Home » Archived » BIRT » HTML/PDF does not show up
HTML/PDF does not show up [message #71331] Fri, 02 September 2005 10:37 Go to next message
Originally posted by: Jenny.xxx.com
I have run the servlet engine API.I have hardcoded the report design in
it[i gave the physical location - URL] . RIght now iam not passing any
parameters but iam just trying to open the desing in the browser when the
tomcat server runs.It is just downloading the page and trying to save it
in my local drive.But i want to open it in the browser instead as html or
PDF.
Appreciate help
Jen
INFO: building formatting object tree
Sep 2, 2005 9:22:35 AM org.apache.avalon.framework.logger.Jdk14Logger info
INFO: setting up fonts
Sep 2, 2005 9:22:35 AM org.apache.avalon.framework.logger.Jdk14Logger error
SEVERE: property - "text-transform" is not implemented yet.
SEVERE: Error in letter-spacing property value 'normal':
org.apache.fop.fo.expr.PropertyException: No conversion defined
SEVERE: property - "word-spacing" is not implemented yet.
INFO: [1]
Sep 2, 2005 9:22:36 AM org.apache.avalon.framework.logger.Jdk14Logger info
INFO: Parsing of document complete, stopping renderer
Sep 2, 2005 9:22:36 AM org.eclipse.birt.data.engine.impl.DataEngineImpl
shutdown
INFO: Data engine shuts down
Re: HTML/PDF does not show up [message #71728 is a reply to message #71331] Fri, 02 September 2005 16:42 Go to previous messageGo to next message
Originally posted by: Jenny.xxxxx.com
Hello Guys,
Here is the stuff on the server.....It is not displaying the images of
charts on the web browser.
INFO: Server startup in 44023 ms
Sep 2, 2005 3:33:50 PM org.eclipse.birt.core.util.BirtTimer logTimeTaken
INFO: Engine startup takes 7010 Milliseconds.
Sep 2, 2005 3:34:09 PM org.eclipse.birt.data.engine.impl.DataEngineImpl
<init>
INFO: Data Engine starts up
line 1 column 1 - Warning: inserting missing 'title' element
line 1 column 5 - Warning: <center> isn't allowed in <h3> elements
line 1 column 47 - Warning: replacing unexpected </b> by </u>
line 1 column 51 - Warning: replacing unexpected </u> by </b>
line 1 column 55 - Warning: discarding unexpected </center>
[INFO]: getProperty(...) - chart.instance
[INFO]: ChartReportItemQueryImpl: getReportQueries(...) - start
[INFO]: ChartReportItemQueryImpl: getReportQueries(...) - end
Sep 2, 2005 3:34:34 PM
org.eclipse.birt.report.engine.content.impl.MasterPageConten t
initSimpleMasterPage
INFO: The property HeaderHeight is not set. Use Default 1 cm.
INFO: The property FooterHeight is not set. Use default 1 cm.
Sep 2, 2005 3:34:37 PM
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager
loadDriverExtensions
INFO: Found JDBC driverinfo extension:
driverClass=sun.jdbc.odbc.JdbcOdbcDriver, connectionFactory=null
driverClass=org.apache.derby.jdbc.EmbeddedDriver, connectionFactory=null
loadAndRegisterDriver
INFO: Loading JDBC driver class: net.sourceforge.jtds.jdbc.Driver
org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager$Driv erClassLoader
getDriverHomeDir
INFO: JDBCDriverManager: drivers directory location:
C:\iopen\jakarta-tomcat-5.5.9\webapps\birt-viewer\WEB-INF\pl ugins\org.eclipse.birt.report.data.oda.jdbc\drivers
refreshURLs
INFO: JDBCDriverManager: found JAR file jtds-1.0.3.jar.
URL=file:C:\iopen\jakarta-tomcat-5.5.9\webapps\birt-viewer\W EB-INF\plugins\org.eclipse.birt.report.data.oda.jdbc\drivers \jtds-1.0.3.jar
[INFO]: ChartReportItemGenerationImpl: onRowSets(...) - start
2004-05-01 00:00:00.0, 2000.0000,
2004-06-01 00:00:00.0, 8200.0000,
2004-07-01 00:00:00.0, 4000.0000,
2004-08-01 00:00:00.0, 3900.0000,
2004-09-01 00:00:00.0, 2100.0000,
2004-10-01 00:00:00.0, 800.0000,
2004-11-01 00:00:00.0, 1100.0000,
2004-12-01 00:00:00.0, 10000.0000,
2005-01-01 00:00:00.0, 1200.0000,
2005-02-01 00:00:00.0, 3500.0000,
2005-03-01 00:00:00.0, 1300.0000,
2005-04-01 00:00:00.0, 1600.0000,
2005-05-01 00:00:00.0, 1800.0000,
[INFO]: (ECLIPSE-ENV) Creating dsp
org.eclipse.birt.chart.datafeed.DataSetProcessorImpl
[INFO]: ChartReportItemPresentationImpl: onRowSets(...) - building chart
[INFO]: Writing to PNG file at
[INFO]: SWING Display Server: Sun Microsystems Inc. v1.4.2_04
[INFO]: (ECLIPSE-ENV) Creating display server ds.SWING as
org.eclipse.birt.chart.device.swing.SwingDisplayServer
[INFO]: (ECLIPSE-ENV) Creating device dv.PNG as
org.eclipse.birt.chart.device.image.PngRendererImpl
[INFO]: Presentation uses bounds
bo=org.eclipse.birt.chart.model.attribute.impl.BoundsImpl@17af46e (left:
0.0, top: 0.0, width: 500.0, height: 250.0)
[INFO]: (ECLIPSE-ENV) Creating series renderer
org.eclipse.birt.chart.render.Bar
[INFO]: Processing stacked info for axis
org.eclipse.birt.chart.model.component.impl.AxisImpl@186ed7a (type:
Linear, titlePosition: Left, gapWidth: <unset>, orientation: Vertical,
labelPosition: Left, staggered: <unset>, primaryAxis: true, categoryAxis:
<unset>, percent: false)
[INFO]: Time to compute plot (without axes) = 2,093 ms
[INFO]: ChartReportItemPresentationImpl: onRowSets(...) - rendering chart
[INFO]: Using graphics context
sun.java2d.SunGraphics2D[font=java.awt.Font[family=Dialog,na me=Dialog,style=plain,size=12],color=java.awt.Color[r=255,g= 255,b=255]]
[INFO]: org.eclipse.birt.chart.render.EmptyWithAxes: renderSeries() [1/2]
[INFO]: org.eclipse.birt.chart.render.Bar: renderSeries() [2/2]
[INFO]: Time to render everything = 1,783 ms
[INFO]: Using {0} image writer
{1}pngcom.sun.imageio.plugins.png.PNGImageWriter
[INFO]: ChartReportItemPresentationImpl: onRowSets(...) - end
[INFO]: ChartReportItemPresentationImpl: finish(...) - start
[INFO]: Successfully deleted temporary PNG file created at
[INFO]: ChartReportItemPresentationImpl: finish(...) - end
Dorsey , 9,
Trailmobile , 14,
Warranty, 17,
Great Dane, 121,
Utility, 211,
bo=org.eclipse.birt.chart.model.attribute.impl.BoundsImpl@b049a (left:
org.eclipse.birt.chart.model.component.impl.AxisImpl@96e599 (type: Linear,
[INFO]: Time to compute plot (without axes) = 441 ms
[INFO]: Time to render everything = 741 ms
Sep 2, 2005 3:35:09 PM org.eclipse.birt.data.engine.impl.DataEngineImpl
shutdown
--------------------------------------------------------web browser
page-------
K2 Slider Failures - To Date ----> this is the heading and rest of the
page is blank. what is going on ?
Any help appreciated.
Jen
Servlet code - Re: HTML/PDF does not show up [message #71748 is a reply to message #71728] Fri, 02 September 2005 16:45 Go to previous messageGo to next message
Here is my servlet
---------------Servlet----------------------
* Created on Sep 2, 2005
* TODO To change the template for this generated file go to
* Window - Preferences - Java - Code Style - Code Templates
package com.Jen;
* Created on Aug 25, 2005
import java.io.IOException;
import java.io.PrintWriter;
import javax.servlet.ServletException;
import javax.servlet.ServletOutputStream;
import javax.servlet.http.HttpServlet;
import javax.servlet.http.HttpServletRequest;
import javax.servlet.http.HttpServletResponse;
import java.util.Collection;
import java.util.HashMap;
import java.util.Iterator;
import java.util.Locale;
import java.util.Map;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLCompleteImageHandler;
import org.eclipse.birt.report.engine.api.HTMLEmitterConfig;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IGetParameterDefinitionTa sk;
import org.eclipse.birt.report.engine.api.IParameterDefnBase;
import org.eclipse.birt.report.engine.api.IParameterGroupDefn;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.IScalarParameterDefn;
import org.eclipse.birt.report.engine.api.ReportEngine;
import org.eclipse.birt.report.engine.api.ReportParameterConverter;
* @author BinkeyDoodle
* TODO To change the template for this generated type comment go to
public class RunReport extends HttpServlet
private ReportEngine engine = null;
* Constructor of the object.
public RunReport() {
super();
* Destruction of the servlet. <br>
public void destroy()
super.destroy(); // Just puts "destroy" string in log
// Put your code here
engine.destroy( );
* The doGet method of the servlet. <br>
* This method is called when a form has its tag value method equals to
get.
* @param request the request send by the client to the server
* @param response the response send by the server to the client
* @throws ServletException if an error occurred
* @throws IOException if an error occurred
public void doGet(HttpServletRequest request, HttpServletResponse
response) throws ServletException, IOException
response.setContentType("text/html");
response.setContentType( "text/html;charset=utf-8" ); //$NON-NLS-1$
response.setHeader( "cache-control", "no-cache" ); //$NON-NLS-1$
//$NON-NLS-2$
HashMap params = new HashMap( );
//String OrderNo = request.getParameter("OrderNumber");
//Integer i = new Integer(10100);
//params.put("OrderNumber", OrderNo);
boolean showInfo = false;
String format = HTMLRenderOption.OUTPUT_FORMAT_HTML;
//String format = HTMLRenderOption.OUTPUT_FORMAT_PDF;
String reportName =
" C:\\iopen\\jakarta-tomcat-5.5.9\\webapps\\birt-viewer\\K2Sli der.rptdesign ";
run( reportName, response, params, format, showInfo );
// Get the parameters from the request object
//out.flush();
//out.close();
public void run( String name, HttpServletResponse response, HashMap
params, String format, boolean showInfo )
// Open the report design.
IReportRunnable report = null;
try
report = engine.openReportDesign( name );
catch ( EngineException e )
System.err.println( "Report " + name + " not found!\n" + e );
//engine.destroy( );
return;
catch(Exception e)
System.err.println( "Report " + name + " not found!\n" + e.getMessage()
e.printStackTrace();
return;
// Create a task to run the report and convert the output to HTML
// or PDF.
if ( format != null )
parseParams( engine, report, params );
IRunAndRenderTask task = engine.createRunAndRenderTask( report );
HTMLRenderOption options = new HTMLRenderOption( );
options.setOutputFormat( format );
String output = name.replaceFirst( ".rptdesign", "." + format );
//options.setOutputFileName( output );
ServletOutputStream servletOutputStream = null;
try
servletOutputStream = response.getOutputStream( );
catch(IOException ioe){}
options.setOutputStream( servletOutputStream );
task.setRenderOption( options );
task.setParameterValues( params );
// Run the report
try
task.run( );
catch ( EngineException e1 )
System.err.println( "Report " + name + " run failed.\n" );
System.err.println( e1.toString( ) );
e1.printStackTrace();
// Special handle since servlet output stream has been retrieved.
// Any include and forward throws exception.
// Better to move this error handle into engine.
//String message = "<html><body><font color=\"red\">" //$NON-NLS-1$
// + htmlEncode( e1.getLocalizedMessage( ) )
// +"</font></body></html>"; //$NON-NLS-1$
//servletOutputStream.write( message.getBytes( ) );
* This function is used to encode an ordinary string that may contain
* characters or more than one consecutive spaces for appropriate HTML
display.
* @param s
* @return String
public static final String htmlEncode( String s )
String sHtmlEncoded = ""; //$NON-NLS-1$
if ( s == null )
return null;
StringBuffer sbHtmlEncoded = new StringBuffer( );
final char chrarry[] = s.toCharArray( );
for ( int i = 0; i < chrarry.length; i++ )
char c = chrarry[i];
switch ( c )
case '\t':
sbHtmlEncoded.append( "&#09;" ); //$NON-NLS-1$
break;
case '\n':
sbHtmlEncoded.append( "<br>" ); //$NON-NLS-1$
break;
case '\r':
sbHtmlEncoded.append( "&#13;" ); //$NON-NLS-1$
break;
case ' ':
sbHtmlEncoded.append( "&#32;" ); //$NON-NLS-1$
break;
case '"':
sbHtmlEncoded.append( "&#34;" ); //$NON-NLS-1$
break;
case '\'':
sbHtmlEncoded.append( "&#39;" ); //$NON-NLS-1$
break;
case '<':
sbHtmlEncoded.append( "&#60;" ); //$NON-NLS-1$
break;
case '>':
sbHtmlEncoded.append( "&#62;" ); //$NON-NLS-1$
break;
case '`':
sbHtmlEncoded.append( "&#96;" ); //$NON-NLS-1$
break;
case '&':
sbHtmlEncoded.append( "&#38;" ); //$NON-NLS-1$
break;
default:
sbHtmlEncoded.append( c );
sHtmlEncoded = sbHtmlEncoded.toString( );
return sHtmlEncoded;
* The doPost method of the servlet. <br>
post.
public void doPost(HttpServletRequest request, HttpServletResponse
response)
throws ServletException, IOException {
PrintWriter out = response.getWriter();
out.println("<!DOCTYPE HTML PUBLIC \"-//W3C//DTD HTML 4.01
Transitional//EN\">");
out.println("<HTML>");
out.println(" <HEAD><TITLE>A Servlet</TITLE></HEAD>");
out.println(" <BODY>");
out.print(" This is ");
out.print(this.getClass());
out.println(", using the POST method");
out.println(" </BODY>");
out.println("</HTML>");
out.flush();
out.close();
* Initialization of the servlet. <br>
* @throws ServletException if an error occure
public void init() throws ServletException
// The EngineConfig is used to set up engine-wide configuration
// information.
EngineConfig config = new EngineConfig( );
// The Engine home is the location of the BIRT engine runtime.
// M3 Note: Use the report engine installed as part of the BIRT web app
// used to preview reports. Alter this path to the location of your
// Eclipse installation.
//config.setEngineHome( "c://Program
Files//eclipse//plugins//org.eclipse.birt.report.viewer_0.0. 1//birt//WEB-INF "
config.setEngineHome(" C:\\iopen\\jakarta-tomcat-5.5.9\\webapps\\birt-viewer\\WEB-I NF ");
// HTML reports can have embedded images or charts. Set up the
configuration
// required to write these into a directory in the output directory.
// The HTMLCompleteImageHandler is one provided by BIRT for this purpose.
// Your application can create a customized version to provide
alternative
// ways to handle images.
HTMLEmitterConfig hc = new HTMLEmitterConfig( );
HTMLCompleteImageHandler imageHandler = new HTMLCompleteImageHandler( );
hc.setImageHandler( imageHandler );
config.setEmitterConfiguration( HTMLRenderOption.OUTPUT_FORMAT_HTML, hc
// Create the report engine itself. This engine can be used to run
// multiple reports.
engine = new ReportEngine( config );
* Prepare the report parameters from incoming request.
* @param request incoming http request
* @param paramDefns collection of report parameter definitions
* @return Hash map from parameter name to its current value
private void parseParams( ReportEngine engine, IReportRunnable report,
HashMap values )
if ( values.isEmpty( ) )
return;
IGetParameterDefinitionTask task =
engine.createGetParameterDefinitionTask( report );
Collection params = task.getParameterDefns( false );
Iterator iter = values.keySet( ).iterator( );
while ( iter.hasNext( ) )
String name = (String) iter.next( );
IScalarParameterDefn found = null;
Iterator i2 = params.iterator( );
while ( i2.hasNext( ) )
IParameterDefnBase param = (IParameterDefnBase) i2.next( );
if ( param instanceof IParameterGroupDefn )
continue;
if ( param.getName( ).equals( name ) )
found = (IScalarParameterDefn) param;
break;
if ( found == null )
System.err.println( "Parameter " + name + " not found in the report."
continue;
String value = (String) values.get( name );
ReportParameterConverter cfgConverter = new ReportParameterConverter(
"", Locale.getDefault( ) );
Object obj = cfgConverter.parse( value, found.getDataType( ) );
values.put( name, obj );
//values.put( name, value );
Re: Servlet code - Re: HTML/PDF does not show up [message #72171 is a reply to message #71748] Mon, 05 September 2005 19:14 Go to previous messageGo to next message
Hello !!!
Is there no way that i can figure out what my problem is ?
I am sure it is possible for you guys are you are experienced.
Help
Jenny
Jenny wrote:
> Here is my servlet
> package com.Jen;
> super();
> engine.destroy( );
> get.
> //$NON-NLS-2$
> String reportName =
> " C:\iopen\jakarta-tomcat-5.5.9\webapps\birt-viewer\K2Slider.r ptdesign ";
> //out.flush();
> //out.close();
> try
> System.err.println( "Report " + name + " not found!n" + e );
> return;
> catch(Exception e)
> System.err.println( "Report " + name + " not found!n" + e.getMessage()
> return;
> // or PDF.
> try
> // Run the report
> try
> task.run( );
> System.err.println( "Report " + name + " run failed.n" );
> //String message = "<html><body><font color="red">" //$NON-NLS-1$
> display.
> * @param s
> * @return String
> if ( s == null )
> return null;
> switch ( c )
> case 't':
> break;
> case 'n':
> break;
> case 'r':
> break;
> case ' ':
> break;
> case '"':
> break;
> case ''':
> break;
> case '<':
> break;
> case '>':
> break;
> case '`':
> break;
> case '&':
> break;
> default:
> post.
> response)
> out.println("<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01
> Transitional//EN">");
> out.flush();
> out.close();
> // information.
config.setEngineHome("C:\iopen\jakarta-tomcat-5.5.9\webapps\birt-viewer\WEB-INF ");
> configuration
> alternative
> HashMap values )
> return;
> continue;
> break;
> continue;
Re: Servlet code - Re: HTML/PDF does not show up [message #72207 is a reply to message #72171] Tue, 06 September 2005 04:37 Go to previous messageGo to next message
I personnaly use the following to get the task report forwarded to the
servlet response stream...
Unfortunately, I don't have time to check your servlet, but I give you
the following, just in case it can help... Sorry if it doesn't. ;o)
I'm not so experienced yet...
HTMLRenderOptions options = new HTMLRenderOption();
options.setOutputFormat(HTMLRenderOption.OUTPUT_FORMAT_PDF);
ByteArrayOutputStream out = new ByteArrayOutputStream();
options.setOutputStream(out);
task.setRenderOption(options);
task.run();
response.setContentLength((int) out.toByteArray().length);
response.getOutputStream().write(out.toByteArray());
response.getOutputStream().flush();
response.getOutputStream().close();
task = null;
On Mon, 5 Sep 2005 23:14:10 +0000 (UTC), Jenny@xxx.com (Jenny) wrote:
>Hello !!!
>Help
>Jenny
Re: Servlet code - Re: HTML/PDF does not show up [message #72701 is a reply to message #72171] Thu, 08 September 2005 11:41 Go to previous messageGo to next message
Originally posted by: Jenny.xxxx.com
Jenny wrote:
> Hello !!!
> Help
> Jenny
> Jenny wrote:
>> Here is my servlet
>> package com.Jen;
>> super();
>> engine.destroy( );
>> get.
>> //$NON-NLS-2$
>> String reportName =
>> " C:iopenjakarta-tomcat-5.5.9webappsbirt-viewerK2Slider.rptdes ign ";
>> //out.flush();
>> //out.close();
>> try
>> return;
>> catch(Exception e)
>> return;
>> // or PDF.
>> try
>> // Run the report
>> try
>> task.run( );
>> display.
>> * @param s
>> * @return String
>> if ( s == null )
>> return null;
>> switch ( c )
>> case 't':
>> break;
>> case 'n':
>> break;
>> case 'r':
>> break;
>> case ' ':
>> break;
>> case '"':
>> break;
>> case ''':
>> break;
>> case '<':
>> break;
>> case '>':
>> break;
>> case '`':
>> break;
>> case '&':
>> break;
>> default:
>> post.
>> response)
>> out.flush();
>> out.close();
>> // information.
> config.setEngineHome("C:iopenjakarta-tomcat-5.5.9webappsbirt-viewerWEB-INF ");
>> configuration
>> alternative
>> HashMap values )
>> return;
>> continue;
>> break;
>> continue;
Re: Servlet code - Re: HTML/PDF does not show up [message #72928 is a reply to message #72207] Thu, 08 September 2005 23:38 Go to previous messageGo to next message
Hello Frederic,
I tried with what you gave.
The Problem still persists. When i execute the chart report, i see a
picture on the browser, but the image is not showing up. when i looked at
the properties it points to
http://localhost:8080/ReportEngine.servlet/custom6. however i dont find
this file either on the server or the client machine temportary internet
files directory.
If i tried to save the chart on the server file system using the
options.setOutputfile(filename), i was able to see the chart with an
associated customx file in the directory.
Any help would be greatly appreciated.
Jenny
> task.run();
> task = null;
>>Hello !!!
>>Help
>>Jenny
Re: Servlet code - Re: HTML/PDF does not show up [message #73098 is a reply to message #72928] Fri, 09 September 2005 18:37 Go to previous messageGo to next message
any one know what is going on ?
Please help
Jenny wrote:
> Hello Frederic,
> files directory.
> Thanks
> Jenny
>> task.run();
>> task = null;
>>>Hello !!!
>>>Help
>>>Jenny
Re: Servlet code - Re: HTML/PDF does not show up [message #74926 is a reply to message #73098] Fri, 16 September 2005 11:36 Go to previous messageGo to next message
Originally posted by: thmwg.web.de
Hello Jenny,
IŽve exactly the same problem. Do you have solved the problem? If yes - I
would be glad if you can tell me how.
THX and greetings
Thomas
Re: Servlet code - Re: HTML/PDF does not show up [message #74975 is a reply to message #74926] Fri, 16 September 2005 12:19 Go to previous messageGo to next message
Originally posted by: Jen.xxxxx.com
Hello Thomas,
It is working for me now.What i did was in the .java file
I have set the Image directory.
Then i have set the Base URL for it.
Finally i have set the content t ype.
If it still does not work then go to browser and right click on the image
/Properties / copy the URL which it is using for image and use that in the
code.
GOod Luck
Jen
Thomas Wagner wrote:
> Hello Jenny,
> THX and greetings
> Thomas
Re: Servlet code - Re: HTML/PDF does not show up [message #75236 is a reply to message #74975] Fri, 16 September 2005 17:26 Go to previous message
Hi Jenny,
thanks for your fast reply. It would be very helpfull if you can post
(here or to : thmwg@web.de) me a codesnip of your java-file.
Thomas
Previous Topic:subreports bound to calculated columns
Next Topic:How to do System.out in BIRT ?
Current Time: Tue Jul 22 17:51:46 EDT 2025
Powered by FUDForum. Page generated in 0.05269 seconds
