Home » Eclipse Projects » Equinox » Deploying servlet in a solaris environment
Deploying servlet in a solaris environment [message #71171] Mon, 31 July 2006 18:12 Go to next message
Originally posted by: ksshams.gmail.com
Our servlet works fine with UI dependencies on the Windows OS. Our
servlet basically depends on plugins that have dependencies on the UI
plugin. When I tried deploying the servlet in the linux environment, I
cannot do so. One of the differences I noticed in the ss output between
the windows and solaris was that the UI plugin was not started on the
solaris machine. Similar issues came about with the Linux environment.
I have copied over all of the swt jar files for linux and solaris into
our plugins folder, but I still cannot start the UI plugin. I am not
sure what to do next as our own plugins will not start due to
dependencies on the UI plugin. I would sincerely appreciate any help
regarding the matter.
Khawaja Shams
osgi> ss
Framework is launched.
id State Bundle
0 ACTIVE system.bundle_3.2.0.v20060601
Fragments=28
1 ACTIVE org.eclipse.equinox.common_3.2.0.v20060603
2 ACTIVE org.eclipse.update.configurator_3.2.0.v20060605
3 ACTIVE
org.eclipse.equinox.servlet.bridge.http_3.2.0.200607131428
4 ACTIVE org.eclipse.equinox.http.registry_3.2.0.200607131428
5 ACTIVE sample.http_1.0.0
6 RESOLVED gov.nasa.jpl.maestro.mer.dataproduct_1.0.15.200607271534
7 ACTIVE org.apache.log4j_1.2.8.2
8 RESOLVED gov.nasa.jpl.maestro.core.jai_1.0.6.200607271534
9 RESOLVED gov.nasa.jpl.maestro.core.dataproduct_1.0.0.200607271534
10 RESOLVED org.eclipse.rcp_3.2.0.v20060605
11 RESOLVED org.eclipse.core.contenttype_3.2.0.v20060603
12 RESOLVED gov.nasa.ensemble.core.hibernate.tool_1.0.7.200607271534
13 RESOLVED gov.nasa.ensemble.core.rcp_1.0.15.200607271534
14 RESOLVED org.eclipse.swt_3.2.0.v3232o
15 RESOLVED org.hibernate_3.1.4
16 RESOLVED org.eclipse.update.core_3.2.0.v20060602
17 INSTALLED org.eclipse.swt.gtk.linux.x86_64_3.2.0.v3232m
19 RESOLVED javax.media.jai_1.0.0
20 RESOLVED gov.nasa.ensemble.core.hibernate_1.0.13.200607271534
21 RESOLVED gov.nasa.ensemble.mer_1.0.15.200607271534
22 RESOLVED org.hsqldb_1.7.2.5
23 RESOLVED javax.vecmath_1.0.0
25 RESOLVED org.eclipse.core.expressions_3.2.0.v20060605-1400
26 RESOLVED net.sf.antcontrib_1.0.2
27 RESOLVED org.eclipse.help.base_3.2.0.v20060601
28 RESOLVED org.eclipse.equinox.servlet.bridge.extensionbundle_3.2.0
Master=0
29 RESOLVED org.eclipse.ui.forms_3.2.0.v20060530
30 RESOLVED gov.nasa.ensemble.core.common_1.0.15.200607271534
31 ACTIVE org.eclipse.equinox.registry_3.2.0.v20060601
32 RESOLVED org.eclipse.help_3.2.0.v20060602
33 RESOLVED org.eclipse.osgi.services_3.1.100.v20060601
34 INSTALLED org.eclipse.swt.gtk.linux.ppc_3.2.0.v3232m
36 RESOLVED org.apache.commons.httpclient_2.0.2.3
37 RESOLVED org.apache.ant_1.6.5
38 RESOLVED org.exolab.castor_0.9.9.2
39 RESOLVED org.eclipse.help.appserver_3.1.100.v20060510b
40 RESOLVED org.eclipse.help.ui_3.2.0.v20060510b
41 RESOLVED org.apache.lucene_1.4.103.v20060601
42 RESOLVED org.apache.xerces_2.6.3
43 RESOLVED org.eclipse.ant.core_3.1.100.v20060531
44 RESOLVED org.junit_3.8.1
45 RESOLVED gov.nasa.jpl.maestro.core.common_1.0.15.200607271534
46 RESOLVED org.eclipse.tomcat_4.1.130.v20060601
47 RESOLVED org.eclipse.ui_3.2.0.I20060605-1400
48 RESOLVED org.eclipse.ui.cheatsheets_3.2.0.v20060516
50 RESOLVED gov.nasa.jpl.maestro.core.testdata_1.0.0
51 RESOLVED org.eclipse.ui.views_3.2.0.I20060511-2000
53 RESOLVED org.eclipse.ui.intro_3.2.0.v20060601
54 RESOLVED gov.nasa.ensemble.core.frame_1.0.11.200607271534
55 ACTIVE org.eclipse.core.runtime_3.2.0.v20060603
56 INSTALLED org.eclipse.update.configurator_3.2.0.v20060511
57 RESOLVED
gov.nasa.ensemble.core.planning.database.preferences_1.0.8.2 00607271534
58 RESOLVED org.jdom_1.0.1
61 RESOLVED org.eclipse.update.ui_3.2.0.v20060601
62 RESOLVED org.eclipse.core.variables_3.1.100.v20060517
64 RESOLVED gov.nasa.ensemble.mars.common_1.0.0.200607271534
65 RESOLVED org.eclipse.help.webapp_3.2.0.v20060510b
66 INSTALLED org.eclipse.swt.gtk.solaris.sparc_3.2.0.v3232m
67 RESOLVED net.sf.antcontrib.cpptasks_1.0.1
68 RESOLVED org.eclipse.ui.workbench_3.2.0.I20060605-1400
69 RESOLVED org.eclipse.jface.databinding_1.0.0.I20060605-1400
70 RESOLVED org.apache.commons.logging_1.0.1
71 ACTIVE
org.eclipse.core.runtime.compatibility_3.1.100.v20060601a
72 RESOLVED org.eclipse.core.resources_3.2.0.v20060601a
73 RESOLVED org.apache.commons.lang_2.0.1
75 ACTIVE
org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601
76 INSTALLED org.eclipse.swt.gtk.linux.x86_3.2.0.v3232m
77 RESOLVED com.ibm.icu_3.4.4.1
78 RESOLVED org.eclipse.core.filesystem_1.0.0.v20060601a
79 RESOLVED org.eclipse.jface_3.2.0.I20060605-1400
80 RESOLVED org.hibernate.tool_3.1.2
82 ACTIVE org.eclipse.core.jobs_3.2.0.v20060603
83 RESOLVED org.eclipse.core.commands_3.2.0.I20060605-1400
84 INSTALLED org.eclipse.swt.win32.win32.x86_3.2.0.v3232m
85 ACTIVE org.eclipse.equinox.preferences_3.2.0.v20060601
osgi> start org.eclipse.ui
org.osgi.framework.BundleException: The activator
org.eclipse.ui.internal.UIPlugin for bundle org.eclipse.ui is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:966)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:317)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
org.eclipse.osgi.framework.internal.core.FrameworkCommandPro vider._start(FrameworkCommandProvider.java:239)
org.eclipse.osgi.framework.internal.core.FrameworkCommandInt erpreter.execute(FrameworkCommandInterpreter.java:145)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.do command(FrameworkConsole.java:293)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.co nsole(FrameworkConsole.java:278)
org.eclipse.osgi.framework.internal.core.FrameworkConsole.ru n(FrameworkConsole.java:213)
at java.lang.Thread.run(Thread.java:595)
Caused by: java.lang.NoClassDefFoundError:
org/eclipse/ui/plugin/AbstractUIPlugin
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:498)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:468)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:427)
org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:410)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:339)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:391)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 13 more
Nested Exception:
java.lang.NoClassDefFoundError: org/eclipse/ui/plugin/AbstractUIPlugin
Nested Exception:
osgi>
Re: Deploying servlet in a solaris environment [message #71257 is a reply to message #71171] Wed, 02 August 2006 09:00 Go to previous messageGo to next message
Comparing the state of your framework
with my eclipse installation
406 RESOLVED org.eclipse.swt_3.2.0.v3232o
Fragments=408
407 INSTALLED org.eclipse.swt.gtk.linux.x86_3.2.0.v3232l
408 RESOLVED org.eclipse.swt.win32.win32.x86_3.2.0.v3232m
Master=406
I noticed that the swt fragment for the platform I'm on is resolved, not
just installed.
In your framework, none of the bundles is actually resolved. To find out
why, you can use the "diag" command like this:
osgi> diag 407
update@plugins/org.eclipse.swt.gtk.linux.x86_3.2.0.v3232l.jar
Platform filter did not match: (& (osgi.ws=gtk) (osgi.os=linux)
(osgi.arch=x86))
Missing Constraint: Fragment-Host: org.eclipse.swt;
bundle-version="[3.0.0,4.0.0)"
osgi> diag 408
update@plugins/org.eclipse.swt.win32.win32.x86_3.2.0.v3232m.jar
No unresolved constraints.
That is the command "diag" followed by the id of the bundle.
You can also use the bundle name like this:
osgi> diag org.eclipse.swt.gtk.linux.x86
update@plugins/org.eclipse.swt.gtk.linux.x86_3.2.0.v3232l.jar [407]
(osgi.arch=x86))
HTH
Harald
Re: Deploying servlet in a solaris environment [message #71948 is a reply to message #71171] Fri, 11 August 2006 02:59 Go to previous message
In case someone else has this problem in the future, we solved this
by adding the following lines to our launch.ini:
osgi.ws=gtk
osgi.os=solaris
osgi.arch=sparc
It seems like we should not have had to do this, but it solved our
problem.
Khawaja Shams
> Hello,
> Khawaja Shams
> osgi> ss
> id State Bundle
> Fragments=28
> 3 ACTIVE org.eclipse.equinox.servlet.bridge.http_3.2.0.200607131428
> 6 RESOLVED
> 9 RESOLVED
> 12 RESOLVED
> 28 RESOLVED
> Master=0
> 57 RESOLVED
> 71 ACTIVE org.eclipse.core.runtime.compatibility_3.1.100.v20060601a
> 75 ACTIVE org.eclipse.core.runtime.compatibility.auth_3.2.0.v20060601
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 13 more
> Nested Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Nested Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> osgi>
Previous Topic:Discovering Hook Configurators
Next Topic:OSGi bundle class loader
Current Time: Fri Jul 18 22:38:36 EDT 2025
Powered by FUDForum. Page generated in 0.04525 seconds
