Home » Archived » BIRT » sending a report parameter as an argument to a function
sending a report parameter as an argument to a function [message #71349] Fri, 02 September 2005 12:22 Go to next message
Originally posted by: sai.yelamanchili.gmail.com
I want to send a report parameter as an argument to a function in a java
class. I'm working on Scripted Data Source. Does anyone have any ideas
on this.
Help Appreciated.
Sai
Is this supported [message #71368 is a reply to message #71349] Fri, 02 September 2005 12:40 Go to previous messageGo to next message
Is there really a way to do this ? Does report parameters work with
Scripted Data Sources ? Is this supported ?
Thanks!
Sai Yelamanchili wrote:
> on this.
> Help Appreciated.
> Thanks
> Sai
Re: Is this supported [message #71423 is a reply to message #71368] Fri, 02 September 2005 13:46 Go to previous messageGo to next message
Sai,
You should be able to do this.
As an example I have a class that I use as an RSS reader and in my open
method I use a parameter to set the feed.
open method on Data Set
brss = new Packages.org.birt.examples.sds.BirtRssReader();
brss..setFeed(params["RssFeed"]);
brss.readFeed();
Jason Weathersby
BIRT PMC
"Sai Yelamanchili" <sai.yelamanchili@gmail.com> wrote in message
news:df9vb6$6a3$1@news.eclipse.org...
> Thanks!
>> class. I'm working on Scripted Data Source. Does anyone have any ideas on
>> this.
>> Help Appreciated.
>> Thanks
>> Sai
Re: Is this supported [message #71461 is a reply to message #71423] Fri, 02 September 2005 14:30 Go to previous messageGo to next message
Jason,
really looks like its gonna help me. Can you make this a little clear.
Suppose, if I'm referencing a class A and invoking function B(with
argument) of that class, I mean
In open() function:
importPackage(Packages x.x.x.x.);
var x = new A().B();
and now I need a argument to be set to B from a user input, how do I do
that ?
Thanks much!
Sai
Jason Weathersby wrote:
> Sai,
> brss.readFeed();
> Jason Weathersby
> BIRT PMC
>>Thanks!
>>>Hi,
>>>this.
>>>Help Appreciated.
>>>Thanks
>>>Sai
Re: Is this supported [message #71480 is a reply to message #71461] Fri, 02 September 2005 14:36 Go to previous messageGo to next message
Sai,
You should be able to just add
var x = new A().B(params["yourparametername"]);
One caveat. Dont do this in the open method of the Data Source. I believe
there is a problem with this.
Try it on the Data Set open method.
Jason Weathersby
BIRT PMC
news:dfa5mo$etj$1@news.eclipse.org...
> Jason,
> In open() function:
> that ?
> Thanks much!
> Sai
>> Sai,
>> brss.readFeed();
>> Jason Weathersby
>> BIRT PMC
>>>Thanks!
>>>>Hi,
>>>>on this.
>>>>Help Appreciated.
>>>>Thanks
>>>>Sai
Thanks [message #71499 is a reply to message #71480] Fri, 02 September 2005 14:44 Go to previous messageGo to next message
Jason,
Thanks much!.
I'm trying this.
yeah I was talking abt the open method in Data Set only.
Sai
> Sai,
> Jason Weathersby
> BIRT PMC
>>Jason,
>>In open() function:
>>that ?
>>Thanks much!
>>Sai
>>>Sai,
>>>brss.readFeed();
>>>Jason Weathersby
>>>BIRT PMC
>>>>Thanks!
>>>>>Hi,
>>>>>on this.
>>>>>Help Appreciated.
>>>>>Thanks
>>>>>Sai
Error [message #71518 is a reply to message #71480] Fri, 02 September 2005 14:53 Go to previous messageGo to next message
Jason
Can You please tell mewhy do I get the following error :
"Some required parameter values are not set or set to incompatible data
type." what parameter values is this referring to ?
I appreciate Your time and effort.
Thanks i advance
Sai
> Sai,
> Jason Weathersby
> BIRT PMC
>>Jason,
>>In open() function:
>>that ?
>>Thanks much!
>>Sai
>>>Sai,
>>>brss.readFeed();
>>>Jason Weathersby
>>>BIRT PMC
>>>>Thanks!
>>>>>Hi,
>>>>>on this.
>>>>>Help Appreciated.
>>>>>Thanks
>>>>>Sai
Error [message #71541 is a reply to message #71480] Fri, 02 September 2005 14:55 Go to previous messageGo to next message
Jason
Can You please tell me why do I get the following error :
type."
Thanks in advance
Sai
> Sai,
> Jason Weathersby
> BIRT PMC
>>Jason,
>>In open() function:
>>that ?
>>Thanks much!
>>Sai
>>>Sai,
>>>brss.readFeed();
>>>Jason Weathersby
>>>BIRT PMC
>>>>Thanks!
>>>>>Hi,
>>>>>on this.
>>>>>Help Appreciated.
>>>>>Thanks
>>>>>Sai
Re: Error [message #71579 is a reply to message #71541] Fri, 02 September 2005 15:07 Go to previous messageGo to next message
Sai,
Is your paramater a string?
If so make sure its double quoted.
Jason Weathersby
BIRT PMC
news:dfa75k$gme$2@news.eclipse.org...
> Jason
> type."
> Thanks in advance
> Sai
>> Sai,
>> believe there is a problem with this.
>> Jason Weathersby
>> BIRT PMC
>>>Jason,
>>>In open() function:
>>>that ?
>>>Thanks much!
>>>Sai
>>>>Sai,
>>>>brss.readFeed();
>>>>Jason Weathersby
>>>>BIRT PMC
>>>>>Thanks!
>>>>>>Hi,
>>>>>>java class. I'm working on Scripted Data Source. Does anyone have any
>>>>>>ideas on this.
>>>>>>Help Appreciated.
>>>>>>Thanks
>>>>>>Sai
Re: Error [message #71597 is a reply to message #71579] Fri, 02 September 2005 15:14 Go to previous messageGo to next message
Jason,
Its a date paramater. Its of Type DateTime.
> Sai,
> Jason Weathersby
> BIRT PMC
>>Jason
>>type."
>>Thanks in advance
>>Sai
>>>Sai,
>>>Jason Weathersby
>>>BIRT PMC
>>>>Jason,
>>>>In open() function:
>>>>that ?
>>>>Thanks much!
>>>>Sai
>>>>>Sai,
>>>>>brss.readFeed();
>>>>>Jason Weathersby
>>>>>BIRT PMC
>>>>>>Thanks!
>>>>>>>Hi,
>>>>>>>ideas on this.
>>>>>>>Help Appreciated.
>>>>>>>Thanks
>>>>>>>Sai
Re: Error [message #71654 is a reply to message #71597] Fri, 02 September 2005 15:33 Go to previous messageGo to next message
Sai,
Have you tried
var dt = new Date(params["yourparameter"]);
new A().B( dt);
Jason Weathersby
BIRT PMC
news:dfa88u$ich$1@news.eclipse.org...
> Jason,
> Thanks
>> Sai,
>> Jason Weathersby
>> BIRT PMC
>>>Jason
>>>type."
>>>Thanks in advance
>>>Sai
>>>>Sai,
>>>>Jason Weathersby
>>>>BIRT PMC
>>>>>Jason,
>>>>>In open() function:
>>>>>that ?
>>>>>Thanks much!
>>>>>Sai
>>>>>>Sai,
>>>>>>open method I use a parameter to set the feed.
>>>>>>brss.readFeed();
>>>>>>Jason Weathersby
>>>>>>BIRT PMC
>>>>>>>Thanks!
>>>>>>>>Hi,
>>>>>>>>any ideas on this.
>>>>>>>>Help Appreciated.
>>>>>>>>Thanks
>>>>>>>>Sai
Re: Error [message #71673 is a reply to message #71654] Fri, 02 September 2005 15:38 Go to previous messageGo to next message
Yes I did,
Error persists.
Sai
> Sai,
> Have you tried
> new A().B( dt);
> Jason Weathersby
> BIRT PMC
>>Jason,
>>Thanks
>>>Sai,
>>>Jason Weathersby
>>>BIRT PMC
>>>>Jason
>>>>type."
>>>>Thanks in advance
>>>>Sai
>>>>>Sai,
>>>>>Jason Weathersby
>>>>>BIRT PMC
>>>>>>Jason,
>>>>>>In open() function:
>>>>>>that ?
>>>>>>Thanks much!
>>>>>>Sai
>>>>>>>Sai,
>>>>>>>brss.readFeed();
>>>>>>>Jason Weathersby
>>>>>>>BIRT PMC
>>>>>>>>Thanks!
>>>>>>>>>Hi,
>>>>>>>>>any ideas on this.
>>>>>>>>>Help Appreciated.
>>>>>>>>>Thanks
>>>>>>>>>Sai
Re: Error [message #71692 is a reply to message #71673] Fri, 02 September 2005 16:00 Go to previous messageGo to next message
Sai,
I had a similar error in the past with a string parameter.
Have you checked the log file for anything under
org.eclipse.birt.report.viewer_1.0.1\birt\logs
Additionally is this the only paramter?
Jason Weathersby
BIRT PMC
news:dfa9m5$k4r$1@news.eclipse.org...
> Yes I did,
> Error persists.
> Thanks
> Sai
>> Sai,
>> Have you tried
>> new A().B( dt);
>> Jason Weathersby
>> BIRT PMC
>>>Jason,
>>>Thanks
>>>>Sai,
>>>>Jason Weathersby
>>>>BIRT PMC
>>>>>Jason
>>>>>type."
>>>>>Thanks in advance
>>>>>Sai
>>>>>>Sai,
>>>>>>Jason Weathersby
>>>>>>BIRT PMC
>>>>>>>Jason,
>>>>>>>clear.
>>>>>>>In open() function:
>>>>>>>do that ?
>>>>>>>Thanks much!
>>>>>>>Sai
>>>>>>>>Sai,
>>>>>>>>brss.readFeed();
>>>>>>>>Jason Weathersby
>>>>>>>>BIRT PMC
>>>>>>>>>Thanks!
>>>>>>>>>>Hi,
>>>>>>>>>>a java class. I'm working on Scripted Data Source. Does anyone
>>>>>>>>>>have any ideas on this.
>>>>>>>>>>Help Appreciated.
>>>>>>>>>>Thanks
>>>>>>>>>>Sai
Re: Error [message #71709 is a reply to message #71692] Fri, 02 September 2005 16:20 Go to previous messageGo to next message
Jason
This is the only parameter.
sai
> Sai,
> Jason Weathersby
> BIRT PMC
>>Yes I did,
>>Error persists.
>>Thanks
>>Sai
>>>Sai,
>>>Have you tried
>>>new A().B( dt);
>>>Jason Weathersby
>>>BIRT PMC
>>>>Jason,
>>>>Thanks
>>>>>Sai,
>>>>>Jason Weathersby
>>>>>BIRT PMC
>>>>>>Jason
>>>>>>type."
>>>>>>Thanks in advance
>>>>>>Sai
>>>>>>>Sai,
>>>>>>>Jason Weathersby
>>>>>>>BIRT PMC
>>>>>>>>Jason,
>>>>>>>>clear.
>>>>>>>>In open() function:
>>>>>>>>do that ?
>>>>>>>>Thanks much!
>>>>>>>>Sai
>>>>>>>>>Sai,
>>>>>>>>>brss.readFeed();
>>>>>>>>>Jason Weathersby
>>>>>>>>>BIRT PMC
>>>>>>>>>>Thanks!
>>>>>>>>>>>Hi,
>>>>>>>>>>>Help Appreciated.
>>>>>>>>>>>Thanks
>>>>>>>>>>>Sai
Detailed Idea [message #72101 is a reply to message #71709] Mon, 05 September 2005 13:54 Go to previous messageGo to next message
Jason
What I'm exactly doing is :
I have an object A and a class B. Class B has a function that takes an
argument "x", which is a date and returns ArrayList of A objects.
Now, I have to use the Scripetd Data Source to make a report from the
returned ArrayList.
In my open and fetch of Data Set, I'm usig the following code:
Open()
importPackage(Packages.com.rpc.core.accounting.model);
dt = new Date(params["input"]);
c = new B().A(dt);
itrLista = c.iterator();
Fetch()
while(itrLista.hasNext())
a = itrLista.next();
row["1"]= a.get1();
row["2"]= a.get2();
row["3"]= a.get3();
row["4"]= a.get4();
row["5"]= a.5();
return true;
return false;
" Some required parameter values are not set or set to incompatible data
type."
1. while creating the report parameter input, Do I have to select type
as String or Datetime.
And any other ideas how I can proceed with this. Cudnt't find any
online-help. I'm actually new to reporting.
I appreciate Ur help.
Sai
> Jason
> Thanks
> sai
>> Sai,
>> Jason Weathersby
>> BIRT PMC
>>> Yes I did,
>>> Error persists.
>>> Thanks
>>> Sai
>>>> Sai,
>>>> Have you tried
>>>> new A().B( dt);
>>>> Jason Weathersby
>>>> BIRT PMC
>>>>> Jason,
>>>>> Thanks
>>>>>> Sai,
>>>>>> Jason Weathersby
>>>>>> BIRT PMC
>>>>>>> Jason
>>>>>>> incompatible data type."
>>>>>>> Thanks in advance
>>>>>>> Sai
>>>>>>>> Sai,
>>>>>>>> I believe there is a problem with this.
>>>>>>>> Jason Weathersby
>>>>>>>> BIRT PMC
>>>>>>>>> Jason,
>>>>>>>>> clear.
>>>>>>>>> B(with argument) of that class, I mean
>>>>>>>>> In open() function:
>>>>>>>>> do I do that ?
>>>>>>>>> Thanks much!
>>>>>>>>> Sai
>>>>>>>>>> Sai,
>>>>>>>>>> in my open method I use a parameter to set the feed.
>>>>>>>>>> brss.readFeed();
>>>>>>>>>> Jason Weathersby
>>>>>>>>>> BIRT PMC
>>>>>>>>>> message news:df9vb6$6a3$1@news.eclipse.org...
>>>>>>>>>>> work with Scripted Data Sources ? Is this supported ?
>>>>>>>>>>> Thanks!
>>>>>>>>>>>> Hi,
>>>>>>>>>>>> function in a java class. I'm working on Scripted Data
>>>>>>>>>>>> Source. Does anyone have any ideas on this.
>>>>>>>>>>>> Help Appreciated.
>>>>>>>>>>>> Thanks
>>>>>>>>>>>> Sai
Re: Detailed Idea [message #72121 is a reply to message #72101] Mon, 05 September 2005 14:42 Go to previous message
Jason
returned ArrayList.
Open()
c = new B().A(dt);
Fetch()
row["1"]= a.get1();
row["2"]= a.get2();
row["3"]= a.get3();
row["4"]= a.get4();
row["5"]= a.5();
return true;
return false;
type."
After I enter the date,
the error is:
" Script engine error: TypeError: findOpenDepositsAsOfDate is not a
function. (DataSet:OpenVendorDeposit.open#2 "
Sai
> Jason
> returned ArrayList.
> Open()
> c = new B().A(dt);
> Fetch()
> row["1"]= a.get1();
> row["2"]= a.get2();
> row["3"]= a.get3();
> row["4"]= a.get4();
> row["5"]= a.5();
> return true;
> return false;
> type."
> Thanks
> Sai
>> Jason
>> Thanks
>> sai
>>> Sai,
>>> Jason Weathersby
>>> BIRT PMC
>>>> Yes I did,
>>>> Error persists.
>>>> Thanks
>>>> Sai
>>>>> Sai,
>>>>> Have you tried
>>>>> new A().B( dt);
>>>>> Jason Weathersby
>>>>> BIRT PMC
>>>>>> Jason,
>>>>>> Thanks
>>>>>>> Sai,
>>>>>>> Jason Weathersby
>>>>>>> BIRT PMC
>>>>>>>> Jason
>>>>>>>> Thanks in advance
>>>>>>>> Sai
>>>>>>>>> Sai,
>>>>>>>>> Source. I believe there is a problem with this.
>>>>>>>>> Jason Weathersby
>>>>>>>>> BIRT PMC
>>>>>>>>> message news:dfa5mo$etj$1@news.eclipse.org...
>>>>>>>>>> Jason,
>>>>>>>>>> little clear.
>>>>>>>>>> In open() function:
>>>>>>>>>> how do I do that ?
>>>>>>>>>> Thanks much!
>>>>>>>>>> Sai
>>>>>>>>>>> Sai,
>>>>>>>>>>> brss.readFeed();
>>>>>>>>>>> Jason Weathersby
>>>>>>>>>>> BIRT PMC
>>>>>>>>>>>> Thanks!
>>>>>>>>>>>>> Hi,
>>>>>>>>>>>>> Help Appreciated.
>>>>>>>>>>>>> Thanks
>>>>>>>>>>>>> Sai
Previous Topic:Thanks for all who helped to answer questions in this forum
Next Topic:Binding a Data Set Parameter to Report Parameter Not Working
Current Time: Sat Jul 26 05:11:22 EDT 2025
Powered by FUDForum. Page generated in 0.11932 seconds
