Home » Language IDEs » C / C++ IDE (CDT) » new variable for code assist and acces to global variabel
new variable for code assist and acces to global variabel [message #71338] Fri, 23 May 2003 09:43 Go to next message
Originally posted by: hxbx.gmx.net
hallo,
1) is it possible to define a new variable, like "owner" for the code
assist?
I want to insert this new variable as ${owner} into
a new template for the code assist, for example for a procedure header.
Is there a way to read in some variable from a file?
2) if I insert global eclipse variable like ${resource_name} into a code
template it dosnt work? Why?
thanks
harald
Re: new variable for code assist and acces to global variabel [message #75014 is a reply to message #71338] Sat, 05 July 2003 14:40 Go to previous message
"harald" <hxbx@gmx.net> wrote in message news:bal8ht$krq$1@rogue.oti.com...
> hallo,
> assist?
1) Can't create your own variables yet
2) Likely just a carry over since the CDT code base hasn't caught up to
the Eclipse 2.0 and 2.1 features (codebase originated on 1.0).
Thomas
Previous Topic:Stuck at "Run..." configuration dialog
Next Topic:best IDE for C++
Current Time: Sat Aug 30 19:26:57 EDT 2025
Powered by FUDForum. Page generated in 0.04918 seconds
