Home » Eclipse Projects » Eclipse Platform » Problem using JUnit in eclipse
Problem using JUnit in eclipse [message #71412] Wed, 11 June 2003 14:17 Go to next message
Originally posted by: lengi.gmx.ch
Hello
I hope i'm in the right newsgroup. Otherwise i would appreciate every
hint ;-)
I'm in trouble using Junit with eclipse.
Since i'm not using eclipse for long but have knowledge of other IDE, i
found it
easy first, to use this great framework with such a good IDE.
Now what my situation is:
OS: Win2k
Eclipse-Version: 2.0.2
Junit-Version: 3.8.1
CLASSPATH=(...)C:\java2sdk\lib;C:\java2sdk\jre\lib;C:\junit3 .8.1\junit.jar;.
JAVA_HOME=C:\java2sdk
Path=(...)C:\java2sdk\bin;C:\junit3.8.1
And what my problem is:
General work with eclipse is ok (creating Classes, TestCases, TestSuites,
"Run As Junit" finds my Tests without trouble).
But when i Run the Test, the Output in the Console is the following:
----------------------console-ouput------------------------- --------
Usage: javaw [-options] class [args...]
(to execute a class)
or javaw -jar [-options] jarfile [args...]
(to execute a jar file)
where options include:
-client to select the "client" VM
-server to select the "server" VM
-hotspot is a synonym for the "client" VM [deprecated]
The default VM is client.
-cp -classpath <directories and zip/jar files separated by ;>
set search path for application classes and resources
-D<name>=<value>
set a system property
-verbose[:class|gc|jni]
enable verbose output
-version print product version and exit
-showversion print product version and continue
-? -help print this help message
-X print help on non-standard options
-ea[:<packagename>...|:<classname>]
-enableassertions[:<packagename>...|:<classname>]
enable assertions
-da[:<packagename>...|:<classname>]
-disableassertions[:<packagename>...|:<classname>]
disable assertions
-esa | -enablesystemassertions
enable system assertions
-dsa | -disablesystemassertions
disable system assertions
----------------------/console-ouput------------------------ ---------
What i looked for:
It seemed to me as a configuration problem
(perhaps javaw don't get any parameters?)
I've googled around, found nobody having this trouble.
Looked in different FAQ's and Forums without success.
What i think now:
Perhaps i have to enter the Right Parameters in the Run-Configuration of
my Tests?
But what do they look like?
For any Help on my Problem i'm very thankful in advance.
Greetings
Lemy
Re: Problem using JUnit in eclipse [message #71514 is a reply to message #71412] Wed, 11 June 2003 18:07 Go to previous message
Hello again.
Not to boring you. I just solved my Problem.
Installed Version 2.1. and everything works fine.
Lemy
Stefan Lengacher wrote:
> Hello
> hint ;-)
> found it
> OS: Win2k
> -D<name>=<value>
> enable assertions
> disable assertions
> What i looked for:
> What i think now:
> my Tests?
> Greetings
> Lemy
Previous Topic:More on problems importing binary projects
Next Topic:Problem in importing binary projects
Current Time: Fri Jul 18 23:19:55 EDT 2025
Powered by FUDForum. Page generated in 0.02961 seconds
