Home » Language IDEs » PHP Development Tools (PDT) » PDT help not showing up
PDT help not showing up [message #71125] Sat, 17 May 2008 17:54 Go to next message
Originally posted by: pock.127.0.0.1
Eclipse 3.3.2 and PDT 1.0.3 RC1 - PDT User Guide is not showing up in
Eclipse "Help Contents". Probably because org.eclipse.php.help is not
loaded - it's missing on the list in Help -> About Eclipse Platform ->
Feature Details -> PDT Plug-in -> Plug-in Details, however it's
installed in plugins/ and not damaged in any way I can recognise. Any
ideas?
xmpp:pocketer@jabber.gda.pl
Re: PDT help not showing up [message #71148 is a reply to message #71125] Sat, 17 May 2008 23:03 Go to previous messageGo to next message
Originally posted by: euthanasia_waltz.yahoo.co.jp.earth
org.eclipse.php.help plugin of rc1 requires org.junit4 plugin. You can get
it from Eclipse Classic package or Eclipse IDE for Java Developers package
or... Also you can edit Manifest.mf in org.eclipse.php.help plugin. Remove
'org.junit4' from 'Require-Bundle'. (If you cannot wait 1.0.3 release)
I believe this unnecessary dependency will be removed from 1.0.3 release...
Re: PDT help not showing up [message #71167 is a reply to message #71148] Sun, 18 May 2008 03:07 Go to previous message
> can get it from Eclipse Classic package or Eclipse IDE for Java
> Developers package or...
> release) I believe this unnecessary dependency will be removed from
> 1.0.3 release...
This has worked after disabling and re-enabling PDT feature again.
Thanks.
Previous Topic:Can't Configure PDT Include Path to find the GD library
Next Topic:Excluding file from PHP syntax check?
Current Time: Sun Aug 31 18:23:02 EDT 2025
Powered by FUDForum. Page generated in 0.03975 seconds
