Home » Archived » Visual Editor (VE) » .. is too complicated to be evaluated
.. is too complicated to be evaluated [message #71329] Thu, 11 November 2004 07:03 Go to next message
Originally posted by: mik.c-l-a-s-s-x.it
I have updated to Eclipse 3.0.1 and VEP to:
org.eclipse.ve (1.0.1) "Visual Editor"
org.eclipse.ve.cde (1.0.1) "Visual Editor Common Data Editor"
org.eclipse.ve.doc (1.0.1) "Visual Editor User Guide"
org.eclipse.ve.java.core (1.0.1) "Visual Editor Java Core"
org.eclipse.ve.java.core (1.0.1.1) "Visual Editor Java Core"
org.eclipse.ve.jfc (1.0.1) "Visual Editor for Java Foundation Classes"
org.eclipse.ve.jfc (1.0.1.1) "Visual Editor for Java Foundation Classes"
org.eclipse.ve.propertysheet (1.0.1) "Visual Editor PropertySheet"
org.eclipse.ve.swt (1.0.1) "Visual Editor for Standard Widget Toolkit"
I always get "java.lang.xxx IWA0125E ResourceLanguages.getString("xxx" is
too complicated to be evaluated)" when working on localized (externalized)
code.
I was not getting this error on the previous version. What happened ?
Mik
> ClassX Development Italy Via Francesca, 368/I I-56030 S.M. a Monte (PI) <
> Tel.(+39)-0587-705153 Fax.(+39)-0587-705153 WEB: http://www.classx.it <
Re: .. is too complicated to be evaluated [message #71388 is a reply to message #71329] Thu, 11 November 2004 09:40 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
We switched to a new way of parsing which gave us a more powerful
parser, BUT a few types of settings were left out. We have since fixed
this in the maintenance driver M20041109. You can either try that, or if
you don't want to step up to a development build yet, you will need to
fully-qualify with package name the ResourceLangauges in the getString stmt.
Rich Kulp
Re: .. is too complicated to be evaluated [message #71407 is a reply to message #71388] Thu, 11 November 2004 10:14 Go to previous messageGo to next message
Thanks Rich,
I'll try to switch to the maintenance driver.
Localization is a bit of pain with VE (and more generally with Eclipse). Are
there any plans to improve it in the next versions ?
Some suggestions:
- Ability to specify a common resource properties file and resources
handling class for a set of classes (i.e. package-specific or
project-specific).
- I would like to handle localized text in VE (the best would be VAJ style).
Mik
"Rich Kulp" <richkulp@us.NO_SPAM.ibm.com> ha scritto nel messaggio
news:cmvtk5$a3p$1@eclipse.org...
stmt.
> Rich Kulp
Re: .. is too complicated to be evaluated [message #71426 is a reply to message #71407] Thu, 11 November 2004 11:04 Go to previous message
Michele Puccini wrote:
> Thanks Rich,
> Some suggestions:
> project-specific).
The VE doesn't prevent you from doing this. As long as it is a static
the VE will be able to process it and show you the value (like it does
now). It could be a package or project static.
What it doesn't do is allow you to change or edit the resource file
through the property sheet. We have some thoughts on that and a defect,
but we haven't been able to work on it yet.
Anything else would be an Eclipse thing. They handle the externalization
process itself.
> Mik
Rich Kulp
Re: .. is too complicated to be evaluated [message #602981 is a reply to message #71329] Thu, 11 November 2004 09:40 Go to previous message
Rich Kulp
Re: .. is too complicated to be evaluated [message #602985 is a reply to message #71388] Thu, 11 November 2004 10:14 Go to previous message
Thanks Rich,
Some suggestions:
project-specific).
Mik
stmt.
> Rich Kulp
Re: .. is too complicated to be evaluated [message #602991 is a reply to message #71407] Thu, 11 November 2004 11:04 Go to previous message
> Thanks Rich,
> Some suggestions:
> project-specific).
process itself.
> Mik
Rich Kulp
Previous Topic:.. is too complicated to be evaluated
Next Topic:VE Unable to parse specific code
Current Time: Sun Jul 13 23:32:41 EDT 2025
Powered by FUDForum. Page generated in 0.09174 seconds
