Home » Archived » Test and Performance Tools Platform (TPTP) » [AGR] Double click in StyledText?
[AGR] Double click in StyledText? [message #71247] Thu, 18 May 2006 12:44 Go to next message
Hello.
I have a StyledText in which I have implemented the double mouse click
as a means of selecting an entire word in the field (same as in an
normal text field). However when I try to record the double click in
position based recording, although I see my word being selected, the
macro shows two subsequent single clicks with exactly the same
coordinates, as follows:
<command type="mouse-click" detail="1" x-coord="847" y-coord="155"/>
During playback, the selection does not happen. Any pointer?
TIA,
B.
Re: [AGR] Double click in StyledText? [message #71367 is a reply to message #71247] Sat, 20 May 2006 17:20 Go to previous messageGo to next message
The combination of the two clicks should behave just like a double click (I
verified this with a quick test case).
Your operating system may be configured to register double clicks at a
different speed. Try putting a wait statement in between the two click
commands. For example:
<command type="wait" time-to-wait="100"/>
"Barbara Rosi-Schwartz" <Barbara.Rosi-Schwartz@Etish.org> wrote in message
news:e4i89u$bqq$1@utils.eclipse.org...
> Hello.
> TIA,
> B.
Re: [AGR] Double click in StyledText? [message #71466 is a reply to message #71367] Mon, 22 May 2006 05:15 Go to previous message
Ali, thanks for your reply.
Unfortunately your suggestion does not help. Double click appears to
work correctly during playback when I perform it in a normal Text
component, but not in a StyledText one.
The macro below may work as a simple test case to show aberrant
behaviour. The macro does the following:
1) start Eclipse in the Resource view
2) create a simple project (named p)
3) create a simple file (named f) in project p
4) in the text editor that is automatically opened by Eclipse, insert
the words "Some text here"
5) switch to position based recording, place the cursor between the
words "Some" and "text" and add the word "more"
6) double click on the word "more" to select it.
If I run this macro in quick mode, it all works fine. If I play it back
in the standard mode, the word "more" is inserted at the beginning of
the sentence, it does not get selected and the editor gets maximized to
take up the whole workbench.
I hope this helps in clarifying the problems. Please let me know if I am
doing something wrong or if this should go into Bugzilla.
Cheerio,
B.
---------- Macro begins -------------
<macro version="0.1" >
<shell id="org.eclipse.ui.internal.WorkbenchWindow" return-code="-1">
<command type="select" contextId="toolbar"
widgetId="contribid/newWizardDropDown"/>
<shell id="org.eclipse.jface.wizard.WizardDialog" return-code="0">
<command type="item-select"
contextId="wizard-page/newWizardSelectionPage"
widgetId="org.eclipse.swt.widgets.Tree#1">
<item
path=" org.eclipse.swt.widgets.TreeItem#{{org.eclipse.ui.Basic}}-{{ 1.0}} "/>
</command>
<command type="item-expand"
widgetId="org.eclipse.swt.widgets.Tree#1" value="true">
<item
</command>
<item
path=" org.eclipse.swt.widgets.TreeItem#{{org.eclipse.ui.wizards.ne w.project}}-{{1.0}} "/>
</command>
<command type="select" contextId="wizard"
widgetId="org.eclipse.swt.widgets.Button#{{15}}-{{1.0}}"/>
<command type="modify"
contextId="wizard-page/basicNewProjectPage"
widgetId="org.eclipse.swt.widgets.Text#1">
<![CDATA[p]]>
</command>
widgetId="org.eclipse.swt.widgets.Button#{{16}}-{{1.0}}"/>
</shell>
<command type="wait"/>
contextId="view/org.eclipse.ui.views.ResourceNavigator"
widgetId="org.eclipse.swt.widgets.Tree#{{/}}-{{1.0}}">
<item path="org.eclipse.swt.widgets.TreeItem#{{/p}}-{{1.0}}"/>
</command>
<command type="focus"
widgetId="org.eclipse.swt.widgets.Composite#1"/>
contextId=" popup/view/org.eclipse.ui.views.ResourceNavigator/org.eclips e.swt.widgets.Tree#{{/}}-{{1.0}} "
widgetId=" org.eclipse.ui.actions.NewWizardMenu#{{Ne&amp;w-&amp ;File}}-{{0.8}}{{0|3}}-{{0.6}}{{true}}-{{0.1}}{{9}}-{{0.1}}{ {&amp;Folder}}-{{0.2}}{{&amp;Untitled
Text File}}-{{0.2}}"/>
<command type="modify" contextId="wizard-page/newFilePage1"
widgetId="org.eclipse.swt.widgets.Text#2">
<![CDATA[f]]>
</command>
</shell>
contextId="editor/org.eclipse.ui.DefaultTextEditor/f"
widgetId="org.eclipse.swt.custom.StyledText#1">
<![CDATA[Some text here]]>
</command>
<command type="mouse-click" detail="1" x-coord="502" y-coord="97"/>
<command type="key-press" detail="109" ischarset="true"/>
<command type="key-press" detail="111" ischarset="true"/>
<command type="key-down" detail="114" ischarset="true"/>
<command type="key-press" detail="101" ischarset="true"/>
<command type="key-press" detail="32" ischarset="true"/>
<command type="mouse-click" detail="1" x-coord="510" y-coord="97"/>
<command type="wait" time-to-wait="5000"/>
</shell>
</macro>
---------- Macro ends -------------
Previous Topic:Could not initialize class org.eclipse.hyades.models.hierarchy.HierarchyPackage
Next Topic:Eclipse runtime workspace crash during test execution
Current Time: Sat Aug 30 12:54:42 EDT 2025
Powered by FUDForum. Page generated in 0.04053 seconds
