Home » Modeling » GMF (Graphical Modeling Framework) » Changin the palette background and foreground colors
Changin the palette background and foreground colors [message #71144] Fri, 27 October 2006 18:50 Go to next message
Originally posted by: atoulme.intalio.com
is there a way to change the palette colors ?
Antoine Toulmé
Re: Changin the palette background and foreground colors [message #73090 is a reply to message #71144] Wed, 01 November 2006 20:26 Go to previous messageGo to next message
I filed a bug regarding this question :
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163163
Antoine Toulmé
Antoine Toulmé wrote:
> Antoine Toulmé
Re: Changin the palette background and foreground colors [message #73359 is a reply to message #73090] Thu, 02 November 2006 09:50 Go to previous messageGo to next message
Antoine
The settings for the palette match the workbench settings. You can open the
Palette view to move the palette into a view. You will see exactly how the
colours match the workbench settings (Font, colour, etc.).
There is no API to change these settings, so I will change your Bugzilla
below to an enhancement request.
Cheers...
Anthony
"Antoine Toulm
Re: Changin the palette background and foreground colors [message #73661 is a reply to message #73359] Thu, 02 November 2006 19:02 Go to previous messageGo to next message
Hi Anthony,
thank you for your answer.
The discussion will continue on the bugzilla, I guess.
Anthony Hunter wrote:
> Antoine
> Cheers...
> Anthony
> "Antoine Toulmé" <atoulme@intalio.com> wrote in message
> news:eibhga$bke$1@utils.eclipse.org...
>> Regards,
>> Antoine Toulmé
>>> Hi,
>>> Regards,
>>> Antoine Toulmé
Re: Changin the palette background and foreground colors [message #75544 is a reply to message #73661] Tue, 07 November 2006 13:02 Go to previous message
Hi Antonie;
The Palette is constructed using EditParts, you can always have your
own PaletteEditPartFactory that creates a specialized edit parts for
your palette, or you can override the hookPaletteViewer method on the
PaletteViewerProvider and change the back ground color on the figure of
the palette edit part
For example; lets say i want to change the background color of all
palettes to be Red, i can override
PaletteViewerProvider#hookPaletteViewer inside the
DiagramEditorWithFlyOutPalette and implement it like this :
protected void hookPaletteViewer(PaletteViewer viewer) {
super.hookPaletteViewer(viewer);
RootEditPart rEP = viewer.getRootEditPart();
((AbstractGraphicalEditPart)(rEP.getChildren().get(0))).getF igure().setBackgroundColor(new
Color(null,255,0,0));
For sure this is not the practical way to do it, this is just an
example on how can i customize the palette ; you should do that only in
your editor to make sure you change only your palette, and it is better
to have your own palette edit parts and customize them in the way you like.
To provide a specialized editor for your diagram you can use
AbstractEditorProvider.
i hope this helps
> Hi Anthony,
>> Antoine
>> open the Palette view to move the palette into a view. You will see
>> exactly how the colours match the workbench settings (Font, colour,
>> etc.).
>> Bugzilla below to an enhancement request.
>> Cheers...
>> Anthony
>>> Regards,
>>> Antoine Toulmé
>>>> Hi,
>>>> Regards,
>>>> Antoine Toulmé
Previous Topic:How to access an attribute of a node?
Next Topic:How to get Diagram size in layoutProvider
Current Time: Thu Jul 17 13:57:43 EDT 2025
Powered by FUDForum. Page generated in 0.32887 seconds
