Home » Newcomers » Newcomers » HelloWorld example help plz
HelloWorld example help plz [message #6378] Tue, 18 January 2005 15:02 Go to next message
Originally posted by: dd.nospamplease.com
I've followed the hello world example and got to the last step where
it says select run->run, select "java application" and click "new". At
that point I'm supposed to go ahead and change some parameter
options but all I get is the following exception:
java.lang.NoClassDefFoundError: org/eclipse/core/variables/VariablesPlugin
org.eclipse.jdt.internal.debug.ui.launcher.WorkingDirectoryB lock.isValid(WorkingDirectoryBlock.java:265)
org.eclipse.jdt.debug.ui.launchConfigurations.JavaArgumentsT ab.isValid(JavaArgumentsTab.java:156)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.refresh(LaunchConfigurationTabGroup Viewer.java:414)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.updateButtons(LaunchConfigurationsDialog.j ava:1278)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.refreshStatus(LaunchConfigurationTa bGroupViewer.java:836)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.displayInstanceTabs(LaunchConfigura tionTabGroupViewer.java:554)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer$5.run(LaunchConfigurationTabGroupVi ewer.java:473)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.inputChanged(LaunchConfigurationTab GroupViewer.java:490)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationTabGroupViewer.setInput(LaunchConfigurationTabGrou pViewer.java:454)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.handleLaunchConfigurationSelectionChanged( LaunchConfigurationsDialog.java:775)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$3.selectionChanged(LaunchConfigurationsDia log.java:585)
at org.eclipse.jface.viewers.Viewer$2.run(Viewer.java:159)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
at org.eclipse.jface.viewers.Viewer.fireSelectionChanged(Viewer .java:157)
org.eclipse.jface.viewers.StructuredViewer.updateSelection(S tructuredViewer.java:1394)
org.eclipse.jface.viewers.StructuredViewer.setSelection(Stru cturedViewer.java:1093)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationView.launchConfigurationAdded(LaunchConfigurationV iew.java:223)
org.eclipse.debug.internal.core.LaunchManager$ConfigurationN otifier.run(LaunchManager.java:1481)
org.eclipse.debug.internal.core.LaunchManager$ConfigurationN otifier.notify(LaunchManager.java:1505)
org.eclipse.debug.internal.core.LaunchManager.launchConfigur ationAdded(LaunchManager.java:755)
org.eclipse.debug.internal.core.LaunchConfigurationWorkingCo py.writeNewFile(LaunchConfigurationWorkingCopy.java:278)
org.eclipse.debug.internal.core.LaunchConfigurationWorkingCo py.doSave0(LaunchConfigurationWorkingCopy.java:233)
org.eclipse.debug.internal.core.LaunchConfigurationWorkingCo py.doSave(LaunchConfigurationWorkingCopy.java:174)
org.eclipse.debug.internal.ui.launchConfigurations.CreateLau nchConfigurationAction.performAction(CreateLaunchConfigurati onAction.java:75)
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction$1.run(AbstractLaunchConfigurationAc tion.java:103)
org.eclipse.debug.internal.ui.launchConfigurations.AbstractL aunchConfigurationAction.run(AbstractLaunchConfigurationActi on.java:106)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$ButtonActionNew.run(LaunchConfigurationsDi alog.java:1461)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog$1.widgetSelected(LaunchConfigurationsDialo g.java:1430)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:796)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2772)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2431)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:668 )
at org.eclipse.jface.window.Window.open(Window.java:648)
org.eclipse.debug.internal.ui.launchConfigurations.LaunchCon figurationsDialog.open(LaunchConfigurationsDialog.java:419)
at org.eclipse.debug.ui.DebugUITools$1.run(DebugUITools.java:38 1)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:385)
org.eclipse.debug.ui.DebugUITools.openLaunchConfigurationDia logOnGroup(DebugUITools.java:327)
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:80)
org.eclipse.debug.ui.actions.OpenLaunchDialogAction.run(Open LaunchDialogAction.java:99)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:276)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:206)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:915)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:866)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:785)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1377)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1348)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:254)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:141)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:96)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
Re: HelloWorld example help plz [message #6436 is a reply to message #6378] Tue, 18 January 2005 16:13 Go to previous messageGo to next message
Ensure you have the Core Variables plugin required in your plugin.xml
<requires>
<import plugin="org.eclipse.core.variables"/>
</requires>
HTH
Darins
"d d" <dd@nospamplease.com> wrote in message
news:csjq09$hpc$1@www.eclipse.org...
> at
> at
> at
upViewer.refresh(LaunchConfigurationTabGroupViewer.java:414)
> at
g.updateButtons(LaunchConfigurationsDialog.java:1278)
> at
upViewer.refreshStatus(LaunchConfigurationTabGroupViewer.jav a:836)
> at
upViewer.displayInstanceTabs(LaunchConfigurationTabGroupView er.java:554)
> at
upViewer$5.run(LaunchConfigurationTabGroupViewer.java:473)
> at
upViewer.inputChanged(LaunchConfigurationTabGroupViewer.java :490)
> at
upViewer.setInput(LaunchConfigurationTabGroupViewer.java:454 )
> at
g.handleLaunchConfigurationSelectionChanged(LaunchConfigurat ionsDialog.java:
775)
> at
g$3.selectionChanged(LaunchConfigurationsDialog.java:585)
> at
:616)
> at
java:1394)
> at
a:1093)
> at
aunchConfigurationAdded(LaunchConfigurationView.java:223)
> at
> at
:616)
> at
> at
hManager.java:755)
> at
> at
> at
> at
Action.performAction(CreateLaunchConfigurationAction.java:75 )
> at
onAction$1.run(AbstractLaunchConfigurationAction.java:103)
> at
onAction.run(AbstractLaunchConfigurationAction.java:106)
> at
g$ButtonActionNew.run(LaunchConfigurationsDialog.java:1461)
> at
g$1.widgetSelected(LaunchConfigurationsDialog.java:1430)
> at
> at
> at
UITools.java:385)
> at
UITools.java:327)
> at
on.java:80)
> at
on.java:99)
> at
> at
206)
> at
> at
tem.java:866)
> at
tionItem.java:785)
> at
> at
java:335)
> at
> at
Re: HelloWorld example help plz [message #6511 is a reply to message #6436] Tue, 18 January 2005 16:34 Go to previous messageGo to next message
Thanks Darin,
I did a search and found 76 plugin.xml files and I'm not sure
which to modify. I'm trying to build and run the sample hello
world SWT java application on Windows XP using eclipse 3.01.
I'm still surprised I'd have to do this as (1) why wouldn't that
definition be in the plugin.xml file already if it's required and
(b) why wouldn't it tell me in the tutorial as it would happen to
everyone surely.
~dd
"Darin Swanson" <Darin_Swanson@us.ibm.com> wrote in message
news:csju6q$902$1@www.eclipse.org...
> <requires>
> </requires>
> HTH
> Darins
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> 775)
>> at
>> at
> :616)
>> at
> java:1394)
>> at
> a:1093)
>> at
>> at
>> at
> :616)
>> at
>> at
> hManager.java:755)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
> UITools.java:385)
>> at
> UITools.java:327)
>> at
> on.java:80)
>> at
> on.java:99)
>> at
>> at
> 206)
>> at
>> at
> tem.java:866)
>> at
> tionItem.java:785)
>> at
>> at
> java:335)
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
Re: HelloWorld example help plz [message #6531 is a reply to message #6511] Tue, 18 January 2005 16:40 Go to previous messageGo to next message
I assumed you were building a plugin. The xml to modify would be that
plugin's xml
The tutorial is likely out of date. Please help us make it better by logging
a bug report stating the problems.
Darins
news:csjvgi$fo6$1@www.eclipse.org...
> Thanks Darin,
> everyone surely.
> ~dd
> > <requires>
> > </requires>
> > HTH
> > Darins
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> > 775)
> >> at
> >> at
> > :616)
> >> at
> >> at
> > java:1394)
> >> at
> > a:1093)
> >> at
> >> at
> >> at
> > :616)
> >> at
> >> at
> > hManager.java:755)
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> >> at
> > UITools.java:385)
> >> at
> > UITools.java:327)
> >> at
> > on.java:80)
> >> at
> > on.java:99)
> >> at
> >> at
> > 206)
> >> at
> >> at
> > tem.java:866)
> >> at
> > tionItem.java:785)
> >> at
> >> at
> >> at
> > java:335)
> >> at
> >> at
Re: HelloWorld example help plz [message #7978 is a reply to message #6378] Wed, 19 January 2005 07:07 Go to previous message
Originally posted by: don.higgins.microfocus.com
Hello
Since Eclipse GUI should be intuitive and Hello World demo should be the
easiest demo to run, I tried giving it
a go again without looking for help. It went like this:
1. Start up Eclipse 3.0.1 on my XP system with J2SE 1.5.0 installed
2. Clicked file menu, clicked new and create new workspace project named
HelloWorld with subdirectories src and lib.
3. Selected src directory and right clicked and selected import and found
HelloWorldSwing.java demo in a local directory from back when I installed
J2SE and wanted to try demos before I started using Ecliplse.
4. Double clicked HelloWorldSwing.java to open the source in Eclipse
browser.
5. Clicked on Problems to verify it had already compiled clean with no
errors as part of import.
6. Clicked on run menu and selected debug.
7. Enter any name for debug session, browse to find and select HelloWorld
project created in #1, and browse to select the only class in this project
called HelloWorldSwing, and then click debug which should now be enabled.
8. The GUI for HelloWorldSwing does startup but it is minimized and you
have to find it and restore it to see it.
Steps 7 and 8 are not all that intuitive and could be simplified as follows:
a. Put run, debug, terminate at the front of the main run menu followed by
the break point toggle selections. Thats all I use on this menu.
b When selecting new project in debug or run, default the name and class
entries to first class.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Previous Topic:What is org.eclipse.tomcat for?
Next Topic:Code Assist does not show Templates
Current Time: Thu May 08 17:13:37 EDT 2025
Powered by FUDForum. Page generated in 0.08570 seconds
