[AGR] Failure to locate local toolbar item in editor during playback [message #71268] |
Thu, 18 May 2006 12:53  |
Hello.
I have an editor of type MultiPageEditorPart, whose pages contain
different forms (collections of standard SWT fields in various types of
SWT containers). In some of these forms I have a container of type
ViewForm with a local toolbar in it. When I prepare a test containing a
button press of one of the buttons located in the local toolbar
("select" command in macro), the playback fails to locate the toolbar
item. Is there any obvious reason for this? If I record a test with a
button press for a button in the toolbar of a View, I do not have any
problems at all during playback.
TIA,
B.
PS: If in the test I invoke the same action using a popup menu item
which supports the same action, things work fine.
Re: [AGR] Failure to locate local toolbar item in editor during playback [message #71387 is a reply to message #71268] |
Sat, 20 May 2006 17:23  |
It maybe related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=131798
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:e4i8rv$fnr$3@utils.eclipse.org...
> Hello.
> TIA,
> B.
FUDForum. Page generated in 0.24364 seconds
