Home » Eclipse Projects » Equinox » Configuration Admin service usage example
Configuration Admin service usage example [message #71276] Wed, 02 August 2006 09:56 Go to next message
can someone share a code snippet on using Configuration Admin service.
Possibly something like one bundle has a managed service and some other
bundle changes configuration of this managed service.
Managed service part seems to be easy, but the bundle that will change
its configuration does not seem to be so obvious. There also some
problems possible with ConfigurationPermissions.
Sergey Mylnikov
P.S. I am using org.eclipse.exuinox.cm , got it from dev.eclipse.org CVS.
Re: Configuration Admin service usage example [message #71524 is a reply to message #71276] Fri, 04 August 2006 07:18 Go to previous message
I have learned to work with configuration admin service.
But nevetheless it is still not quite clear how to set
ConfigurationPermissions for different bundles. Along this line goes a
quiestion of how to set ServicePermissions.
regards,
Sergey Mylnikov
Sergey Mylnikov wrote:
> Hello,
> Sergey Mylnikov
Previous Topic:using ecore in an equinox runtime
Next Topic:How To: Get full path from a BundleDescriptor
Current Time: Sat Aug 09 02:13:25 EDT 2025
Powered by FUDForum. Page generated in 0.03834 seconds
