Home » Eclipse Projects » Mylyn » Automatic upgrade from 3.2.0 to 3.2.1?
Automatic upgrade from 3.2.0 to 3.2.1? [message #71223] |
Mon, 27 July 2009 08:49  |
I'm using Galileo with Mylyn 3.2.0. I know that Mylyn 3.2.1 has been
released a couple of days ago, and I was expecting Eclipse would
automatically realize this and offer me to upgrade it (I have "automatic
updates" enabled). However, not only it does not offer me to upgrade but
manually checking for updates seems to only detect Subclipse updates
(which BTW I *don't* want to upgrade, since I'm currently stuck with
Subversion 1.5).
Is Subclipse 1.6 required for Mylyn 3.2.1? If not, shouldn't the upgrade
be automatically suggested? How do I workaround this?
(BTW: I've had some bad experiences recently regarding some plugin
upgrades which could be related to Mylyn, please refer to
http://www.eclipse.org/newsportal/article.php?id=1917&gr oup=eclipse.tools.mylyn#1917)
Andre
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #71242 is a reply to message #71223] |
Mon, 27 July 2009 10:53   |
> "automatic updates" enabled). However, not only it does not offer me to
> upgrade but manually checking for updates seems to only detect
> Subclipse updates (which BTW I *don't* want to upgrade, since I'm
> currently stuck with Subversion 1.5).
> upgrade be automatically suggested? How do I workaround this?
There is no direct relationship between Subclipse release and Mylyn
releases. The fact that a Subclipse upgrade is available to you has
nothing to do with Mylyn not showing.
BTW, why are you stuck with Subversion 1.5? Any SVN 1.x client can
talk to any 1.x server, so you should be able to run any version on the
client that you want to. That said, you do need a way to get the SVN
1.6 binaries for JavaHL. If you are on Linux, perhaps you are waiting
for your distro to upgrade you?
There are details on this wiki for doing it yourself:
http://subclipse.tigris.org/wiki/JavaHL
Mark
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #71262 is a reply to message #71242] |
Mon, 27 July 2009 11:08   |
Yes, I thought so. This is why I don't understand why Eclipse doesn't
realize Mylyn can be upgraded as well. AFAICS it should ask me to upgrade
both Subclipse and Mylyn, not because they're related somehow, but simply
because there are upgrades for both of them.
So, the core question is: why isn't Mylyn 3.2.1 picked by Eclipse updater?
Do I need to do anything on my own?
Yes, that's precisely my problem: latest subversion CLI client available
on Ubuntu Jaunty is 1.5.4, and I do use it a lot on the same workspace I
use Subclipse. If I upgrade Subclipse to 1.6 I will not be able to use
1.5.x CLI client any longer, which is unacceptable.
Andre
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #71282 is a reply to message #71262] |
Mon, 27 July 2009 12:45   |
> upgrade both Subclipse and Mylyn, not because they're related somehow,
> but simply because there are upgrades for both of them.
> updater? Do I need to do anything on my own?
Perhaps Mylyn 3.2.1 has not been published to the update sites Eclipse
is checking. For example, maybe the updates are configured to only
check the Galileo/Ganymeded (whatever) update site and 3.2.1 is not on
that site?
> available on Ubuntu Jaunty is 1.5.4, and I do use it a lot on the same
> workspace I use Subclipse. If I upgrade Subclipse to 1.6 I will not be
> able to use 1.5.x CLI client any longer, which is unacceptable.
Well, you can upgrade your CLI yourself if you choose to. But I
understand wanting to get it from Ubuntu. They do have 1.6 on the
Karmic site:
http://packages.ubuntu.com/karmic/subversion
Mark
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #71302 is a reply to message #71282] |
Mon, 27 July 2009 13:24   |
> that site?
Mmmh... could be, but then there's something else wrong here. The URL
published on Mylyn's site for updates is the one registered on Eclipse:
http://download.eclipse.org/tools/mylyn/update/e3.4
My first guess was that it was not officially available, for whatever
reason (despite the fact that it is announced as released), and that would
explain it not being pulled by the updater.
However, when I try to install Atlassian Connector through Mylyn Connector
Discovery the installer tries to fetch some (all?) Mylyn 3.2.1 JARs, and
that's what's puzzling me (and maybe what's confusing Eclipse, please
refer to the other thread for more details). It doesn't make sense to be
the latest version if you go one path but not if you follow another.
> Karmic site:
Yeah, it sucks, I never understood why subversion *client* always lags
behind on updates on Linux distros (I use Fedora 10 at home and I have the
same problem there as well), AFAIK there are no fancy dependencies that
could justify that, but...
Andre
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #92582 is a reply to message #71302] |
Mon, 27 July 2009 14:39   |
Maybe I can help with F10. Subversion 1.6.2 is available from quite some
time in the updates/testing repository, you can easily grab the rpm from
there and do a yum localinstall (if you don't want to enable the testing
repositories which may bring in some unwanted updates). Why it is still
in testing since april 27th is unknown.
To get the latest subversion (1.6.3) you can grab the 1.6.2 source rpm,
replace the source package with the one downloaded from tigris, change
the version number in the specs file and recompile. Works well, I'm on
F10 too and I'm using svn 1.6.3 with javahl and subclipse.
Marco.
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #136218 is a reply to message #71302] |
Mon, 27 July 2009 15:21   |
>> that site?
> would explain it not being pulled by the updater.
> Connector Discovery the installer tries to fetch some (all?) Mylyn
> 3.2.1 JARs, and that's what's puzzling me (and maybe what's confusing
> Eclipse, please refer to the other thread for more details). It doesn't
> make sense to be the latest version if you go one path but not if you
> follow another.
There is a difference between "Discovery Sites" and "Update Sites".
When you get an EPP package the updates all come from one master sites,
but individual plugins like Mylyn can still install their discovery
sites so that you can find additional plugins.
The check for updates only checks the update sites.
Mark
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #360096 is a reply to message #136218] |
Tue, 28 July 2009 09:36   |
Thks, that indeed explains the current behavior. However, I think it makes
room for confusion and -- worse -- glitches.
Eg. I am at home now and I've installed subversion 1.6.2 according to
Marco's suggestion. When I ask Eclipse to check for updates, it finds
Subclipse 1.6 (so far, so good). However, along with its own packages it
tries to pull these as well (all from 3.2.1 release):
- Mylyn Bridge: Eclipse IDE
- Mylyn Bridge: Java Development
- Mylyn Bridge: Team Support
- Mylyn Connector: Bugzilla
- Mylyn Task List
- Mylyn Task-Focused Interface
- Mylyn WikiText (1.1.1)
If I accept and proceed with the installation, I end up with the dreadful
"no-plugins" problem
[ http://www.eclipse.org/newsportal/article.php?id=1915&gr oup=eclipse.tools.mylyn#1915].
Major fail :(
In order to fix this, I have to:
- close Eclipse
- remove ~/.eclipse/org.eclipse.platform_3.5.0_1729844414 (I thought
-clean should do this, but apparently it doesn't; is there any better way?)
- restart Eclipse
- reinstall Subclipse (and any other plugins I had before) *with "contact
other updates sites" DISABLED*. Now this is weird: AFAICS when I am
INSTALLING a feature I can disable the "contact other sites" feature, but
when I'm UPGRADING I can't do it.
So, IMHO there's a problem somewhere that deserves a bug report, I just
don't know whose fault this is. Where should I file it? Subclipse? Mylyn?
Eclipse itself?
Andre
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #369105 is a reply to message #361782] |
Tue, 28 July 2009 11:32  |
> On 2009-07-28 09:42:11 -0400, costa@tecgraf.puc-rio.br (Andre Costa) said:
>> Thks. I realized the problem is the other way around (it's Subclipse
>> that tries to install Mylyn 3.2.1 if "check other updates sites" is
>> enabled).
> As you know, the install/update code is entirely owned by Eclipse.
> Plugins can just declare their requirements. Subclipse does not
> require Mylyn and does not force it to be installed. However, the
> Subclipse update site does host a plugin that provides the integration
> between Subclipse and Mylyn. This plugin obviously requires Mylyn (it
> just specifies 3.0.0 or greater).
> Since you apparently do not have Mylyn installed already, the Eclipse
> installer is trying to find it on one of the sites it knows about.
But I *do* have Mylyn 3.2.0 "installed" (at least I use the one that comes
with Galileo by default), and the integration with Subclipse *is* working.
Since Subclipse declares that it depends on Mylyn >= 3.0.0 Eclipse
shouldn't try to pull Mylyn 3.2.1 considering there's no hard dependency
on this particular version and since Eclipse itself doesn't see Mylyn
3.2.1 as an eligible upgrade. This behavior is inconsistent IMHO.
However, that's not the biggest problem. If Mylyn 3.2.1 could be installed
I wouldn't care how it was pulled. But, for some reason I can't install
Mylyn 3.2.1 on Galileo, no matter how I try it, the result is always the
same: once it is installed other plugins (FindBugs, Subclipse etc.) stop
working. They don't even appear on the Preferences settings. I even tried
starting from scratch -- removing
~/.eclipse/org.eclipse.platform_3.5.0_1729844414/ -- and installing Mylyn
3.2.1 from a local zipped archive, before trying to install any additional
plugins; once I install the others, they simply don't work.
It could be something specific to my installation (Linux), but since
Michael Rehse had the same problem on Vista
[ http://www.eclipse.org/newsportal/article.php?id=1915&gr oup=eclipse.tools.mylyn#1915],
I tend to think it's something else.
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598380 is a reply to message #71223] |
Mark
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598385 is a reply to message #71242] |
Andre
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598388 is a reply to message #71262] |
that site?
Karmic site:
Mark
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598392 is a reply to message #71282] |
> that site?
> Karmic site:
Andre
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598408 is a reply to message #71223] |
Mon, 27 July 2009 14:23  |
> Subversion 1.5).
Are you using one of the EPP packages? If so Mylyn updates will only
automatically be shown as part of the Galileo SR1 (Sep 2009) and SR2 (Feb
2010) updates. Mylyn shows as a nested feature of the EPP package feature
under About > Installed Software and P2 will only update top-level features.
No, there is no dependency on a specific Subclipse version.
Steffen
Steffen Pingel
Committer, http://eclipse.org/mylyn
Senior Developer, http://tasktop.com
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598412 is a reply to message #71302] |
Marco.
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598423 is a reply to message #71302] |
>> that site?
> follow another.
Mark
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598428 is a reply to message #92582] |
Tue, 28 July 2009 08:49  |
Hi Marco,
I do use testing packages when I have to (and when they don't break
anything else ;-)), but I confess I have overlooked subversion. I will
give it a try, thks for the reminder.
Andre
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598443 is a reply to message #136218] |
- Mylyn Task List
Major fail :(
- close Eclipse
- restart Eclipse
Eclipse itself?
Andre
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598447 is a reply to message #74995] |
Tue, 28 July 2009 09:42  |
Hi Steffen,
Thks for the explanation, now I know how this works. Still, I believe
there is a serious problem somewhere (please refer to my recent reply to
Mark).
Just out of curiosity: if I wanted to install Mylyn 3.2.1 from a zipped
local archive, should this work? Is this advisable or should I wait for
the SR1 update?
Thks. I realized the problem is the other way around (it's Subclipse that
tries to install Mylyn 3.2.1 if "check other updates sites" is enabled).
Andre
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598452 is a reply to message #360325] |
Tue, 28 July 2009 09:53  |
> enabled).
Mark
Re: Automatic upgrade from 3.2.0 to 3.2.1? [message #598462 is a reply to message #361782] |
>> enabled).
Current Time: Thu Jul 17 23:43:42 EDT 2025
Powered by FUDForum. Page generated in 0.32147 seconds
