Home » Archived » Test and Performance Tools Platform (TPTP) » unable to generate .execution file from .testsuite
unable to generate .execution file from .testsuite [message #71128] Wed, 17 May 2006 08:49 Go to next message
Originally posted by: peter.boldizs.siemens.com
Greetings!
I have started working with TPTP JUnit test cases. I have written a simple
tester class and then generated a TPTP JUnit test. I have generated test
method and filled them with meaningful tests (assertEquals(...)).
I was able to run the "normal" JUnit test(Eclipse's own built-in JUnit
utility) successfully. When I tried to run the generated .testsuite file
(as TPTP "Test"), it was supposed to generate some .execution file. This
was unfortunately not successful. Two processes ("Launching" and
"Executing tests") are started but they are stuck and nothing happens.
I have found the following entry in the Eclipse workspace log:
!ENTRY org.eclipse.hyades.test.core 1 0 2006-05-17 14:46:16.24
!MESSAGE
org.eclipse.hyades.internal.execution.local.control.Inactive ProcessException
!STACK 0
org.eclipse.hyades.execution.harness.TestExecutionHarnessExe cutorStub.launch(TestExecutionHarnessExecutorStub.java:417)
org.eclipse.hyades.execution.harness.TestExecutionHarness.la unchTestExecution(TestExecutionHarness.java:2058)
org.eclipse.hyades.execution.harness.TestExecutionHarness.ac cess$2(TestExecutionHarness.java:1856)
org.eclipse.hyades.execution.harness.TestExecutionHarness$2. run(TestExecutionHarness.java:692)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
I would appreciate any help.
Thanks.
Peter Boldizs
Re: unable to generate .execution file from .testsuite [message #71348 is a reply to message #71128] Sat, 20 May 2006 17:05 Go to previous messageGo to next message
The exception below doesn't indicate much.
Can you tell me what driver you are using and what percentage the launch
gets stuck at?
Are you using a standalone Agent Controller or the intgarated version of the
Agent Controller (IAC)?
If you are using a standalone version of the Agent Controller, please attach
the content of its log file to this thread (<AC-HOME>/config/servicelog.log)
Thanks.
"Peter Boldizs" <peter.boldizs@siemens.com> wrote in message
news:b5293aeec8ceaf08104421dfa72d17b4$1@www.eclipse.org...
> Greetings!
> !MESSAGE
> !STACK 0
> at
> at
> at
> at
nHarness.java:692)
> Thanks.
> Peter Boldizs
Re: unable to generate .execution file from .testsuite [message #71807 is a reply to message #71348] Fri, 26 May 2006 05:04 Go to previous messageGo to next message
Hello!
I am using Eclipse 3.1.0 and TPTP 4.1.0.
It did not occur to me that I have to run the Agent Controller for TPTP
JUnit tests (isn't it only for profiling/logging?). The screencast I have
seen (TPTP/Documentation/TPTP 4.0.0 Introductory Screencasts/JUnit
Integration)never mentioned that the Agent Controller must be run.
Peter
Re: unable to generate .execution file from .testsuite [message #71933 is a reply to message #71807] Fri, 26 May 2006 14:21 Go to previous message
Peter Boldizs wrote:
> Hello!
> have seen (TPTP/Documentation/TPTP 4.0.0 Introductory Screencasts/JUnit
> Peter
No, he didn't say you *had* to run the AC, only that you could. By
default, without the AC, you should be going through the IAC (Integrated
AC) that operates within the same process space. The IAC will be the
default "AC" controlling agents unless it sees that a standalone AC
already has the resources it needs ... named pipe/socket.
You aren't on a system where the AC might have been started as a
service, right? Or where someone else might have the AC running, thus
preventing your workbench from successfully starting the IAC?
RDS
Randy D. Smith randy (dot) d (dot) smith (at) intel (dot) com
Eclipse TPTP Committer, Platform Proj (data collection/agent controller)
Previous Topic:How to expand a TreeViewer in a view through an IVewPart (verification hook)
Next Topic:is BIRT needed to install TPTP?
Current Time: Sat Jul 26 10:03:08 EDT 2025
Powered by FUDForum. Page generated in 0.14480 seconds
