've already got code that does this in a non-blocking manner
(seperate reading threads), but short of re-implementing runRaw in my
debugging engine implementation, are there any other ways to hook into
this? it seems that perl is the bastard child compared to the rest when
it comes executing processes in from java.
perhaps some pre/post hooks could be put into the runRaw method that
would allow me to wire up stdout/err and then get my results and
cleanup?
-jae
On 2007-06-14 11:30:13 -0400, Andrei Sobolev <andrei.sobolev@xored.com> said:
> Hi Jae Gangemi,
> Andrei.
>> thanks!
Re: debug engine overview [message #6552 is a reply to message #6478] Tue, 19 June 2007 09:18 Go to previous messageGo to next message
Hello Jae,
If I understand correctly, you derived your class from
DebuggingEngineRunner and overrode method 'run' to handle stdout/stderr
of the Process that you launched. I think we should extend our core
classes to allow handle situations like you have. It would be very
helpful if you can send your sources related to interpreter launching to
kds@xored.com In this situation I can investigate your code and
implement good general solution.
Dmitriy Kovalev
> interpreter (if an error occurred, etc), i need to hook into it's stdout
> and stderr.
> i've already got code that does this in a non-blocking manner (seperate
> reading threads), but short of re-implementing runRaw in my debugging
> engine implementation, are there any other ways to hook into this? it
> seems that perl is the bastard child compared to the rest when it comes
> would allow me to wire up stdout/err and then get my results and cleanup?
Re: debug engine overview [message #6570 is a reply to message #6552] Tue, 19 June 2007 11:22 Go to previous message
On 2007-06-19 09:18:14 -0400, Dmitriy Kovalev <kds@xored.com> said:
> Hello Jae,
> to kds@xored.com In this situation I can investigate your code and
that is correct.
in this situation, i only need to hook into the Process object to
determine why the program couldn't be started using the debugging
engine.
let me get things cleaned up a bit, and i'll create a patch.
-jae
Previous Topic:Python exemplary IDE
Next Topic:PreferencesMessages.DLTKEditorPreferencePage_returnKeyword
Current Time: Mon Sep 01 00:58:11 EDT 2025
Powered by FUDForum. Page generated in 0.03822 seconds
