More on problems importing binary projects [message #71295] |
Wed, 11 June 2003 13:05  |
Originally posted by: vde.uiuc.edu
hi,
this is with reference to the mail i sent a while back about the problems
i'm facing in importing binary projects. i thought it would be helpful to
give a list of all the error messages i got when i imported the jar file.
the project i tried to import the jar file into is called
org.eclipse.cexample.
Description Resource
The project was not built due to classpath errors
(incomplete or involved in cycle)
Missing required Java project: org.apache.xerces
Missing required Java project: org.eclispe.compare
Missing required Java project: org.eclipse.core.boot
Missing required Java project: org.eclipse.core.resources
Missing required Java project: org.eclipse.core.runtime
Missing required Java project: org.eclipse.debug.core
Missing required Java project: org.eclipse.debug.ui
Missing required Java project: org.eclipse.jdt.ui
Missing required Java project: org.eclipse.search
Missing required Java project: org.eclipse.ui
FUDForum. Page generated in 0.03491 seconds
