Home » Language IDEs » PHP Development Tools (PDT) » Excluding file from PHP syntax check?
Excluding file from PHP syntax check? [message #71226] Mon, 19 May 2008 12:16 Go to next message
Hello
Can I exclude certain files from the PHP syntax check?
Examples why I want this are:
* files from a framework which include later substituted @@WHATEVER@@
* 3rd party library files which are under my project directory as they are too
small to be put into an own project.
* files from co-workers which I just don't want to touch
I would like to see only warnings for files that I can fix :)
bye,
-christian-
Re: Excluding file from PHP syntax check? [message #71246 is a reply to message #71226] Mon, 19 May 2008 12:27 Go to previous message
Hi Christian,
A good point that was raised many times during the development of Eclipse
PDT.
PDT 1.0.x stream will not support such kind of requirement but PDT 1.1
will support for excluding and including resources (this feature is under
development these days and will be available in next PDT 1.1 releases)
Previous Topic:PDT help not showing up
Next Topic:PHP not in perspective
Current Time: Fri Jul 18 22:46:57 EDT 2025
Powered by FUDForum. Page generated in 0.02320 seconds
